A833 insight #2783898
06/10/20 09:36 PM
06/10/20 09:36 PM
Mentor, OH
doggs330 Offline OP
doggs330  Offline OP
Mentor, OH
My project 82 D150 is starting to go back together. I'm wondering if I need to have this A833 that came in the truck gone through before re-installation. Just seeing the pictures, can anyone comfortably say that it can be run as is? There is bits of rtv inside the case and sealing the tailshaft so I assume someone has been inside already. My main worry is the the countershaft and if it needs to be bushed to prevent failure during street driving.
I do not plan on racing this truck just yet so it will have a 360 magnum with the 3:55 8.25 and street tires for now. I have been reading through Jamie's book to learn more about the trans but still not sure on taking it apart myself. Brewers is only a few hours away if a rebuild is required.
Re: A833 insight [Re: doggs330] #2783899
06/10/20 09:39 PM
06/10/20 09:39 PM
Looks okay to me, I have one like that I will sell if you want a spare, new seals and bearings and inspected in good shape like yours also up.
Re: A833 insight [Re: Cab_Burge] #2784944
06/13/20 01:04 PM
06/13/20 01:04 PM
Mentor, OH
doggs330 Offline OP
doggs330  Offline OP
Mentor, OH
Good to hear. Thanks for the offer but if/when this one lets go, it will most likely be replaced with something stronger. The 4.10 dana is almost complete and a gen III Hemi is in the future plans.
Re: A833 insight [Re: doggs330] #2785176
06/13/20 10:20 PM
06/13/20 10:20 PM
VA
dragon slayer Offline
VA
Is there any excess play in the countershaft cluster? Is the clearance ok? As long as the countershaft has not enlarged the holes and the thrust washers are not worn, you are probably ok.
Re: A833 insight [Re: dragon slayer] #2785683
06/15/20 12:31 PM
06/15/20 12:31 PM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
From looking at the pictures, it looks like you have the wrong brass in there. The brass is from a '69 and back, but the synchronizer drum looks like that from a '70 and up transmission?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A833 insight [Re: 68LAR] #2785948
06/16/20 09:58 AM
06/16/20 09:58 AM
South Park, Pa.
68LAR Offline
68LAR  Offline
South Park, Pa.
Sorry, I'm wrong!
Re: A833 insight [Re: doggs330] #2786025
06/16/20 01:50 PM
06/16/20 01:50 PM
Mass.
8
80fbody Offline
80fbody  Offline
Mass.
Freshen it up while it's out. It's a good little project and pretty simple. Get a good kit from Brewers and a book.
Re: A833 insight [Re: dragon slayer] #2786474
06/17/20 04:58 PM
06/17/20 04:58 PM
Mentor, OH
doggs330 Offline OP
doggs330  Offline OP
Mentor, OH
Doesn't appear to be any play that I would call excessive. I wasn't planning on disassembling if it is not necessary. Everything visible through the sidecover looks alright to my untrained eyes. Another member that is local offered to give it a closer look. Thank you for the input.
That is probably what I will end up doing. The plan was to just drive this truck but with two dead cylinders and floorpans taking six months to ship, it has snowballed into the "while it's apart" deals. I do have the book. Thanks.
Re: A833 insight [Re: doggs330] #2786495
06/17/20 05:42 PM
06/17/20 05:42 PM
northeast ohio
hulmule Offline
hulmule  Offline
northeast ohio
What book are you all talking about? Need to pick one up , want to go thru one for son's cuda. Where did you buy? Good details ?? thx If you want help doing yours if you live in Eastlake i'm near chardon, would give a hand to learn.
1969 Dodge Coronet R/T Convertible
1979 LiL Red x2
2012 Yellow Jacket
2006 mega cab
1977 Trailduster
1979 Trailduster
Re: A833 insight [Re: hulmule] #2786612
06/17/20 09:53 PM
06/17/20 09:53 PM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Jamie Passon has written a book about Mopar 4-speeds available on his website up
Gus beer
64 Plymouth Savoy
Dana 60
