Page 1 of 3 1 2 3
Dissapointed with my run with 69 Roadrunner/440 6pk #278766
04/05/09 09:58 PM
04/05/09 09:58 PM
Wisconsin
BLONDE BARRACUDA Offline OP
Wisconsin
Went to drag strip Saturday. Made 3 passes with the best of 14.2 at 95mph with a 1969 Roadrunner 440 6pk with 4speed. Mainly stock with a little better cam, 391 gears. Tires were spinning in 1st only with a best of 1.90 60ft. Was hoping for mid to upper 13's. I think that maybe the factory fuel system was a little restrictive. Seemed sluggish after the first 1/8th mile. Is this ET sound about right with this combo or is it slow ???? It is just a street car/daily driver but kind of expected it to ET better...thanks for any and all replies
Re: Dissapointing Run w/440 6pk [Re: BLONDE BARRACUDA] #278767
04/05/09 10:13 PM
04/05/09 10:13 PM
Chilliwack B.C. Canada
RUNCHARGER Offline
RUNCHARGER  Offline
You're down on power. You should be hitting at least 102 MPH. Check the basics, timing, fuel pressure.
Sheldon
Re: Dissapointing Run w/440 6pk [Re: RUNCHARGER] #278768
04/05/09 10:19 PM
04/05/09 10:19 PM
Wisconsin
Wisconsin
I do believe it is fuel related. I do have a restricted inline fuel filter. Thanks for your response
Re: Dissapointing Run w/440 6pk [Re: BLONDE BARRACUDA] #278769
04/05/09 10:40 PM
04/05/09 10:40 PM
Idaho
Runner Offline
Runner  Offline
Idaho
what were the rest of the numbers on the slip. spinning to a 1.90 60' would lead me to believe the car could go low 13s-high 12s.
Re: Dissapointing Run w/440 6pk [Re: Runner] #278770
04/05/09 10:44 PM
04/05/09 10:44 PM
Wisconsin
Wisconsin
the 1.9 60ft run hooked up pretty good. The other two runs were 2.15 and 2.2 60ft. Mph was between 93 and 95. I don't have the slips on hand but that was the just of it. The best ET was with the 2.15 60ft.
Re: Dissapointing Run w/440 6pk [Re: BLONDE BARRACUDA] #278771
04/05/09 10:55 PM
04/05/09 10:55 PM
Flint, Michigan
B1Fish540 Offline
B1Fish540  Offline
Flint, Michigan
Do you have a 3/8" line and pick up? The 5/16 is too small if you have that. What type of pump are you running? I had good luck with the carter 120 gph one.
Re: Dissapointing Run w/440 6pk [Re: B1Fish540] #278772
04/05/09 10:59 PM
04/05/09 10:59 PM
Idaho
Runner Offline
Runner  Offline
Idaho
what was the 1/8 mile numbers? im still running 5/16 pickup and a carter strip pump and am running 119 mph in a 3800 pound car.
Re: Dissapointing Run w/440 6pk [Re: B1Fish540] #278773
04/05/09 11:03 PM
04/05/09 11:03 PM
Wisconsin
Wisconsin
It has the factory pick up and fuel pump which I agree could be the problem although many muscle cars came with the 5/16th line and mechanical fuel pump and ran much quicker than this.
Re: Dissapointing Run w/440 6pk [Re: B1Fish540] #278774
04/05/09 11:05 PM
04/05/09 11:05 PM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Some thing isnt right, have you checked basics, like timing? If the stock fuel system is in good working order, its not your problem period. A stock Road runner with a stock 383, with factory intake, carb, full interior, stock converter 3.55 gears. And a good tune, would run 100 mph in the 1/4. Spare tire in the trunk and all.
Re: Dissapointing Run w/440 6pk [Re: Bob_Coomer] #278775
04/05/09 11:13 PM
04/05/09 11:13 PM
Wisconsin
Wisconsin
timing is at 36 degrees I still believe my in line filter is the problem. I do not believe at all that a stock 383 with 354 gears will run 100mph in 1/4. I appreciate your reply
Post deleted by Defbob [Re: BLONDE BARRACUDA] #278776
04/06/09 12:32 AM
04/06/09 12:32 AM
Re: Dissapointing Run w/440 6pk #278777
04/06/09 12:46 AM
04/06/09 12:46 AM
Renton Washington
Triple Threat Offline
Renton Washington
ROAD AND TRACK: The standard engine was a 383 CID Roadrunner V8 rated at 335 bhp and 425 lb·ft of torque. For an extra $714, Plymouth would install a 426 CID Hemi rated at 425 bhp and 490 lb·ft of torque. Combined with low weight, the 6-passenger Road Runner could run the 1/4 mile in 13.4 seconds at 105 mph. It would prove to be one of the best engines of the muscle car era, and the Road Runner one of the best platforms to utilize it. Plymouth expected to sell about 2,000 units in 1968; actual sales numbered around 45,000. (It should also be noted Dodge debuted the Road Runner's cousin, the Super Bee, that same year
Read the quote again Freddy, that time is for the Hemi equipped Roadrunner.
-Dustin
67 Dart, 9 second, 392" G3 Hemi
68 Barracuda 340 F/SA
Re: Dissapointing Run w/440 6pk #278778
04/06/09 12:50 AM
04/06/09 12:50 AM
Vista, California
67Satty Offline
67Satty  Offline
Vista, California
I think the goal for the 383 back then was a 14 flat at 100 mph quarter. Even those I'm guessing were ringers.
I'm thinking the 13.4 at 105 must've been the Hemi.
Average, garden-variety, bone-stock, non-ringer not tuned-for the-magazines 383 Roadrunner? I'm guessing most of those would run a low 15?
Re: Dissapointing Run w/440 6pk [Re: Triple Threat] #278779
04/06/09 12:51 AM
04/06/09 12:51 AM
St. Louis, MO
mopardamo Offline
mopardamo  Offline
St. Louis, MO
Hello Tripp,
He knew.
Damon
Re: Dissapointing Run w/440 6pk [Re: Triple Threat] #278780
04/06/09 01:05 AM
04/06/09 01:05 AM
Rock Springs
Bob_Coomer Offline
Bob_Coomer  Offline
Rock Springs
Non Believers LOL
Not only did they do it, they did it bragging, and as a advertisement Logo.
"In 1968 with the intro of the Plymouth Road runner, Mopars claim to fame was Speed on a budget, designed to run 100 mph in the 1/4 mile and sell for under $3000".
You probably wouldn't believe this same car with a little work, still carrying stock 906 heads, and Factory fuel system wouldn't run no where near 11.20's in the 1/4 either...
Rapid Transit's Believe it or not
Re: Dissapointing Run w/440 6pk [Re: BLONDE BARRACUDA] #278781
04/06/09 01:17 AM
04/06/09 01:17 AM
Carstairs, Alberta, Canada
dave571 Offline
dave571  Offline
... I do not believe at all that a stock 383 with 354 gears will run 100mph in 1/4. I appreciate your reply
Stock 383's were 15 second cars most days. Well set up with some slicks and gears, and they improved some.
In any case I think you should put a fuel pressure gauge on the six pack car and run it. Also maybe a vacuum gauge. The vacuum gauge may show a valve spring issue, etc.
The times do clearly show that the motor has torque, but not hp.
Re: Dissapointing Run w/440 6pk [Re: dave571] #278782
04/06/09 08:08 AM
04/06/09 08:08 AM
gregsdart Offline
gregsdart  Offline
A lot of the performance had to do with track conditions, like altitude and barometric pressure. Take a stock 383 RR and run it in Minnesota in the heat of the summer, and you are looking at 94 to 96 mph at best. DA would be somewhere around 4500 ft! Take the same car and run it on the east coast or down south in the fall, with a DA of 0 or mineshaft conditions, and guess what? It would pick up tremendously. I had a bone stock 69 440 RT charger, best was 14.92 at 96 mph. More than likely due to a DA north of 3000 ft. The Magazine cars got special treatments like the 440 exhaust (2 1/2 Vs 2 1/4) a re curved distributor, re jetted, so I know for sure there were ringers out there as well. All in all, they carried thier own wieght with the performance crowd very well. Simple little things like removing the spare, airing up the tires, a tweak of the left front torsion bar, a cold thermostat, proper cooldown and you could run another 1/2 tenths quicker than the average Joe out there as well.
What RPM did you shift at? Was the car cooled down well?
Re: Dissapointing Run w/440 6pk [Re: dave571] #278783
04/06/09 09:39 AM
04/06/09 09:39 AM
U.S.S.A.
JohnRR Offline
JohnRR  Offline
U.S.S.A.
maybe with your grandma driving ... ..
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: BLONDE BARRACUDA] #278784
04/06/09 10:46 AM
04/06/09 10:46 AM
Brookeville, Md
Mr.Yuck Offline
Mr.Yuck  Offline
Brookeville, Md
tires spiing only in 1st is a huge problem... For every tenth you save at the 60 you get 2 down track. Your MPH is off too. Did you up the center jetting to 64? I've seen guys run 11's w/ 5/16 line, mech pump and a 6 pack so I'd check things like timing and carbs 1st. I'd disconect the vac advance and set your timing at 38* total at 2400rpm. Then check your vacuum readings, adjust it so you pull the best, set the idle, re-check your total and take it for a romp. I think that back in the day low 14's high 13's were what those cars were pulling on bais plys thru the pipes.
What else did you do? headers? bigger exhaust? mufflers? what are you shifting at? all that makes a difference.
Re: Dissapointed with my run with 69 Roadrunner/440 6pk [Re: BLONDE BARRACUDA] #278785
04/06/09 10:56 AM
04/06/09 10:56 AM
Atlanta Indiana
Dave Watt Offline
Dave Watt  Offline
Atlanta Indiana
If you have original six pack carbs, the kill bleed holes on the outboard carbs could be oversized. We have seen many that were drilled too big and never let the ouboards pull open. Mine were like that and it would only run low 14's, once it was fixed, it would run 13.30's, bone stock with the skinny factory redline tires, 4:10's and a 4-speed.
Page 1 of 3 1 2 3
