93 Octane w/ethanol or 90 Octane non-ethanol #2787362
06/20/20 11:13 AM
06/20/20 11:13 AM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
I have a 9:1 440 in my Charger, I was wondering what gas you guys would run. I guess my choices are 93 (it might even be 92) Sunoco with ethanol, or ethanol-free 90 octane from Fastrac (I am not sure what brand the gas is). It's a street/strip car, it might see track 6-8 times a year or so.
I guess if it doesn't ping, the 90 is fine, right?
Anything else to consider? I obviously would prefer to run the non-ethanol if I can.
Thanks.
Greg
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: GregY] #2787375
06/20/20 11:43 AM
06/20/20 11:43 AM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I switched my Valiant from 93 w/10% ethanol to 91 no e and it liked it a lot. I had to take out some jet, it went rich.
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: GregY] #2787409
06/20/20 01:32 PM
06/20/20 01:32 PM
central il.
second 70 Offline
second 70  Offline
central il.
At 9:1 you can probably run 87 without a problem and it might even run better.
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: second 70] #2787464
06/20/20 04:37 PM
06/20/20 04:37 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
What would be the theory behind this?
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: GregY] #2787533
06/20/20 07:31 PM
06/20/20 07:31 PM
Omaha Ne
TJP Offline
TJP  Offline
Omaha Ne
Ethanol is not friendly with older fuel systems as it will deteriorate rubber diaphragms, hoses, Accel. pumps, has a lower boiling point ( think vapor lock), attracts moisture and several other issues including being less efficient (lower MPG).
back in 1987 or so I was visiting Ne. from Calif. and mistakenly filled up with a 5 or 10% ethanol fuel. The car immediately began to run like cr-p and the mileage dropped a reasonable amount. I ran the tank empty as quickly as i could, refilled with normal unleaded and all was back to normal.
twocents beer
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: TJP] #2787553
06/20/20 08:38 PM
06/20/20 08:38 PM
Central Florida
larrymopar360 Offline
Stud Muffin
Stud Muffin
Central Florida
With the 93 you can go with a little more timing though. I agree, without ethanol would be better on a carburated fuel system, and if you deal with hot weather, hot starts can be a problem sometimes.
Maybe the 93 with an ethanol conditioner
Facts are stubborn things.
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: larrymopar360] #2787562
06/20/20 08:58 PM
06/20/20 08:58 PM
nowhere
Sniper Offline
Sniper  Offline
nowhere
And yet my 51 Cambridge runs just fine on E10.
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: GregY] #2787568
06/20/20 09:11 PM
06/20/20 09:11 PM
Someplace you aren't
SomeCarGuy Offline
SomeCarGuy  Offline
More power potential/btu in 87. 93 is harder to burn, which is why you need it with higher compression. Control when the burn happens that way so less likely to detonate. You can get into quench and how the lame smogger 440s don’t have it, but your 9 to 1 should be ok. That’s a whole nother discussion though.
I want my fair share
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: SomeCarGuy] #2787801
06/21/20 02:45 PM
06/21/20 02:45 PM
central il.
second 70 Offline
second 70  Offline
central il.
Man you explained that a lot clearer than I would have. Thanks Mike
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: TJP] #2787837
06/21/20 05:22 PM
06/21/20 05:22 PM
upstate western ny
sogtx Offline
sogtx  Offline
upstate western ny
6-8 times a year
Get that junk outta the garage ! 😁
If thats case run 90 that you czn get at speedway rite around corner From your house
And i blend with 110 . Do you ping when u hammer on it ?
Wheres the timing ?
All my gaskets and hose are modern rated for ethanol , but who knows
Mine slurps 93 $20 bucks a weekend in summer . .
In october i def switch to 90 and blend .
Needles seats stay happier , but even then theyve choked in spring before.
Look at your bowls for residue regardless in April .
You cSn buy race gas on basket rd at BERG
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: sogtx] #2787860
06/21/20 06:40 PM
06/21/20 06:40 PM
Rochester, New York
GregY Offline OP
GregY  Offline OP
Rochester, New York
Hi Andy,
I was all set to go on opening day for the first time in a decade, then COVID came along. I am hoping for at least once a month from now through September, that'd be 4 times anyway! Thanks for calling me out on it, ha ha. It's a miracle my junk runs at all.
I sent you a PM.
Greg
Re: 93 Octane w/ethanol or 90 Octane non-ethanol [Re: GregY] #2787890
06/21/20 08:11 PM
06/21/20 08:11 PM
SomeCarGuy Offline
SomeCarGuy  Offline
If the ethanol crap is easier to get and it runs ok, you could get by running Stabil 360. Use every fill up or two, get a new bottle every two years. Works for me. My stuff has been trouble free, the guy next door refuses to listen each year when I explain to him why his stuff is fubar and how he can stop it.
