Page 8 of 10 1 2 6 7 8 9 10
Re: TH400 to RB in 69 b body info [Re: Clanton] #2786092
06/16/20 05:35 PM
06/16/20 05:35 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
I take it your going carbon fiber since the chart doesnt go to the length you want?
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2786119
06/16/20 07:40 PM
06/16/20 07:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Nooo!lol That leaves 2 other options ms and aluminum
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2786145
06/16/20 08:53 PM
06/16/20 08:53 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
in this link an aluminum 4" can take 2k hp and this is what Mark williams wanted to sell me 1st at my length so at 1/2 the $ of cf this works for me even with shipping 50$ maybe. aluminum ds spec from the link"Description
3.5″ Shaft with, 1350 Series “Gold” Cryo treated Solid U-joints, are built under the most Stringent Tolerances in the industry. Tubing is Factory Straightened to .010″ total runout at the center of the tube. Tube yokes are welded to within .006″ runout on each end. The shafts are Electronically Computer Balanced to less than 1/8 Oz/Inch, as an assembly, assuring smooth operation at the Big end as well out of the hole.
Critical Speed is calculated on each shaft to insure your Safety and Ultimate Shaft longevity. We recommend the 3.5″ shaft in most cases to 1000 Horse Power. 4″ Shafts are recommended to 2000 Horse Power.
Shafts are complete with the most common standard transmission Slip Yokes. In some cases an upgrade on the Slip Yoke or U- joints may be considered."
Re: TH400 to RB in 69 b body info [Re: Clanton] #2786182
06/16/20 11:13 PM
06/16/20 11:13 PM
Cab_Burge Online work
Cab_Burge  Online Work
How about chromemoly DOM 3.5 tubes?
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2786223
06/17/20 07:10 AM
06/17/20 07:10 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
In the chart the rpm limit is much lower for cm.My driveshaft speed would be 6300 I think at 140 mph.I have some hard choices to make here it looks like so I need to revisit the data
Re: TH400 to RB in 69 b body info [Re: Clanton] #2786233
06/17/20 08:07 AM
06/17/20 08:07 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
So I would have a ds speed of 6266 with a mph 140 and a 28" tire and 5848 with a tire of 30" so with a 30" tire I think a aluminum 59" shaft is doable.Or even a 4" mild steel
Re: TH400 to RB in 69 b body info [Re: Clanton] #2786488
06/17/20 05:35 PM
06/17/20 05:35 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Did you use this calculation for the ds speed?
Top speed x 336 (a constant) x rear ratio (like 4.10), then divide it by the tire height (28” tall tire)
It doesnt look like it
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2786589
06/17/20 08:44 PM
06/17/20 08:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
yes I did w 3.73 gear so 140 mph 3.73, 30" tire
Re: TH400 to RB in 69 b body info [Re: Clanton] #2793902
07/07/20 01:40 PM
07/07/20 01:40 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I got the driveshaft today so just waiting on the PTC 4500 stall 9.5: vert.The ds clears thew hoop plenty and the ds was 663$.I am also waiting on the shifter sideplates to go to a th400 and it should be here today or tomorrow.I will sell the 727 sideplates.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2798214
07/18/20 10:00 AM
07/18/20 10:00 AM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I will be getting my 9.5" vert from PTC today to complete what I need to get running again so I will be back to work for a few weeks on the car.I don't expect to get to the track this yr but will run on the street to test the carb jetting that have been sitting on the blower for 3yrs or so.I will post a video I hope when I drive it.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2798290
07/18/20 12:53 PM
07/18/20 12:53 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
Are you going to put the blower back on it for the street duty?
Re: TH400 to RB in 69 b body info [Re: fast68plymouth] #2798315
07/18/20 01:39 PM
07/18/20 01:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
yes!Low boost 5 to 8 lbs and that would be 3 or 5%OD
Re: TH400 to RB in 69 b body info [Re: Clanton] #2798324
07/18/20 02:00 PM
07/18/20 02:00 PM
So. Burlington, Vt.
So. Burlington, Vt.
Looking forward to when you finally get it back to the track up
Re: TH400 to RB in 69 b body info [Re: fast68plymouth] #2798374
07/18/20 04:00 PM
07/18/20 04:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you Me too!There is no good in having a blower if you can't use it.I will not use the intercooler for now also but when I get to the track I should have it in and plumbed.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2798620
07/19/20 02:49 PM
07/19/20 02:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Just some GM style converter picsI measured the pilot fo fit the flexplate adapter 1.702 pilot and 1.704 adaptor hole.I need to put the fplate agains the vert to check the bolt holes.I got 3 bolts,nuts in the box with the vert.[7/16" maybe]I will check the crank bolt to fplate gap also.When I unbolt the trans I will check the installed ht in the bell
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802145
07/28/20 02:24 PM
07/28/20 02:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
some update pics.I had to put a friend in his final resting place so getting to work on this was slow.Lokar dipstick fits nice.The vert went in clean. 1.22 to the mount pads, .900 to the pilot from the bell face.I need to measure the pad to fp gap yet and pull the vert to the fp.Now I will be steady at work on it.ty for reading.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802291
07/28/20 08:20 PM
07/28/20 08:20 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
sorry for your loss .
looking at the filler , could you have dented the floor away a little and run a solid tube ?
lots of hard work youve covered thanks
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: TH400 to RB in 69 b body info [Re: tex013] #2802296
07/28/20 08:45 PM
07/28/20 08:45 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Tex
I think you could make a solid tube work but why dent the floor when you can form the tube?.My Lokar is about 34" long
Re: TH400 to RB in 69 b body info [Re: tex013] #2802300
07/28/20 08:56 PM
07/28/20 08:56 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
thanks
Tex
Thank you for your sympathy for Cpl E-4 USMC Brian King
Re: TH400 to RB in 69 b body info [Re: Clanton] #2802303
07/28/20 09:02 PM
07/28/20 09:02 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Condolences on your loss.
