Cloyes multi keyways timing sets
#2783912
06/10/20 10:02 PM
06/10/20 10:02 PM
Posts: 43,127 Bend,OR USA
Cab_Burge
I installed a Cloyes multi keyway timing set on a customers 350 Chevy motor today and degreed the cam, the timing marks on the crankshaft gear are marked backwards, just like the last 7 sets of new BB Mopar expensive timing sets I bought where Any one on here have a better company, product and brand to use from now on
Re: Cloyes multi keyways timing sets
[Re: Cab_Burge]
#2783915
06/10/20 10:11 PM
06/10/20 10:11 PM
Posts: 277 MN
Willie68coronet
MN
I like my "gold series" Rollmaster.The degree marks were correct for straight up and advancing. I've heard ProGear are good too.
'68 Coronet 500 w/ Indy EZ-1 headed 446, 727 trans, 9" rear First day at the track with SUV street tires and no traction: 1.688 60', 7.24 @ 101.79 in the 1/8 mile
Great customer service from: DominicThumper Carbs, B3 racing engines, Porter Racing Engines, A-1 torque converter's, Quick Performance, Racer Brown Cams, R&R Performance, Manton pushrods
[Re: Willie68coronet]
#2783937
06/10/20 11:10 PM
06/10/20 11:10 PM
Posts: 20,509 Eagle, Idaho
Neil
The Doctor is in.
The Doctor is in.
Eagle, Idaho
Try a Pro Gear set maybe? I have not read anything negative about them yet (knock on wood). http://progearweb.com/
[Re: Neil]
#2784049
06/11/20 11:23 AM
06/11/20 11:23 AM
Posts: 14,493 So. Burlington, Vt.
fast68plymouth
So. Burlington, Vt.
I realize there is no excuse for the lower gear having the numbers stamped on it backwards.......but...... does it really matter? Cab, I have to believe by now you know what notch on the gear equates to which position it is.
I assume you’re checking the installed position after you move the cam......so, what does it matter what the gear is stamped as long as the cam is installed correctly?
The first one of those 9 way sets I used had only a couple of dots stamped on the lower gear, designating the mid-point, or “0” position. Then there was a slip of paper with a drawing of the lower gear depicting what the advance/retard values were for each of the other notches.
I just consider the dots to be markings that are there as a convenience to get you to a point that’s close enough to start degreeing the cam.
[Re: Cab_Burge]
#2784173
06/11/20 03:25 PM
06/11/20 03:25 PM
RapidRobert
is Cloyes a quality piece other than that issue? there's sure been a lot of complaints against em but not sure if it was the dot issue and or something else
[Re: Neil]
#2784393
06/11/20 11:53 PM
06/11/20 11:53 PM
Posts: 199 TN Hoosier
jb500
TN Hoosier
Try a Pro Gear set maybe? I have not read anything negative about them yet (knock on wood). http://progearweb.com/ A second for Pro Gear. I purchased a Pro Gear set for my last rebuild and the chain was a little loose due to line hone. I called the company and spoke with customer service about geatting a tighter chain and they sent out two chains to try at Zero cost. Great customer service for sure!
[Re: Cab_Burge]
#2784503
06/12/20 09:31 AM
06/12/20 09:31 AM
RapidRobert
All 9 of the new BB Cloyes I've bought in the last two years will not fit under a stock timing cover I've call their service tech rep multiple times with no real fix yet, BAD ,BAD, Bad customer service Point taken, thanks Cab
