Re: 93 Octane w/ethanol or 90 Octane non-ethanol
[Re: GregY]
#2787375
06/20/20 11:43 AM
06/20/20 11:43 AM
Posts: 20,203 Park Forest, IL
slantzilla
Park Forest, IL
I switched my Valiant from 93 w/10% ethanol to 91 no e and it liked it a lot. I had to take out some jet, it went rich.
[Re: second 70]
#2787464
06/20/20 04:37 PM
06/20/20 04:37 PM
Posts: 1,200 Rochester, New York
GregY
Rochester, New York
At 9:1 you can probably run 87 without a problem and it might even run better. What would be the theory behind this?
[Re: TJP]
#2787553
06/20/20 08:38 PM
06/20/20 08:38 PM
Posts: 15,926 Central Florida
larrymopar360
Stud Muffin
Stud Muffin
Central Florida
With the 93 you can go with a little more timing though. I agree, without ethanol would be better on a carburated fuel system, and if you deal with hot weather, hot starts can be a problem sometimes.
Maybe the 93 with an ethanol conditioner
Facts are stubborn things.
[Re: GregY]
#2787568
06/20/20 09:11 PM
06/20/20 09:11 PM
Posts: 10,226 Someplace you aren't
SomeCarGuy
At 9:1 you can probably run 87 without a problem and it might even run better. What would be the theory behind this? More power potential/btu in 87. 93 is harder to burn, which is why you need it with higher compression. Control when the burn happens that way so less likely to detonate. You can get into quench and how the lame smogger 440s don’t have it, but your 9 to 1 should be ok. That’s a whole nother discussion though.
I want my fair share
[Re: TJP]
#2787837
06/21/20 05:22 PM
06/21/20 05:22 PM
Posts: 5,180 upstate western ny
sogtx
upstate western ny
6-8 times a year Get that junk outta the garage ! 😁 If thats case run 90 that you czn get at speedway rite around corner From your house And i blend with 110 . Do you ping when u hammer on it ? Wheres the timing ?
All my gaskets and hose are modern rated for ethanol , but who knows Mine slurps 93 $20 bucks a weekend in summer . . In october i def switch to 90 and blend . Needles seats stay happier , but even then theyve choked in spring before.
Look at your bowls for residue regardless in April .
You cSn buy race gas on basket rd at BERG
[Re: GregY]
#2787890
06/21/20 08:11 PM
06/21/20 08:11 PM
SomeCarGuy
If the ethanol crap is easier to get and it runs ok, you could get by running Stabil 360. Use every fill up or two, get a new bottle every two years. Works for me. My stuff has been trouble free, the guy next door refuses to listen each year when I explain to him why his stuff is fubar and how he can stop it.
