Re: Congratulations to Dave Dudek
[Re: dOc !]
#2787595
06/20/20 11:00 PM
06/20/20 11:00 PM
Posts: 3,093 Michigan
A727Tflite
HOW TRICK are those exhaust manifolds ? There is no stone left unturned. Just think the term - “smoke and mirrors”. Basically a BIG SS/AH engine on the inside looking like a street Hemi on the outside.
[Re: A727Tflite]
#2787608
06/20/20 11:41 PM
06/20/20 11:41 PM
Posts: 7,498 Minnesota
Hemi_Joel
Minnesota
The exhaust manifolds are nothing special. Just extrude honed street hemi manifolds. Remember, it all has to go through mufflers and a two and a half inch exhaust system all the way back to the bumper. And the hemi exhaust manifolds are outstanding as built.
[img]http://i.imgur.com/boeexFms.jpg[/img]31 Plymouth Coupe, 392 Hemi, T56 magnum RS23J71 RS27J77 RP23J71 RO23J71 WM21J8A I don't regret the things I've done. I only regret the things I didn't do. "Wise men talk because they have something to say; fools because they have to say something. ~ Plato"
[Re: Hemi_Joel]
#2787611
06/20/20 11:58 PM
06/20/20 11:58 PM
Posts: 20,197 PA.
pittsburghracer
"Little"John
"Little"John
PA.
There is not one cheap or non trick parts involved in these cars. Nothing. Not for the usual cheap azz Mopar racer
[Re: pittsburghracer]
#2787615
06/21/20 12:15 AM
06/21/20 12:15 AM
Posts: 11,686 W. Kentucky
justinp61
W. Kentucky
There is not one cheap or non trick parts involved in these cars. Nothing. Not for the usual cheap azz Mopar racer Deep pockets for sure. It's still way more impressive than a light weight pipe rack.
[Re: DaveRS23]
#2787734
06/21/20 12:15 PM
06/21/20 12:15 PM
Posts: 731 NY
XXHEMI
NY
He beat the Corvette in the final.
Agreed that a lot of money is spent doing this type of racing but the majority of the racers are hard working blue collar guys.
It took me 15 years to figure it out and who knows how much $ but a wedge was not the right motor to work with in F.A.S.T
I have no complaints I still enjoy it very much but I don't think the Max Wedge will ever see 9's. At least not with a 340 lbs driver??
[Re: XXHEMI]
#2787748
06/21/20 12:57 PM
06/21/20 12:57 PM
Hemi_Joel
Minnesota
Ed, have you got a Hemi in the works?
[Re: justinp61]
#2787777
06/21/20 02:15 PM
06/21/20 02:15 PM
Posts: 673 Emmett, Idaho
SuperStockWagon
Emmett, Idaho
[/quote] still way more impressive than a light weight pipe rack. [/quote]
Nailed it! Congrats Dave, proving once again hard work pays off!
NHRA Stock/SuperStock Class Racing..Engineered Muscle In Motion!
[Re: SuperStockWagon]
#2787825
06/21/20 04:09 PM
06/21/20 04:09 PM
Posts: 11,725 Portage,michigan
B3422W5
Portage,michigan
Is the front of the hood supposed to be lifting up that much........
[Re: B3422W5]
#2787899
06/21/20 08:50 PM
06/21/20 08:50 PM
A727Tflite
Is the front of the hood supposed to be lifting up that much........ It’s not lifting up - old school trick to get more fresh air under the hood. Some guys raise the rear part of the hood to let hot air escape too.
[Re: Hemi_Joel]
#2787907
06/21/20 09:09 PM
06/21/20 09:09 PM
Posts: 713 Lake Villa Il
INTMD8
Lake Villa Il
The exhaust manifolds are nothing special. Just extrude honed street hemi manifolds. Remember, it all has to go through mufflers and a two and a half inch exhaust system all the way back to the bumper. And the hemi exhaust manifolds are outstanding as built. I'm surprised. Would have thought extensively hand ported before extrude honing at least. At best I would think cut/weld/blend so the downward break wasn't so extreme. (try to increase radius at top of manifold ports)
[Re: B3422W5]
#2787909
06/21/20 09:18 PM
06/21/20 09:18 PM
Posts: 4,700 Wichita
GY3
Wichita
Is the front of the hood supposed to be lifting up that much........ OG Ram Air.
[Re: INTMD8]
#2787924
06/21/20 10:11 PM
06/21/20 10:11 PM
Hemi_Joel
Minnesota
The exhaust manifolds are nothing special. Just extrude honed street hemi manifolds. Remember, it all has to go through mufflers and a two and a half inch exhaust system all the way back to the bumper. And the hemi exhaust manifolds are outstanding as built. I'm surprised. Would have thought extensively hand ported before extrude honing at least. At best I would think cut/weld/blend so the downward break wasn't so extreme. (try to increase radius at top of manifold ports) I tried that, it didn't help.
[Re: Hemi_Joel]
#2788011
06/22/20 10:04 AM
06/22/20 10:04 AM
Posts: 13,385 Marion, South Carolina [><]
an8sec70cuda
[Re: XXHEMI]
#2788113
06/22/20 02:39 PM
06/22/20 02:39 PM
Posts: 8,779 Mt.Gilead, Ohio
OhioMopar
Mt.Gilead, Ohio
Impressive for sure. Dave's talent, both the engine and the quality of the car, is awesome.
1969 Dart GTS 340 1969 Super Bee X9 N-96 1969 Coronet R/T X9 N-96 2015 Dodge Dart GT 2019 Ram 2500 Big Horn. Looking for the original block for my Bee. The last 4 are 7449
[Re: OhioMopar]
#2788256
06/22/20 09:18 PM
06/22/20 09:18 PM
Posts: 643 southern conn
1969gtx
southern conn
I have no trick as far hood goes it lift a lot @ 120 plus mph Dave going much faster
1965 A/FX Plymouth 9.50 et @139 mph 1965 A/FX awb plymouth flashback [email]10.26@129mph[/email] mph on pump gas 426 hemi 1969 GTX Hemi 4 speed 12.50 et @ 112mph in F.A.S.T TRIM 1970 GTX 4406pac 4 speed 11.05 @126.9 mph in F.A.S.T TRIM http://www.AFXER.com
