Re: TH400 to RB in 69 b body info
[Re: The Shadow]
#2786119
06/16/20 07:40 PM
06/16/20 07:40 PM
Posts: 4,489 northern,Ohio,USA
Clanton
northern,Ohio,USA
I take it your going carbon fiber since the chart doesnt go to the length you want? Nooo!lol That leaves 2 other options ms and aluminum
[Re: The Shadow]
#2786145
06/16/20 08:53 PM
06/16/20 08:53 PM
Clanton
northern,Ohio,USA
I take it your going carbon fiber since the chart doesnt go to the length you want? in this link an aluminum 4" can take 2k hp and this is what Mark williams wanted to sell me 1st at my length so at 1/2 the $ of cf this works for me even with shipping 50$ maybe. aluminum ds spec from the link"Description 3.5″ Shaft with, 1350 Series “Gold” Cryo treated Solid U-joints, are built under the most Stringent Tolerances in the industry. Tubing is Factory Straightened to .010″ total runout at the center of the tube. Tube yokes are welded to within .006″ runout on each end. The shafts are Electronically Computer Balanced to less than 1/8 Oz/Inch, as an assembly, assuring smooth operation at the Big end as well out of the hole. Critical Speed is calculated on each shaft to insure your Safety and Ultimate Shaft longevity. We recommend the 3.5″ shaft in most cases to 1000 Horse Power. 4″ Shafts are recommended to 2000 Horse Power. Shafts are complete with the most common standard transmission Slip Yokes. In some cases an upgrade on the Slip Yoke or U- joints may be considered."
[Re: Clanton]
#2786182
06/16/20 11:13 PM
06/16/20 11:13 PM
Posts: 43,284 Bend,OR USA
Cab_Burge
How about chromemoly DOM 3.5 tubes?
[Re: Cab_Burge]
#2786223
06/17/20 07:10 AM
06/17/20 07:10 AM
Clanton
northern,Ohio,USA
How about chromemoly DOM 3.5 tubes? In the chart the rpm limit is much lower for cm.My driveshaft speed would be 6300 I think at 140 mph.I have some hard choices to make here it looks like so I need to revisit the data
[Re: Clanton]
#2786233
06/17/20 08:07 AM
06/17/20 08:07 AM
Clanton
northern,Ohio,USA
So I would have a ds speed of 6266 with a mph 140 and a 28" tire and 5848 with a tire of 30" so with a 30" tire I think a aluminum 59" shaft is doable.Or even a 4" mild steel
[Re: The Shadow]
#2786589
06/17/20 08:44 PM
06/17/20 08:44 PM
Clanton
northern,Ohio,USA
Did you use this calculation for the ds speed? Top speed x 336 (a constant) x rear ratio (like 4.10), then divide it by the tire height (28” tall tire) It doesnt look like it yes I did w 3.73 gear so 140 mph 3.73, 30" tire
[Re: Clanton]
#2798290
07/18/20 12:53 PM
07/18/20 12:53 PM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Are you going to put the blower back on it for the street duty?
[Re: fast68plymouth]
#2798315
07/18/20 01:39 PM
07/18/20 01:39 PM
Clanton
northern,Ohio,USA
Are you going to put the blower back on it for the street duty? yes!Low boost 5 to 8 lbs and that would be 3 or 5%OD
[Re: Clanton]
#2802145
07/28/20 02:24 PM
07/28/20 02:24 PM
Clanton
northern,Ohio,USA
some update pics.I had to put a friend in his final resting place so getting to work on this was slow.Lokar dipstick fits nice.The vert went in clean. 1.22 to the mount pads, .900 to the pilot from the bell face.I need to measure the pad to fp gap yet and pull the vert to the fp.Now I will be steady at work on it.ty for reading.
[Re: Clanton]
#2802291
07/28/20 08:20 PM
07/28/20 08:20 PM
Posts: 2,469 Sydney,Australia
tex013
Sydney,Australia
sorry for your loss .
looking at the filler , could you have dented the floor away a little and run a solid tube ? lots of hard work youve covered thanks
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: tex013]
#2802296
07/28/20 08:45 PM
07/28/20 08:45 PM
Clanton
northern,Ohio,USA
Tex I think you could make a solid tube work but why dent the floor when you can form the tube?.My Lokar is about 34" long
[Re: tex013]
#2802300
07/28/20 08:56 PM
07/28/20 08:56 PM
Clanton
northern,Ohio,USA
thanks
Tex Thank you for your sympathy for Cpl E-4 USMC Brian King
