Re: Who to call for solid roller cam [Re: mopar dave] #2784115
06/11/20 01:13 PM
06/11/20 01:13 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
Originally Posted by mopar dave
I agree, my Scott Brown cam was way off with the 112LDA. My car couldn't get out of its own smoke with that cam.
Don't take it wrong, but sometimes the cam has to be matched to the converter etc. IM sure you and MR P know what you doing, just saying.
My buddy has a Nova, 3600lbs street car. Scott handled the cyl head porting, and the cam. Its a 565 BBC and it runs 9.30's . We haven't lit the plate yet....LOL
There are a few good suggestions in this thread, call a few and see what they say. My car runs pretty well, and I don't question Scott, whatever he says...I listen LOL
A lot of fast cars out there have Scott Brown cams in them and they don't even know it, only because a lot of tuners go through Scott and don't tell their customers where the cam came from or who spec'd it.
Hey I understand, not everyone will get great results and that's why there are a few great guys out there to work with.
Honestly I would talk to Dwayne ( I have never worked with him, but many here have) and or Scott. I think that's all you need to get a great cam for a Mopar
....BAD A$$ STREET CAR.....
Re: Who to call for solid roller cam [Re: n20mstr] #2784144
06/11/20 02:05 PM
06/11/20 02:05 PM
AndyF Offline
AndyF  Offline
I usually call Dwayne if I'm trying to figure out the best set of lobes for an engine but I've made good power with Scott Brown cams in the past. My all time favorite cam was a Harold grind back in the Ultradyne days. I had Bullet spec a cam for me on the last race engine and it ended up being a dog. I've gotten a bunch of poor performing cams from the Comp tech line over the years. Over the long run Dwayne has the best track record of any lobe picker that I've worked with. He just has a ton of experience with the lobe catalog and these types of engines.
Re: Who to call for solid roller cam [Re: n20mstr] #2784148
06/11/20 02:11 PM
06/11/20 02:11 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
I'm no expert on cam grinds, but what I see is large cubic inch(540+) and or high compression and or nitrous combos handle the wide lobe sep much better than low compression and smaller cubic inch motors. Mine was a 408 10.5:1 and the vert was a 3500 at the time. It hated that 112lda cam. I'm sure some may have had good results, but me, MR.P, and Don didn't and I used to see a lot of those for resale 10yrs or so ago. I'm glad yours is working good thou, that's cool.
Re: Who to call for solid roller cam [Re: dragram440] #2784165
06/11/20 03:08 PM
06/11/20 03:08 PM
New York
polyspheric Offline
polyspheric  Offline
New York
calling cam companies
You're not going to get an engineer on the phone. That's Buffy-the-phone-girl, reading a prepared response from her screen. Not her fault, she's limited to recommending at least one product whether it's best for you is not her problem.
Another problem: understanding cams has 2 distinct subjects which overlap by accident:
1. how do the whirley bits function (this has naught to do with engines and combustion, just metal, springs and geometry - especially rocker arms)
2. what does the engine want the valves to do (and doesn't care if it's by pneumatic, solenoids, or pixie dust).
Just my 2¢? I don't know anyone of Harold's quality that you can get on the phone. Some of his comments are still on Speedtalk.
After 50 years, your radar gets really sharp at picking up "he sounded good, until he said that really stupid thing" (name on request).
Why you see big LSA numbers with big engines: they need HUGE duration, and that LSA is how they hide the overlap.
Boffin Emeritus
Re: Who to call for solid roller cam [Re: polyspheric] #2784273
06/11/20 07:26 PM
06/11/20 07:26 PM
Phila Pa
scatpacktom Offline
scatpacktom  Offline
Phila Pa
These "who do I call" questions come up all the time... I can remember 15 plus years ago calling a few cam companies for a solid roller for a car with exhaust manifolds. I got so frustrated because I could hear the juice bag on the other end of the phone turning the pages. I didn't take any of their reccomendations, I basicly had a idea how much duration I wanted and knew how much lift would fit in the motor. I told them to spread the lobe center out as wide as the cam core would support.
Then through Ryan Johnson I heard of this guy Dwayne Porter that works with comp and had a very wide scope of dyno testing all kinds of racing engines...From 2 bbls with exhaust manifolds to stock eliminator to boat stuff. I gave Dwayne a call and tapped into his expierence...Naturally he was able to refine what some stupid kid came up with on his own.
Over the years, I have have bought more than a few cams...All sourced through Dwayne. I have directed many of my friends and family to use Dwayne's services with not one misfire...Not a problem ever!
Sometimes business comes down to... who you "want to get the money." All the names mentioned in this thread I'm sure are capable of getting you a cam that will work in your motor. Of all those names listed which ones post here on Moparts on a regular basis? Passing on their wealth of knowledge for free. Which ones can you call up on the telephone and have a conversation about YOUR car/combo and not feel rushed to get it all out in less than a minute? Then get advice you may not have known you needed with your cam purchace?
I just call Dwayne when I need a cam
Re: Who to call for solid roller cam [Re: scatpacktom] #2784300
06/11/20 08:41 PM
06/11/20 08:41 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
This ^^^^^^
Re: Who to call for solid roller cam [Re: scatpacktom] #2784315
06/11/20 09:14 PM
06/11/20 09:14 PM
New York
polyspheric Offline
polyspheric  Offline
New York
I would not presume to recommend a cam (except for those small number I've used personally,).
I would feel comfortable preferring 1 of 2 or 3 as a choice.
I would definitely recco not using some mentioned ("is 270° @ .050" a good choice for my 318 904 3.23?").
If Dwayne did your heads, he's the first person to ask.
Boffin Emeritus
Re: Who to call for solid roller cam [Re: Thumperdart] #2784330
06/11/20 10:01 PM
06/11/20 10:01 PM
gregsdart Online content
gregsdart  Online Content
Originally Posted by Thumperdart
And why Isky is the best overall in MY world and all I use plus my roller has the most aggressive street-ish lobes while being easy on parts. 14+ years and changed springs twice and rebuilt the roller lifters once so far. Easy mid 9's and 6-teens so far and driven a good amount.......680-.660 276-281 on a 108 lsa w/97 degrees of overlap.....
I too started with an Isky. A. RR735 grind with 1.55 rockers on a 528 alky motor with 440-1 heads. Went 8.77 with that cam at 153 mph at 1600 da and 3055 lbs. I had another more agressive cam cut and didn't see much if any improvement other than beating the snot out of my valvetrain. That rr735 was run with 340lbs on the seat.
Ole Ed Iskenderian understood cam design way back in the day. Those shelf grinds are VERY good designs.
Re: Who to call for solid roller cam [Re: gregsdart] #2784362
06/11/20 11:09 PM
06/11/20 11:09 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I have limited experience with Duane Porter all goood. The one thing I can say worth mentioning is that he’s helped many many people on here. I’ve heard story after story on here and I’ve never heard a single negative experience. To me that speaks volumes.
Re: Who to call for solid roller cam [Re: viperblue72] #2784457
06/12/20 06:53 AM
06/12/20 06:53 AM
UK
rb446 Offline
rb446  Offline
UK
Recently I put up a post about our newly acquired Big wedge motor my mate bought ready for this seasons racing at SPR frown ....I was asking for cam advice and intake/carb help. Its somewhat of a weird combo and my experience with something like that was minimal, having Race heads, street CR and a small solid roller not the best. Duane took the trouble in answering my posts and also spent time with me on pm's giving a cam recommendation with which lobes he thought would work with which springs, rockers etc. as I wanted to get some more out of what we had with the limit on CR which was a big restriction. Got to give it to him he was very helpful, where else can you get a good response like that on a forum from an expert in the field up
1969 'Cuda 446ci, best 9.96@133.9 in 1990
1971 340 'Cuda, best 11.01@122.8 in 1987
Re: Who to call for solid roller cam [Re: dragram440] #2784513
06/12/20 09:47 AM
06/12/20 09:47 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Dwayne is a nice guy and very helpful here. With your 500 12.25:1 Dwayne will probable spec you something in the low to mid 260@50 max effort street/strip. My Dwayne spec'd 270@50 for my 11.25:1 511 was too much for the combo and it showed when I raised the compression to 12.5:1 as it really woke up. Another plus going thru Dwayne is you would always have him here for questions later.
Re: Who to call for solid roller cam [Re: mopar dave] #2786896
06/18/20 05:19 PM
06/18/20 05:19 PM
bigfork mn
dragram440 Offline OP
bigfork mn
I ended up ordering a cam from Dwayne Porter. Definately glad I did. He took the time to go through all my info and I feel very confident after spending 45 mn on the phone with him. Called Bullet cams 5 times in the last week after filling out the form and left many messages to call me back and still haven't talked with them. Thanks again Dwayne.
67' charger 499 RB 10.57 at 127
Re: Who to call for solid roller cam [Re: dragram440] #2786926
06/18/20 07:08 PM
06/18/20 07:08 PM
NC
440Jim Offline
440Jim  Offline
NC
IMO your combo may be common in the last few years since the TF270 heads came out. Dwayne is familiar with it. So, I feel you made a good choice. Converter, gear, weight are variables other than engine. And user tolerance for valve springs is another.
Tell us your combo and the cam lobes and/or specs.
Re: Who to call for solid roller cam [Re: 440Jim] #2786930
06/18/20 07:21 PM
06/18/20 07:21 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
Dwayne spec’d cam in my pump gas 511. Couldn’t be happier with it!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Who to call for solid roller cam [Re: 68 HEMI GTS] #2786996
06/19/20 02:25 AM
06/19/20 02:25 AM
nj pine beach
dart9ss Offline
dart9ss  Offline
nj pine beach
Dwayne or no cam !! When it comes to mopar he is the right person and a great guy. Its a 1 on 1 experience.
802-951-1955
Re: Who to call for solid roller cam [Re: dragram440] #2787067
06/19/20 11:28 AM
06/19/20 11:28 AM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
What was your compression on that 511 and what did Dwayne give you for specs if you don’t mind sayin?
Re: Who to call for solid roller cam [Re: mopar dave] #2787157
06/19/20 03:22 PM
06/19/20 03:22 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
10.5:1. SFT 260/266@.050. nets a touch over .600 lift with 1.6 rockers. It’s drug my 69 roadrunner into the high 10’s with a six pack @ 4000#’s (with me).
I’m building another one right now for a 69 dart. 512 10.5:1 440-1’s with the solid roller from Andy F’s 470. I’ll be curious how it performs.
Cam for the one I’m building.
Re: Who to call for solid roller cam [Re: 68 HEMI GTS] #2787171
06/19/20 04:31 PM
06/19/20 04:31 PM
bigfork mn
bigfork mn
1967 Charger, Leaf spring Drag radial. 499 CI RB, 1969 440 block .055 over bore, 4.150 Eagle crank, 6.768 Eagle H beam rods, 12.25-1 comp.Trick Flow 270 with the 1.56 Springs, Titanium locks. Super Victor intake, Holley 1050 Dom. Dougs 2" x 3 1/2" headers. as of now but might have the heads decked to get it around 13-1. 8" 5000 converter hopefully a little higher stall with new combo. Foot brake car. Dana 60 with 3.91 gears. 3700 lbs with me in it. Cam he picked is if I remember correctly. 275/278 @ .050 .709 lift be for deflection and lash. Suppose to have some aggressive lobes. Says it withh open and close the valves fast. If he is on here he might be able to say more about the cam. I didnt write anything down on it and can't remember exactly.
Re: Who to call for solid roller cam [Re: dragram440] #2787182
06/19/20 05:29 PM
06/19/20 05:29 PM
Mt Morris Michigan
mopar dave Offline
mopar dave  Offline
Mt Morris Michigan
Ok, sounds real good.
