Auto vs. Manual cross member #2785266
06/14/20 09:27 AM
06/14/20 09:27 AM
A727Tflite Offline OP
Can anyone post a side by side pic of an auto vs. manual trans cross member for a 69 B Body showing the difference?
Re: Auto vs. Manual cross member [Re: A727Tflite] #2785286
06/14/20 10:29 AM
06/14/20 10:29 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
This was a very long time ago but I remember changing a 1967 Plymouth Hemi car from a four speed to an automatic and I thought we used the same cross member and rear motor mount.
This was in the late sixties so no guarantees on my memory!
Re: Auto vs. Manual cross member [Re: A727Tflite] #2785301
06/14/20 10:59 AM
06/14/20 10:59 AM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
Here you go Lou... Auto top/4spd bottom, .....if need be you can convert the auto crossmember to 4 speed use with a little surgery if that's the case?
mike
Re: Auto vs. Manual cross member [Re: DAYCLONA] #2785439
06/14/20 04:18 PM
06/14/20 04:18 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
Can you show the auto and 4speed cross members for a 66,67, 68 Cbody Thanks.
Re: Auto vs. Manual cross member [Re: MO_PA] #2785463
06/14/20 05:37 PM
06/14/20 05:37 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
I believe only B Body differentiates between auto and 4 speed in those years Auto and 3 speed manual are the same for all. So C body 4 speed and auto and 3 speed manual are all the same.
Re: Auto vs. Manual cross member [Re: A727Tflite] #2785470
06/14/20 06:05 PM
06/14/20 06:05 PM
New York
R/T1968R/T Offline
R/T1968R/T  Offline
New York
I used an auto cross member in a 69 with a 4 speed, but the box had the later tail shaft. No mods needed
Re: Auto vs. Manual cross member [Re: R/T1968R/T] #2785478
06/14/20 06:48 PM
06/14/20 06:48 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
So, the mount in the cross member is about 4 inches behind where it bolts to the trans. ? I'm working on my first, factory 440, 4speed CBody
Re: Auto vs. Manual cross member [Re: MO_PA] #2785494
06/14/20 07:22 PM
06/14/20 07:22 PM
Morrow, OH
markz528 Offline
markz528  Offline
Morrow, OH
The crossmember is the same but the insulators are different. I don't know about 66-68, but my 65 C Body also uses the same crossmember for auto and 4 speed (but it is a one year only crossmember) and the insulator is quite wide. One application faces towards the rear and the other faces toward the front - don't remember which way the auto faces versus the 4 speed. The insulators are different because the angle must be reversed otherwise in 65 they look identical.
Re: Auto vs. Manual cross member [Re: markz528] #2785569
06/15/20 12:58 AM
06/15/20 12:58 AM
New York, USA
Chargerfan68 Offline
New York, USA
My 68 charger r/t 4 speed and 68 r/t auto cross members are different, exactly like in the pics above. The 4speed one does not protrude out like the auto. Just a folded lip. This is for 68.
Re: Auto vs. Manual cross member [Re: DAYCLONA] #2785672
06/15/20 12:17 PM
06/15/20 12:17 PM
Stoney Creek, Ontario, Canada
76Beeper Offline
76Beeper  Offline
mike
Mike,
Can you show the auto and 4speed cross members for a 1971 B-body?
Thanks.
Re: Auto vs. Manual cross member [Re: 76Beeper] #2785678
06/15/20 12:25 PM
06/15/20 12:25 PM
Mass
DAYCLONA Offline
DAYCLONA  Offline
Mass
mike
Mike,
Thanks.
Sorry no pics, but IIRC the 71-2 B body uses the same crossmember auto or 4spd, much like the 70-4 E body does
Mike
