Re: Auto vs. Manual cross member
[Re: MO_PA]
#2785463
06/14/20 05:37 PM
06/14/20 05:37 PM
Posts: 4,267 Morrow, OH
markz528
Morrow, OH
Can you show the auto and 4speed cross members for a 66,67, 68 Cbody Thanks. I believe only B Body differentiates between auto and 4 speed in those years Auto and 3 speed manual are the same for all. So C body 4 speed and auto and 3 speed manual are all the same.
[Re: MO_PA]
#2785494
06/14/20 07:22 PM
06/14/20 07:22 PM
markz528
Morrow, OH
The crossmember is the same but the insulators are different. I don't know about 66-68, but my 65 C Body also uses the same crossmember for auto and 4 speed (but it is a one year only crossmember) and the insulator is quite wide. One application faces towards the rear and the other faces toward the front - don't remember which way the auto faces versus the 4 speed. The insulators are different because the angle must be reversed otherwise in 65 they look identical.
[Re: markz528]
#2785569
06/15/20 12:58 AM
06/15/20 12:58 AM
Posts: 1,262 New York, USA
Chargerfan68
New York, USA
My 68 charger r/t 4 speed and 68 r/t auto cross members are different, exactly like in the pics above. The 4speed one does not protrude out like the auto. Just a folded lip. This is for 68.
[Re: DAYCLONA]
#2785672
06/15/20 12:17 PM
06/15/20 12:17 PM
Posts: 352 Stoney Creek, Ontario, Canada
76Beeper
Here you go Lou... Auto top/4spd bottom, .....if need be you can convert the auto crossmember to 4 speed use with a little surgery if that's the case?
mike Mike, Can you show the auto and 4speed cross members for a 1971 B-body? Thanks.
[Re: 76Beeper]
#2785678
06/15/20 12:25 PM
06/15/20 12:25 PM
Posts: 18,153 Mass
DAYCLONA
Mass
mike Mike, Can you show the auto and 4speed cross members for a 1971 B-body? Thanks. Sorry no pics, but IIRC the 71-2 B body uses the same crossmember auto or 4spd, much like the 70-4 E body does Mike
