Pro's and con's of tool steel lifters #2785194
06/13/20 11:17 PM
06/13/20 11:17 PM
Mt Morris Michigan
mopar dave Offline OP
Mt Morris Michigan
Can anyone tell me the pros and cons of tool steel flat tappet lifters? Looking at Howards tool steel, extreme duty and their lite weight lifters. all have direct oiling, but i'm really interested in the tool steel if they don't cause any issues with cam lobes. Thanks
Re: Pro's and con's of tool steel lifters [Re: mopar dave] #2785217
06/14/20 12:34 AM
06/14/20 12:34 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
Dont do it , the reasons that Dwayne describes for my failure is IT.
https://board.moparts.org/ubbthreads/ubbthreads.php/topics/2402051/flat-cam.html
Re: Pro's and con's of tool steel lifters [Re: mopar dave] #2785234
06/14/20 07:22 AM
06/14/20 07:22 AM
PA
Harry's Taxi 2 Offline
PA
Pro's would be much less expensive than GOOD roller lifters, Con's more expensive than conventional lifters(that seem more failure prone than in the past)
I have been using Trend/Barton tool steel lifters. (they're a little different than directly from trend as the body has no groove/space in the middle) No edm holes.
The same set have been used on 4 different cams in two different short blocks. I use either Schaffer's or Valvoline 10-30 racing oil with no additional additives.
Currently using Isky 8205 springs.....I'd have to check my notes, but I think they're around 150# closed and #430 open
'86 Maple Grove KOS Mopar low qualifier......true street legal with no power adders.
NOS-used when losing since 1940.
Re: Pro's and con's of tool steel lifters [Re: CSK] #2785289
06/14/20 10:39 AM
06/14/20 10:39 AM
Mt Morris Michigan
Mt Morris Michigan
Wow, glad I asked. Some seem to have no issues, but I think i'll stay with the Comp or the Howards non tool steel EDM lifters. Thanks
Re: Pro's and con's of tool steel lifters [Re: mopar dave] #2785652
06/15/20 11:24 AM
06/15/20 11:24 AM
fredericksburg,va
cudaman1969 Offline
cudaman1969  Offline
fredericksburg,va
What type of cam is used with the tool steel lifters?
Re: Pro's and con's of tool steel lifters [Re: cudaman1969] #2785654
06/15/20 11:27 AM
06/15/20 11:27 AM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
cast iron
Re: Pro's and con's of tool steel lifters [Re: CSK] #2785704
06/15/20 01:12 PM
06/15/20 01:12 PM
central texas
K
krautrock Offline
krautrock  Offline
K
central texas
cast iron
did you ever say what Howards told you about the cam? I don't see anything in your thread.
Re: Pro's and con's of tool steel lifters [Re: cudaman1969] #2785724
06/15/20 01:45 PM
06/15/20 01:45 PM
Mt Morris Michigan
Mt Morris Michigan
Standard iron nitrated. The cam is a Ultradyne.
Re: Pro's and con's of tool steel lifters [Re: krautrock] #2785735
06/15/20 02:02 PM
06/15/20 02:02 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
cast iron
No, they wanted me to pay shipping to them & I was broke at the time, it was not the fault of Howards Cams, OR Trend lifters,it's just not something that works well for lots of street driving.
Re: Pro's and con's of tool steel lifters [Re: CSK] #2785839
06/15/20 07:58 PM
06/15/20 07:58 PM
Washington
hemienvy Offline
hemienvy  Offline
Washington
What is the theoretical advantage of tool steel flat tappet lifters ?
What is the reason they make them?
How are they ideally used ?
OK, on cast iron, non-nitrided cores, in theory ?
Re: Pro's and con's of tool steel lifters [Re: hemienvy] #2785885
06/15/20 10:58 PM
06/15/20 10:58 PM
Mt Morris Michigan
Mt Morris Michigan
I honestly don't know. I was looking at them because their lighter than the extreme duty lifters.
Re: Pro's and con's of tool steel lifters [Re: mopar dave] #2785916
06/16/20 02:34 AM
06/16/20 02:34 AM
Melbourne , Australia
LA360 Offline
LA360  Offline
I remember a little while that there were several instances of camshafts wiping lobes. It was found that the lifters available were a very similar surface hardness, resulting in metal tranfer from one to the other and lifters failing. Hence why nitriding is now an option on camshafts, the lifters are softer, so they wear gradually over time. The hard lifters, the opposite is going to happen, but the guys buying them aren't too bothered. DLC coated lifters are another thing altogether.
Alan Jones
Re: Pro's and con's of tool steel lifters [Re: LA360] #2785936
06/16/20 09:14 AM
06/16/20 09:14 AM
Mt Morris Michigan
Mt Morris Michigan
Think i'll stick with the comp EDM lifter. Had good luck with them so far.
Re: Pro's and con's of tool steel lifters [Re: mopar dave] #2785983
06/16/20 11:55 AM
06/16/20 11:55 AM
Super Spudsville
Mr PotatoHead Offline
Half Baked
Half Baked
Super Spudsville
Whats some of the weights you finding? What does the TS lifter weigh?
Any of you posters sitting on a set of TS small block units, used or? and want to dump them, pm me.
STOP POTATO HATE!
Re: Pro's and con's of tool steel lifters [Re: Mr PotatoHead] #2786020
06/16/20 01:43 PM
06/16/20 01:43 PM
Mt Morris Michigan
Mt Morris Michigan
If I remember correctly the ultra lite is 85 grams, the tool steel is 92g and the extreme duty are 100gram. I believe the extreme duty is same lifter as comp edm.
