Re: Grinding weld on patch panel [Re: ZIPPY] #2788461
06/23/20 01:28 PM
06/23/20 01:28 PM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
Ever try hammer welding?
Re: Grinding weld on patch panel [Re: ZIPPY] #2788506
06/23/20 03:34 PM
06/23/20 03:34 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
Originally Posted by ZIPPY
Thinking about one of these:
https://youtu.be/fPDbu_T0kL0
I have that and like it. Works well for grinding out spot welds and can get you back into tight areas.
Re: Grinding weld on patch panel [Re: ZIPPY] #2789403
06/26/20 10:58 AM
06/26/20 10:58 AM
moparx Offline
moparx  Offline
i have an air version of one of those belt sanders. works very well for lots of applications. up
beer
Re: Grinding weld on patch panel [Re: gzig5] #2789497
06/26/20 02:04 PM
06/26/20 02:04 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
beer
On those little 13 inch belts, do you guys prefer 36 or 60 grit for knocking down welds?
80 grit discs seem too slow, I was thinking the belt + going more coarse would help me be more productive.
Rich H.
Esse Quam Videri
Re: Grinding weld on patch panel [Re: ZIPPY] #2789847
06/27/20 12:36 PM
06/27/20 12:36 PM
moparx Offline
moparx  Offline
it depends a lot on the job at hand.
i use both 36 & 60 grit to rough grind, followed by the 80.
beer
Re: Grinding weld on patch panel [Re: ZIPPY] #2790158
06/27/20 11:31 PM
06/27/20 11:31 PM
Mequon, WI
gzig5 Offline
gzig5  Offline
Mequon, WI
I'm not sure which grit is on there. I bought several spares but am still using the one it came with. I would think that rougher is better to remove the material fast with less heat.
Re: Grinding weld on patch panel [Re: gzig5] #2790288
06/28/20 12:49 PM
06/28/20 12:49 PM
moparx Offline
moparx  Offline
what a lot of guys forget is a new belt or disc of any grit cuts faster and cooler than a used one.
don't try to use up your belt or disc just because there is some grit still there.
i save my used ones and use them up forming and polishing thick [1/8" and up] material.
beer
Re: Grinding weld on patch panel [Re: cudaman1969] #2790554
06/29/20 12:45 AM
06/29/20 12:45 AM
Phila
P
PhillyRag Offline
PhillyRag  Offline
P
Phila
That does work nice. But it always seems you have to be really fast or have 3 hands.
Re: Grinding weld on patch panel [Re: PhillyRag] #2790973
06/30/20 12:54 PM
06/30/20 12:54 PM
Kingsburg Calif.
Quikshft Offline
Quikshft  Offline
Kingsburg Calif.
I have always used an air driven cut-off wheel for grinding sheet metal welds. They are available in different levels of abrasion, a gritty disc grinds pretty quickly without building up much heat.
Re: Grinding weld on patch panel [Re: Quikshft] #2796505
07/14/20 01:01 PM
07/14/20 01:01 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I went and bought the air version of that mini belt sander. Works great with 36 grit.
Rich H.
Esse Quam Videri
