1979 Dodge W150 radio wiring #2784676
06/12/20 04:23 PM
06/12/20 04:23 PM
God's Country Maryland
GODSCOUNTRY340 Offline OP
After over an hour on google and youtube, getting nowhere, I am hoping you guys can help. I'm installing a factory radio in my '79 Warlock and need to know where the wires coming out of the back of the radio go. There are 5 wires in question, black, purple, green, white and yellow. There is no under dash harness to plug into so I have to direct wire it. The double prong harness for power is there and hooked up. Thanks for any help.
Re: 1979 Dodge W150 radio wiring [Re: GODSCOUNTRY340] #2784679
06/12/20 04:36 PM
06/12/20 04:36 PM
Grand Prairie,Texas
stumpy Offline
stumpy  Offline
Grand Prairie,Texas
Re: 1979 Dodge W150 radio wiring [Re: stumpy] #2784683
06/12/20 04:54 PM
06/12/20 04:54 PM
Thank you Stumpy, you're always a big help.
Re: 1979 Dodge W150 radio wiring [Re: GODSCOUNTRY340] #2784721
06/12/20 07:04 PM
06/12/20 07:04 PM
chicagoland,usa
buildanother Offline
chicagoland,usa
the orange and red should be on all trucks, that's the main power(red) and inst lights (orange). The black, purple and green is stereo right and left w/ground.(black) You'll have to ground radio too.
Re: 1979 Dodge W150 radio wiring [Re: buildanother] #2784815
06/13/20 12:08 AM
06/13/20 12:08 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
His yellow is sun faded orange I bet. (Edited, nope Yellow is correct but the same as Orange)
But yes
Red = 12V positive
Orange(Yellow) = dimmable dash lighting
Black = only speaker ground. Do not ground this for the power, use the ground strap stud. You can burn out the transistor inside the radio.
Violet = Right channel
Green = Left channel
There should be a bolt stud for a braided ground strap. This is the ground for power.
CB antenna and AM/FM antenna connectors.
These are Din 1.5 so a modern 1980-1990's AM/FM CD unit will fit too.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: 1979 Dodge W150 radio wiring [Re: Dave_J] #2784861
06/13/20 09:54 AM
06/13/20 09:54 AM
Thanx everyone. What about the white wire?
Re: 1979 Dodge W150 radio wiring [Re: GODSCOUNTRY340] #2784868
06/13/20 10:14 AM
06/13/20 10:14 AM
S.E.Ohio
Magnumguy Offline
Magnumguy  Offline
S.E.Ohio
Yellow and white are "rear" left and right. I'd have to look in a trunk to see which is which, green and purple are the fronts.
"Multiple Magnum owner since 1978!!"
https://www.facebook.com/groups/146952895354657/
Re: 1979 Dodge W150 radio wiring [Re: Magnumguy] #2784898
06/13/20 11:06 AM
06/13/20 11:06 AM
Alberta
440_Offroader Offline
Alberta
Did trucks have rear speakers in the 70s? Never seen any factory ones, so just wondering.
Re: 1979 Dodge W150 radio wiring [Re: 440_Offroader] #2785010
06/13/20 03:49 PM
06/13/20 03:49 PM
N
NITROUSN Offline
NITROUSN  Offline
N
No they did not. I think the poster has a newer radio.
Re: 1979 Dodge W150 radio wiring [Re: NITROUSN] #2785079
06/13/20 06:03 PM
06/13/20 06:03 PM
I had a '75 Clubcab truck and it had rear speakers mounted in the cab corners. Here's a pic of my radio.
Re: 1979 Dodge W150 radio wiring [Re: GODSCOUNTRY340] #2785115
06/13/20 08:05 PM
06/13/20 08:05 PM
N
NITROUSN Offline
NITROUSN  Offline
N
The 75 might of had that radio but someone put it in. Car radios would fit and they had the provisions for 4 speakers.
Re: 1979 Dodge W150 radio wiring [Re: NITROUSN] #2785677
06/15/20 12:24 PM
06/15/20 12:24 PM
That pic is of the '79 Warlock, here's couple more with the rear speakers.
26E20EBA-36A1-410A-82BC-18BFA46055C4_1_201_a.jpeg3472982F-32CF-4221-AFEC-FA2A5C06D4EE_1_201_a.jpeg6A0343A7-B300-4936-AD4A-93A38911923D.jpeg
