Unibody Front End Lift #2786155
06/16/20 09:27 PM
06/16/20 09:27 PM
Farmington Hills, MI
BPBP440 Offline OP
BPBP440  Offline OP
I want to purchase the Front End Lifting Tool from US Car Tool, but all out of stock from them directly. Anyone know where I might be able to located one?
http://store.uscartool.com/uni-lift-unibody-front-end-lifting-tool.html
Any thoughts on achieving the same result in another manner (I don't have a vehicle lift)?
Re: Unibody Front End Lift [Re: BPBP440] #2786169
06/16/20 10:30 PM
06/16/20 10:30 PM
Utah and Alaska
astjp2 Offline
astjp2  Offline
Utah and Alaska
Can you weld?
1941 Taylorcraft
1968 Charger
1994 Wrangler
1998 Wrangler
2008 Kia Rio
2017 Jetta
Re: Unibody Front End Lift [Re: astjp2] #2786174
06/16/20 10:55 PM
06/16/20 10:55 PM
BPBP440 Offline OP
BPBP440  Offline OP
Originally Posted by astjp2
Can you weld?
Not confidently enough for this procedure. I do know people that weld for a living, so that is an option.
Re: Unibody Front End Lift [Re: BPBP440] #2786187
06/16/20 11:24 PM
06/16/20 11:24 PM
CA
crackedback Offline
crackedback  Offline
CA
No welder required
get some thick angle iron, drill some holes, square tube to bridge across for lift point...
Re: Unibody Front End Lift [Re: crackedback] #2786197
06/17/20 12:09 AM
06/17/20 12:09 AM
BPBP440 Offline OP
BPBP440  Offline OP
Yeah, that looks straight forward enough!
Re: Unibody Front End Lift [Re: BPBP440] #2786199
06/17/20 12:19 AM
06/17/20 12:19 AM
AndyF Online content
AndyF  Online Content
I picked the front of the car up using the motor plate tabs that are welded to the front frame rails.
Re: Unibody Front End Lift [Re: AndyF] #2786236
06/17/20 08:14 AM
06/17/20 08:14 AM
London, England
Gavin Offline
Gavin  Offline
London, England
Or if you have the bumper brackets use them and just bolt a piece of angle iron to them and lift using that - that's how I did my Challenger, in fact I only used 2 of the bumper bracket holes (one on each side) and it was no problem at all
Re: Unibody Front End Lift [Re: BPBP440] #2786249
06/17/20 09:06 AM
06/17/20 09:06 AM
Benton, IL.
DaveRS23 Offline
Special needs idiot
DaveRS23  Offline
Special needs idiot
Benton, IL.
Bolt a couple of pieces of angle iron onto the bumper bracket holes like the Car Tool piece does. But instead of a metal spreader, use a 2x4 and pull from the ends of the angle iron with a chain. That way all you need is a drill and bit for a few well placed holes.
I know that will work because I have done it myself.
Master, again and still
Re: Unibody Front End Lift [Re: DaveRS23] #2786260
06/17/20 09:20 AM
06/17/20 09:20 AM
Iowa
burdar Offline
Owen's Dad
burdar  Offline
Owen's Dad
Iowa
Use 1/4" angle. I used 1/8" at first but it flexed when moving the front end around with the engine installed. 1/8" was fine when lifting just the body.
Re: Unibody Front End Lift [Re: DaveRS23] #2786267
06/17/20 09:25 AM
06/17/20 09:25 AM
BPBP440 Offline OP
BPBP440  Offline OP
Thanks Gavin
Re: Unibody Front End Lift [Re: DaveRS23] #2786268
06/17/20 09:26 AM
06/17/20 09:26 AM
BPBP440 Offline OP
BPBP440  Offline OP
Sounds great. Thanks Dave.
Re: Unibody Front End Lift [Re: burdar] #2786270
06/17/20 09:26 AM
06/17/20 09:26 AM
BPBP440 Offline OP
BPBP440  Offline OP
Thanks, will use 1/4" to be safe.
Re: Unibody Front End Lift [Re: AndyF] #2787204
06/19/20 06:54 PM
06/19/20 06:54 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
AndyF, I like your idea. Looks like you have the chain suspended from your ceiling. How high of a ceiling do you have in your shop/garage? Looks like you have plenty of clearance.
David
Re: Unibody Front End Lift [Re: David1971] #2787210
06/19/20 07:22 PM
06/19/20 07:22 PM
David
Not the ceiling, I used the bridge crane in my shop to pick up the front of the car.
Re: Unibody Front End Lift [Re: AndyF] #2787283
06/19/20 11:12 PM
06/19/20 11:12 PM
Alabama
David1971 Offline
David1971  Offline
Alabama
Wow, what a set-up! I apologize for straying off subject on this thread. But what all do use the the bridge crane for during repair and restoration of your cars?
Re: Unibody Front End Lift [Re: BPBP440] #2787344
06/20/20 10:02 AM
06/20/20 10:02 AM
None
71rm23 Offline
71rm23  Offline
None
There is so many ways this can be done and what has been posted already are some. We don't know what kind of facility you're working in or have to your disposal. The main thing is to do it SAFE. Here is what I did and worked too.
