Page 7 of 10 1 2 5 6 7 8 9 10
Re: TH400 to RB in 69 b body info [Re: Cab_Burge] #2780168
05/31/20 08:11 PM
05/31/20 08:11 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I want to thank you all for your interest.I would have went to summit today but they are closed and if they have the .021 in stock at Talmage,Ohio store
I drove to summit and got the .021 and got the bell to read from .001 to .007 so I am good to go when the trans is done.I will update when I get the trans.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2783251
06/09/20 02:38 PM
06/09/20 02:38 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I go to pick up my trans tomorrow and he insists on putting on the bell to the trans for correct sealing to the pump.I waited to order a Vert to be sure nothing went wrong with my order on the trans so I can now order that and get moving on the mount and driveshaft.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2783283
06/09/20 03:19 PM
06/09/20 03:19 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
After he mounts the bell I am going to ask him to put in a converter so I can check the depth of the vert pilot to the engine side of the bell.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2783705
06/10/20 02:10 PM
06/10/20 02:10 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
JW said to ship the bell back.I went to rossler and he let me take a REID bell and another to test fit and so the factory dowels are too big for both bells and I hope to have a buddy turn them down .002/3 tonight after he is off work and then I can test fit what rossler lent me.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2783852
06/10/20 07:42 PM
06/10/20 07:42 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Bam I put on the other JW from another run yrs ago and fit great .001 to .004 with 0 offset dowel
Re: TH400 to RB in 69 b body info [Re: Clanton] #2784201
06/11/20 04:24 PM
06/11/20 04:24 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I finally have it at home.This is a big upgrade for me as much as the Koleno block was.Back to work with some motivation.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2784227
06/11/20 05:41 PM
06/11/20 05:41 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
looking good .
No thought to a sfi case or simply too much $ at this point ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: TH400 to RB in 69 b body info [Re: tex013] #2784247
06/11/20 06:27 PM
06/11/20 06:27 PM
Duloc
The Shadow Offline
The Shadow  Offline
Duloc
Man, are you going to have a long drive shaft. I would think close to 5ft
Re: TH400 to RB in 69 b body info [Re: tex013] #2784253
06/11/20 06:41 PM
06/11/20 06:41 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Originally Posted by tex013
looking good .
Tex
Simple answer Yes too much $.I did what I could.
Re: TH400 to RB in 69 b body info [Re: The Shadow] #2784254
06/11/20 06:44 PM
06/11/20 06:44 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I think it will be around 58".I would have got a longer tail if there were better communication with the builder.The 727 is 35" th400 is 28" ps:I ordered a PTC 9.5" converter will be here in 3 or 4 wks
Re: TH400 to RB in 69 b body info [Re: Clanton] #2784633
06/12/20 02:00 PM
06/12/20 02:00 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Test fit trans
Re: TH400 to RB in 69 b body info [Re: Clanton] #2784637
06/12/20 02:06 PM
06/12/20 02:06 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
2
Re: TH400 to RB in 69 b body info [Re: Clanton] #2784641
06/12/20 02:12 PM
06/12/20 02:12 PM
IL
furious70 Offline
furious70  Offline
IL
how tall is it in the back from the mount point to the top? Interested in comparing it to a Nag1 and TF8 I have to see how much cross member surgery I might need.
70 Sport Fury
68 Charger
69 Coronet
72 RR
Re: TH400 to RB in 69 b body info [Re: furious70] #2784671
06/12/20 03:43 PM
06/12/20 03:43 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
In the trans cross member pic the trans is topped out just to test fit and is just above the trans cross member ledge 3/4" maybe.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2785075
06/13/20 05:49 PM
06/13/20 05:49 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The trans and engine are test fit so I can make a trans mount but the input shaft looks back too far for the converter pilot.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2785357
06/14/20 12:12 PM
06/14/20 12:12 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
I notched the back of the factory trans x member 1" x4" wide and it fit the th400 nice so now to make room for the mount/bushing.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2785405
06/14/20 02:56 PM
06/14/20 02:56 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
The trans input shaft is about .200" away from the crank spacer so I will call PTC and let him know so I can get the .125" pilot in the spacer minimum needed.I need to cut the old trans fluid lines and re press the #6 fitting in and the temp sensor Tee in a good place and my Lokar dipstick looks like no problem clearing and rossler indexed the dipstick for the th400 and I am double triple measuring for the drive shaft to be made.I am glad things are moving along now.Any one have a question or input?
Re: TH400 to RB in 69 b body info [Re: Clanton] #2785694
06/15/20 12:52 PM
06/15/20 12:52 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
For what it's worth, I had a buddy with a '71 duster 20 years ago. When he got it...It had the top of the cross member cut out exactly like you've done to make yourT400 fit. Someone had chopped his out to put a 3 speed manual in the car, and the cross member was in the way of the shift rods if I remember right. This was a lowly mid 13 second car... nothing crazy.
Anyway... We converted it back to a 727 almost right after he bought it.
The odd thing was that it would break flex plates and trans mounts on a regular basis. After about 4 or 5 of them (even aftermarket SFI ones), we suspected maybe the missing frame cross member section had something to do with it.
My dad cut a piece of cross member out of a donor car and welded it back in for us. Never broke another flex plate again!!!!!
So just my 2 cents from my one and only experience.... with that crossmember piece missing it was a disaster.
Re: TH400 to RB in 69 b body info [Re: dizuster] #2785719
06/15/20 01:39 PM
06/15/20 01:39 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
Thank you I could always weld some angle in the cross member inside.I had to start somewhere.
Re: TH400 to RB in 69 b body info [Re: Clanton] #2785864
06/15/20 10:01 PM
06/15/20 10:01 PM
northern,Ohio,USA
Clanton Offline OP
Clanton  Offline OP
northern,Ohio,USA
This was a helpful chart so I will add it here driveshaft material strength list of driveshafts
