440 intake curiousity
#2785712
06/15/20 01:29 PM
06/15/20 01:29 PM
Posts: 10,228 Colleyville
3hundred
Colleyville
Years ago I had a CH4B that had the center divider cut down about 1" from the carb flange. Was wondering on a stock 440 what would be the effect of cutting down that divider about 1" ?
'68 Fury Convertible '69 300 Convertible '15 Durango 5.7 Hemi '16 300 S Hemi
Re: 440 intake curiousity
[Re: AndyF]
#2785749
06/15/20 03:06 PM
06/15/20 03:06 PM
3hundred
Colleyville
You probably won't be able to notice the difference Okay, backstory, I was told the modded CH4B was on a 505 stroker w/ a 750 CFM carb. Supposedly the mod was to make the engine perceive the carburetor was bigger? I've been toying with the long term idea (probably never happen) of a sniper fuel system thinking the mod would eliminate the dual plane problem with FI. In the meantime I was just curious what it would do with the stock carburetor.
[Re: 3hundred]
#2785754
06/15/20 03:21 PM
06/15/20 03:21 PM
Posts: 14,496 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
Only one way to know for sure exactly what it would do on your combo.
The good news is, if for some reason it’s not to your liking....... it’s not that hard or expensive to find a replacement.
[Re: 3hundred]
#2785863
06/15/20 09:56 PM
06/15/20 09:56 PM
Posts: 4,206 New York
polyspheric
New York
A 1" open spacer (if it fits your hood, linkage, fuel line, etc.) has a similar effect. Expect: 1. idle quality suffers slightly, idle vacuum lower 2. response may need more pump shot 3. mileage may go either way 4. peak power increased slightly (most if plenum and/or carb is small) 5. cylinder to cylinder distribution may get worse (on a well-developed manifold)
Boffin Emeritus
