Re: Where to put my Dart into the 12’s
[Re: Mr.Yuck]
#2786033
06/16/20 02:16 PM
06/16/20 02:16 PM
Posts: 4,732 Watertown, WI
MikeyT
Watertown, WI
Ok, will do!! I am going to try and thrash it a little this Saturday and see how it goes.
Thanks for the tips
Mike
1969 Dodge Dart Swinger
[Re: sixpakdodge]
#2786130
06/16/20 08:06 PM
06/16/20 08:06 PM
Posts: 4,318 Prospect, PA
BSB67
Prospect, PA
You should check your timing with a piston stop as well as your carb opening fully. With what you have at that weight you should be going at least 106 MPH, are you running at a track much higher than sea level. This. Something is amiss here, as that car should be running better than what you're posting as is. Would be very curious to know what the air conditions were that day as well. I'd spend a good weekend going over the car, and fine tuning what you have, before I started throwing money at it. Double this. It's probably fair to assume that it does not have 10:1 compression ratio, as no piston exists to give that, unless someone worked pretty hard at it, and used 915 heads. Up in Wisconsin, so the DA was probably not too bad. If he's shifting a 383 at 5300 rpm, he's probably leaving a bunch of HP/mph on the table.
[Re: BSB67]
#2786271
06/17/20 09:27 AM
06/17/20 09:27 AM
Posts: 14,513 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
If he's shifting a 383 at 5300 rpm, he's probably leaving a bunch of HP/mph on the table. Then again....... it could have a fast rate hyd cam in it, and isn’t very happy at anything much over that rpm. But I’m sure a few runs down the track would answer that question.
[Re: fast68plymouth]
#2786358
06/17/20 12:43 PM
06/17/20 12:43 PM
MikeyT
Watertown, WI
Yeah, I always enjoy these discussion. I find I learn a lot. The big one is more seat time. I plan on trying to run it this weekend and vary the shift points. It will probably be helpful to save the time slips so we can analysis it. Anyway rain in the forecast Friday thru Sunday with a nice balmy 87. My hope is stuff won’t get wet until afternoon on Saturday and I sneak down to union grove in the morning.
[Re: MikeyT]
#2786446
06/17/20 03:14 PM
06/17/20 03:14 PM
fast68plymouth
So. Burlington, Vt.
With the mild gearing, you should be able to spend enough time in each of the lower gears to be able to determine if/where it’s starting to lay down...... or if it will easily rev high enough to reach or exceed the optimal shift point.
I find 2nd gear is usually the easiest for me to tell when it’s either flattening out, or nosing over.
[Re: MikeyT]
#2786452
06/17/20 03:48 PM
06/17/20 03:48 PM
Posts: 1,271 Vista, California
67Satty
Vista, California
😂. I know this will sound awful but Dart is 3400 with my fat butt. DA.... 🤔. It was sunny!!
So let’s say I go with a nice head upgrade and like comp xl274 cam, or custom grind from Dwayne , am I restricted too Stealth heads or can I go with an eddy or sidewinder head..? The angled plugs give me pause.. This thing has a lot less engine bay then my previous B bodies.
Mike . The 84cc Edelbrock E Street heads have straight plugs and flow more than the Stealths for about the same price when all is said and done.
