Re: Who to call for solid roller cam
[Re: mopar dave]
#2784115
06/11/20 01:13 PM
06/11/20 01:13 PM
Posts: 4,690 On the parachute mount
n20mstr
I agree, my Scott Brown cam was way off with the 112LDA. My car couldn't get out of its own smoke with that cam. Don't take it wrong, but sometimes the cam has to be matched to the converter etc. IM sure you and MR P know what you doing, just saying. My buddy has a Nova, 3600lbs street car. Scott handled the cyl head porting, and the cam. Its a 565 BBC and it runs 9.30's . We haven't lit the plate yet....LOL There are a few good suggestions in this thread, call a few and see what they say. My car runs pretty well, and I don't question Scott, whatever he says...I listen LOL A lot of fast cars out there have Scott Brown cams in them and they don't even know it, only because a lot of tuners go through Scott and don't tell their customers where the cam came from or who spec'd it. Hey I understand, not everyone will get great results and that's why there are a few great guys out there to work with. Honestly I would talk to Dwayne ( I have never worked with him, but many here have) and or Scott. I think that's all you need to get a great cam for a Mopar
....BAD A$$ STREET CAR.....
[Re: dragram440]
#2784165
06/11/20 03:08 PM
06/11/20 03:08 PM
Posts: 4,210 New York
polyspheric
New York
calling cam companies
You're not going to get an engineer on the phone. That's Buffy-the-phone-girl, reading a prepared response from her screen. Not her fault, she's limited to recommending at least one product whether it's best for you is not her problem.
Another problem: understanding cams has 2 distinct subjects which overlap by accident: 1. how do the whirley bits function (this has naught to do with engines and combustion, just metal, springs and geometry - especially rocker arms) 2. what does the engine want the valves to do (and doesn't care if it's by pneumatic, solenoids, or pixie dust).
Just my 2¢? I don't know anyone of Harold's quality that you can get on the phone. Some of his comments are still on Speedtalk. After 50 years, your radar gets really sharp at picking up "he sounded good, until he said that really stupid thing" (name on request).
Why you see big LSA numbers with big engines: they need HUGE duration, and that LSA is how they hide the overlap.
Boffin Emeritus
[Re: scatpacktom]
#2784300
06/11/20 08:41 PM
06/11/20 08:41 PM
Posts: 2,870 Pattison Texas
CSK
Pattison Texas
These "who do I call" questions come up all the time... I can remember 15 plus years ago calling a few cam companies for a solid roller for a car with exhaust manifolds. I got so frustrated because I could hear the juice bag on the other end of the phone turning the pages. I didn't take any of their reccomendations, I basicly had a idea how much duration I wanted and knew how much lift would fit in the motor. I told them to spread the lobe center out as wide as the cam core would support.
Then through Ryan Johnson I heard of this guy Dwayne Porter that works with comp and had a very wide scope of dyno testing all kinds of racing engines...From 2 bbls with exhaust manifolds to stock eliminator to boat stuff. I gave Dwayne a call and tapped into his expierence...Naturally he was able to refine what some stupid kid came up with on his own.
Over the years, I have have bought more than a few cams...All sourced through Dwayne. I have directed many of my friends and family to use Dwayne's services with not one misfire...Not a problem ever!
Sometimes business comes down to... who you "want to get the money." All the names mentioned in this thread I'm sure are capable of getting you a cam that will work in your motor. Of all those names listed which ones post here on Moparts on a regular basis? Passing on their wealth of knowledge for free. Which ones can you call up on the telephone and have a conversation about YOUR car/combo and not feel rushed to get it all out in less than a minute? Then get advice you may not have known you needed with your cam purchace?
I just call Dwayne when I need a cam This ^^^^^^
[Re: scatpacktom]
#2784315
06/11/20 09:14 PM
06/11/20 09:14 PM
polyspheric
New York
I would not presume to recommend a cam (except for those small number I've used personally,). I would feel comfortable preferring 1 of 2 or 3 as a choice. I would definitely recco not using some mentioned ("is 270° @ .050" a good choice for my 318 904 3.23?").
If Dwayne did your heads, he's the first person to ask.
Boffin Emeritus
[Re: Thumperdart]
#2784330
06/11/20 10:01 PM
06/11/20 10:01 PM
Posts: 10,013 Frostbitefalls MN (Rocky&Bullw...
gregsdart
And why Isky is the best overall in MY world and all I use plus my roller has the most aggressive street-ish lobes while being easy on parts. 14+ years and changed springs twice and rebuilt the roller lifters once so far. Easy mid 9's and 6-teens so far and driven a good amount.......680-.660 276-281 on a 108 lsa w/97 degrees of overlap..... I too started with an Isky. A. RR735 grind with 1.55 rockers on a 528 alky motor with 440-1 heads. Went 8.77 with that cam at 153 mph at 1600 da and 3055 lbs. I had another more agressive cam cut and didn't see much if any improvement other than beating the snot out of my valvetrain. That rr735 was run with 340lbs on the seat. Ole Ed Iskenderian understood cam design way back in the day. Those shelf grinds are VERY good designs.
[Re: mopar dave]
#2786896
06/18/20 05:19 PM
06/18/20 05:19 PM
Posts: 1,058 bigfork mn
dragram440
bigfork mn
I ended up ordering a cam from Dwayne Porter. Definately glad I did. He took the time to go through all my info and I feel very confident after spending 45 mn on the phone with him. Called Bullet cams 5 times in the last week after filling out the form and left many messages to call me back and still haven't talked with them. Thanks again Dwayne.
67' charger 499 RB
10.57 at 127
[Re: dragram440]
#2786926
06/18/20 07:08 PM
06/18/20 07:08 PM
Posts: 16,928 NC
440Jim
NC
I ended up ordering a cam from Dwayne Porter. IMO your combo may be common in the last few years since the TF270 heads came out. Dwayne is familiar with it. So, I feel you made a good choice. Converter, gear, weight are variables other than engine. And user tolerance for valve springs is another. Tell us your combo and the cam lobes and/or specs.
[Re: 440Jim]
#2786930
06/18/20 07:21 PM
06/18/20 07:21 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
Dwayne spec’d cam in my pump gas 511. Couldn’t be happier with it!
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 68 HEMI GTS]
#2786996
06/19/20 02:25 AM
06/19/20 02:25 AM
Posts: 361 nj pine beach
dart9ss
nj pine beach
Dwayne or no cam !! When it comes to mopar he is the right person and a great guy. Its a 1 on 1 experience. 802-951-1955
[Re: mopar dave]
#2787157
06/19/20 03:22 PM
06/19/20 03:22 PM
68 HEMI GTS
Temperance, MI
What was your compression on that 511 and what did Dwayne give you for specs if you don’t mind sayin? 10.5:1. SFT 260/266@.050. nets a touch over .600 lift with 1.6 rockers. It’s drug my 69 roadrunner into the high 10’s with a six pack @ 4000#’s (with me). I’m building another one right now for a 69 dart. 512 10.5:1 440-1’s with the solid roller from Andy F’s 470. I’ll be curious how it performs. Cam for the one I’m building.
[Re: 68 HEMI GTS]
#2787171
06/19/20 04:31 PM
06/19/20 04:31 PM
dragram440
bigfork mn
1967 Charger, Leaf spring Drag radial. 499 CI RB, 1969 440 block .055 over bore, 4.150 Eagle crank, 6.768 Eagle H beam rods, 12.25-1 comp.Trick Flow 270 with the 1.56 Springs, Titanium locks. Super Victor intake, Holley 1050 Dom. Dougs 2" x 3 1/2" headers. as of now but might have the heads decked to get it around 13-1. 8" 5000 converter hopefully a little higher stall with new combo. Foot brake car. Dana 60 with 3.91 gears. 3700 lbs with me in it. Cam he picked is if I remember correctly. 275/278 @ .050 .709 lift be for deflection and lash. Suppose to have some aggressive lobes. Says it withh open and close the valves fast. If he is on here he might be able to say more about the cam. I didnt write anything down on it and can't remember exactly.
67' charger 499 RB
10.57 at 127
