Re: Unibody Front End Lift
[Re: BPBP440]
#2786249
06/17/20 09:06 AM
06/17/20 09:06 AM
Posts: 12,253 Benton, IL.
DaveRS23
Special needs idiot
Special needs idiot
Benton, IL.
Bolt a couple of pieces of angle iron onto the bumper bracket holes like the Car Tool piece does. But instead of a metal spreader, use a 2x4 and pull from the ends of the angle iron with a chain. That way all you need is a drill and bit for a few well placed holes.
I know that will work because I have done it myself.
Master, again and still
[Re: DaveRS23]
#2786267
06/17/20 09:25 AM
06/17/20 09:25 AM
Posts: 264 Farmington Hills, MI
BPBP440
I know that will work because I have done it myself. Thanks Gavin
[Re: DaveRS23]
#2786268
06/17/20 09:26 AM
06/17/20 09:26 AM
BPBP440
I know that will work because I have done it myself. Sounds great. Thanks Dave.
[Re: AndyF]
#2787204
06/19/20 06:54 PM
06/19/20 06:54 PM
Posts: 203 Alabama
David1971
Alabama
I picked the front of the car up using the motor plate tabs that are welded to the front frame rails.
AndyF, I like your idea. Looks like you have the chain suspended from your ceiling. How high of a ceiling do you have in your shop/garage? Looks like you have plenty of clearance. David
[Re: David1971]
#2787210
06/19/20 07:22 PM
06/19/20 07:22 PM
Posts: 31,074 Oregon
AndyF
AndyF, I like your idea. Looks like you have the chain suspended from your ceiling. How high of a ceiling do you have in your shop/garage? Looks like you have plenty of clearance. David Not the ceiling, I used the bridge crane in my shop to pick up the front of the car.
