DANA 60 dimensions
#2783871
06/10/20 08:28 PM
06/10/20 08:28 PM
Posts: 2,115 Byron, NY
W.I.N. Racing
Byron, NY
Im in the middle of setting up a DANA 60 and a the New ring gear falls on the stock carrier (original powr lok) instead of a slight press fit. I cant measure the carrier today but the ring gear measures out at 6.372 and the set I removed measures 6.369... Does anyone have the dimensions for carrier / Ring gear fit?
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60 '01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust, '05 Dodge Magnum R/T - Too Much to list '60 Willys CJ5 '01 International LPX - Project,DT466, Allison '64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: DANA 60 dimensions
[Re: John_Kunkel]
#2784284
06/11/20 07:50 PM
06/11/20 07:50 PM
W.I.N. Racing
Byron, NY
[Re: 440Jim]
#2784580
06/12/20 12:13 PM
06/12/20 12:13 PM
W.I.N. Racing
Byron, NY
He didn't provide me with a mfg dimension value just a measured Ring gear ID he had on hand. When I get a chance I'll measure the carrier on some good equipment and see if any of my friends (if any are still there) at a former employer can get me some numbers to compare to. Got a message from Gus at Randy's. Says 6.373 no Tol info though.
[Re: 440Jim]
#2784726
06/12/20 07:11 PM
06/12/20 07:11 PM
W.I.N. Racing
Byron, NY
Thanks for the input.. I just got another set of gears Motive, the ID measured 6.370 ( similar to the OEM set) and the fit is as expected. So the Auburn set is on its way back to the supplier. sometimes the simplest stuff kicks you butt!
