Re: A833 insight
[Re: doggs330]
#2783899
06/10/20 09:39 PM
06/10/20 09:39 PM
Posts: 43,286 Bend,OR USA
Cab_Burge
Looks okay to me, I have one like that I will sell if you want a spare, new seals and bearings and inspected in good shape like yours also .
Re: A833 insight
[Re: dragon slayer]
#2785683
06/15/20 12:31 PM
06/15/20 12:31 PM
Posts: 4,013 South Park, Pa.
68LAR
South Park, Pa.
From looking at the pictures, it looks like you have the wrong brass in there. The brass is from a '69 and back, but the synchronizer drum looks like that from a '70 and up transmission?
4 speed street legal. Best time 10.99 @ 124 mph on 93 octane pump gas @ 3926# total weight
Re: A833 insight
[Re: dragon slayer]
#2786474
06/17/20 04:58 PM
06/17/20 04:58 PM
Posts: 77 Mentor, OH
doggs330
Mentor, OH
Is there any excess play in the countershaft cluster? Is the clearance ok? As long as the countershaft has not enlarged the holes and the thrust washers are not worn, you are probably ok. Doesn't appear to be any play that I would call excessive. I wasn't planning on disassembling if it is not necessary. Everything visible through the sidecover looks alright to my untrained eyes. Another member that is local offered to give it a closer look. Thank you for the input. Freshen it up while it's out. It's a good little project and pretty simple. Get a good kit from Brewers and a book. That is probably what I will end up doing. The plan was to just drive this truck but with two dead cylinders and floorpans taking six months to ship, it has snowballed into the "while it's apart" deals. I do have the book. Thanks.
Re: A833 insight
[Re: doggs330]
#2786495
06/17/20 05:42 PM
06/17/20 05:42 PM
Posts: 1,412 northeast ohio
hulmule
northeast ohio
What book are you all talking about? Need to pick one up , want to go thru one for son's cuda. Where did you buy? Good details ?? thx If you want help doing yours if you live in Eastlake i'm near chardon, would give a hand to learn.
1969 Dodge Coronet R/T Convertible 1979 LiL Red x2 2012 Yellow Jacket 2006 mega cab 1977 Trailduster 1979 Trailduster
Re: A833 insight
[Re: hulmule]
#2786612
06/17/20 09:53 PM
06/17/20 09:53 PM
Posts: 10,556 Rittman Ohio
fourgearsavoy
Rittman Ohio
What book are you all talking about? Need to pick one up , want to go thru one for son's cuda. Where did you buy? Good details ?? thx If you want help doing yours if you live in Eastlake i'm near chardon, would give a hand to learn. Jamie Passon has written a book about Mopar 4-speeds available on his website Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
