1979 Dodge W150 radio wiring
#2784676
06/12/20 04:23 PM
06/12/20 04:23 PM
Posts: 2,534 God's Country Maryland
GODSCOUNTRY340
After over an hour on google and youtube, getting nowhere, I am hoping you guys can help. I'm installing a factory radio in my '79 Warlock and need to know where the wires coming out of the back of the radio go. There are 5 wires in question, black, purple, green, white and yellow. There is no under dash harness to plug into so I have to direct wire it. The double prong harness for power is there and hooked up. Thanks for any help.
Re: 1979 Dodge W150 radio wiring
[Re: buildanother]
#2784815
06/13/20 12:08 AM
06/13/20 12:08 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
the orange and red should be on all trucks, that's the main power(red) and inst lights (orange). The black, purple and green is stereo right and left w/ground.(black) You'll have to ground radio too.
His yellow is sun faded orange I bet. (Edited, nope Yellow is correct but the same as Orange) But yes Red = 12V positive Orange(Yellow) = dimmable dash lighting Black = only speaker ground. Do not ground this for the power, use the ground strap stud. You can burn out the transistor inside the radio. Violet = Right channel Green = Left channel There should be a bolt stud for a braided ground strap. This is the ground for power. CB antenna and AM/FM antenna connectors. These are Din 1.5 so a modern 1980-1990's AM/FM CD unit will fit too.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: GODSCOUNTRY340]
#2784868
06/13/20 10:14 AM
06/13/20 10:14 AM
Posts: 10,647 S.E.Ohio
Magnumguy
S.E.Ohio
Thanx everyone. What about the white wire? Yellow and white are "rear" left and right. I'd have to look in a trunk to see which is which, green and purple are the fronts.
[Re: NITROUSN]
#2785079
06/13/20 06:03 PM
06/13/20 06:03 PM
GODSCOUNTRY340
I had a '75 Clubcab truck and it had rear speakers mounted in the cab corners. Here's a pic of my radio.
