Original fuel pump 1969 383 #2785605
06/15/20 09:17 AM
06/15/20 09:17 AM
Hinckley, Ohio
KWF340 Offline OP
KWF340  Offline OP
Hinckley, Ohio
Did the factory-original fuel pump on a 1969 383 magnum have one nipple (for connecting to the tank) and a flare connector for (connecting to the fuel filter) or two nipples? The '69 parts book calls for 2932799 pump for both the 383 and 440 and a search primarily shows pumps with two nipples. The fuel line I purchased from inline tube has a flare fitting at the connection to the pump and leading to the filter. Which is correct?
1968 Charger R/T, 440 Auto, GG1;
1969 Super Bee, 383, 4-speed, T5;
1969.5 Road Runner, 440-6, 4-speed, 96;
1970 Duster 340, 4-speed, EV2;
1970 Charger R/T SE, 440 (496), Auto, EB3;
1970 Dart Swinger 340 (416), 4-speed, EV2;
1970 Corvette coupe, LS5, 4-speed, Daytona yellow;
2000 Corvette coupe, LS1, 6-speed, Twin Turbo, Torch red.
Re: Original fuel pump 1969 383 [Re: KWF340] #2785613
06/15/20 09:48 AM
06/15/20 09:48 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
Inverted flare at output end (to carb).
There's a short tube with a pretty wild couple of bends that connects there.
Re: Original fuel pump 1969 383 [Re: topside] #2785837
06/15/20 07:52 PM
06/15/20 07:52 PM
Hinckley, Ohio
KWF340 Offline OP
KWF340  Offline OP
Hinckley, Ohio
Thank you!
