Page 9 of 11 1 2 7 8 9 10 11
Re: test pic 68 turbo dart project [Re: MoonshineMattK] #2781684
06/05/20 12:14 PM
06/05/20 12:14 PM
davenport iowa
P
paul69cuda Offline OP
P
davenport iowa
they slide in and out so all i had to do was back into the area between them and then they jacked it up removed the rear wheels and pushed it into the spot on the floor jack it was easy.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2781705
06/05/20 12:36 PM
06/05/20 12:36 PM
IL
Dart451 Offline
Dart451  Offline
IL
Not sure how i missed so much of this thread!! Impressive results, hope to see car at Cordova sometime soon.
Re: test pic 68 turbo dart project [Re: Dart451] #2781877
06/05/20 07:51 PM
06/05/20 07:51 PM
davenport iowa
P
P
davenport iowa
as soon as it is open on friday night i will be their im hoping next friday just got new seat belt so im ready.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2782029
06/06/20 10:05 AM
06/06/20 10:05 AM
IL
Dart451 Offline
Dart451  Offline
IL
Couple weeks ago we went to Union Grove and TnT on a Thursday night. track was prepped decent could of got 20+ runs ( we did 8) to busy check out cars and letting ours cool down. Think longest we waited in staging lanes was 5 minutes. So if you want lot of test runs might be worth the drive. Last year at Cordova we only made it out twice on friday night got 3 runs first trip and 2 the second. Sure miss when Cordova had Thursday night test sessions.
Re: test pic 68 turbo dart project [Re: Dart451] #2782119
06/06/20 01:26 PM
06/06/20 01:26 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Do you know what the IAT was at 1000 HP?
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: test pic 68 turbo dart project [Re: hemi-itis] #2783924
06/10/20 10:33 PM
06/10/20 10:33 PM
davenport iowa
P
P
davenport iowa
sorry but what is IAT im new to turbo and boost so not sure what that is
Re: test pic 68 turbo dart project [Re: paul69cuda] #2783939
06/10/20 11:16 PM
06/10/20 11:16 PM
Denver, CO
BigBlockGTS Offline
BigBlockGTS  Offline
Denver, CO
Intake Air Temperature I believe
Re: test pic 68 turbo dart project [Re: BigBlockGTS] #2783961
06/11/20 01:41 AM
06/11/20 01:41 AM
iagree
Manifold inlet temps. may be used in some circles to talk about on this subject shruggy
Re: test pic 68 turbo dart project [Re: Cab_Burge] #2785761
06/15/20 03:34 PM
06/15/20 03:34 PM
davenport iowa
P
P
davenport iowa
ah that makes sense now and no i do not know what it was.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790659
06/29/20 01:37 PM
06/29/20 01:37 PM
davenport iowa
P
P
davenport iowa
FINALLY MADE IT TO THE TRACK got 3 passes in to get used to it and yes i was very happy after a messed up 1st pass. okay so 1st pass i go up get in the burnout box do the line lock and it pushes through the bow and im like okay move up to stage get the bulbs trans brake on pedal to the floor let go of the button and boom flat on its face no boost it was like driving my mini van 8.88 at 88 mph 1/8 mile. go to pit trying to figure out what the hell is wrong so we let it cool down drive over to a spot to test the trans brake i push the button and it pops right into high gear at 2100 rpm so we go find matt from redline performance who tuned the car and he ask what the shift point was set at and i told him it was suppose to be 6000rpm well it was still at factory setting of 2100 rpm so he changes it. now 2nd pass 4lbs boost it does a burnout this time hit the bulbs and bam it leaves like it should. 1.77 60 foot 7.52 1/8 mile at 96.3 im happy now everything works but i needed more. so i decided to go with 8lbs boost on my ams 2000 controler wich is number 2 on my selector on my dash. at 8 lbs of boost it makes 650 hp at the axle hub so i go up do the motions hit the bulbs and BAM this thing leaves real good 60 foot 1.64 6.76 1/8 mile at 105.6 mph. i was very very happy it was super hot sat at Cordova but it hooked and ran straight with no leaks or issues i could have ran more but it was hoy as hell. i will be at this level for the rest of the summer for seat time i feel good with the launch getting used to it but i can go to the next level wich is 800hp still on shell 93 pump gas. Before i change to C16 wich i will do after Mopar National's for Aaron to race it and get the Suspension lined out but at this level that im running it has been perfect so far.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790679
06/29/20 02:54 PM
06/29/20 02:54 PM
central il.
second 70 Online content
second 70  Online Content
central il.
You can't find a better guy than Matt and man does he know what to fix.
Re: test pic 68 turbo dart project [Re: second 70] #2790680
06/29/20 02:59 PM
06/29/20 02:59 PM
davenport iowa
P
P
davenport iowa
1000% true great guy and his buddy who's name i forgot take care of customers for sure im just glad they were their. me and graham would have had no idea how to fix it i left my laptop at home all i wanted was a few passes to play with the car and get a feel for it.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790681
06/29/20 03:01 PM
06/29/20 03:01 PM
central il.
central il.
Matt knows more about my car than I do even thou he's never seen it! LOL
Re: test pic 68 turbo dart project [Re: second 70] #2790683
06/29/20 03:04 PM
06/29/20 03:04 PM
davenport iowa
P
P
davenport iowa
BUHAHAHAHAHA
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790704
06/29/20 04:16 PM
06/29/20 04:16 PM
Oakland, MI
dizuster Offline
dizuster  Offline
Oakland, MI
That is one sweet build you have there, and you gotta be happy with the first outing.
You should be REALLY proud of yourself for having the wisdom to get some seat time before turning it up.
That thing is going to fly once you get comfortable in it, and start turning up the wick.
Re: test pic 68 turbo dart project [Re: dizuster] #2790778
06/29/20 08:27 PM
06/29/20 08:27 PM
davenport iowa
P
P
davenport iowa
buddy it has been since 03 when i had my Cuda that i had a fast car. i may be a little crazy every now and then but turning this thing up with no seat time i would probably get killed wrecking the car. level 2 that im on know felt real good so im going to stay here for a while until it feels like normal then i will bump up to 12 lbs i would love to get a 5.99 before this year is over and i think i can as the driver but probably nothing more than that until next year.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790781
06/29/20 08:35 PM
06/29/20 08:35 PM
davenport iowa
P
P
davenport iowa
MOPAR NAT'S BOUND got my registration mailed today i look forward to meeting all of you guys their if your going. it looks like right now its just me from IOWA in the dart and JIMMY and JR from knoxville TENN in their nasty dart cruising heath and brice and the nat's and i here something goe's on at buckeye lake. none of us have been to NAT'S in 4 years my plan is to cruise around naked (no hood ) depending on weather.
Re: test pic 68 turbo dart project [Re: paul69cuda] #2790887
06/30/20 06:44 AM
06/30/20 06:44 AM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
You remember talking smack to me ?
Ha ha ha.
Re: test pic 68 turbo dart project [Re: FastmOp] #2791140
06/30/20 07:01 PM
06/30/20 07:01 PM
davenport iowa
P
P
davenport iowa
where when and how much did i drink before we were talking trash LMAO
Re: test pic 68 turbo dart project [Re: paul69cuda] #2791178
06/30/20 07:47 PM
06/30/20 07:47 PM
Hot Rod Ridge
FastmOp Offline
FastmOp  Offline
Hot Rod Ridge
Its all good.
Nice build. Its been fun watching it come together.
Keep taking it to the track. Post up some slips.
