vaccum pump reading? #2782564
06/07/20 09:51 PM
06/07/20 09:51 PM
birdtracker Offline OP
where do you tap in to get a vacuum reading from the crank case evacuation pump. First time vac pump user. Pictures would be appreciated.Thanks. Birdtracker
Re: vaccum pump reading? [Re: birdtracker] #2782573
06/07/20 10:24 PM
06/07/20 10:24 PM
Cab_Burge Online work
Cab_Burge  Online Work
I put both the vacuum pump fitting and bypass valve fittings holes installed in the front of passenger side valve cover up I had a baffle welded in underneath both fittings also wrench
Re: vaccum pump reading? [Re: Cab_Burge] #2782601
06/08/20 01:58 AM
06/08/20 01:58 AM
New York, USA
Chargerfan68 Offline
New York, USA
I’m ready to fire up my motor soon, and i put a fitting for a vac gauge in the rear of the indy valley plate on top. Since it’s pulling vacuum, i don’t believe a baffle is needed since oil and vapor is being drawn the opposite way.
Re: vaccum pump reading? [Re: Chargerfan68] #2782602
06/08/20 02:33 AM
06/08/20 02:33 AM
How is oil and vapor being drawn the other way? Especially under acceleration work shruggy
Re: vaccum pump reading? [Re: birdtracker] #2782714
06/08/20 12:02 PM
06/08/20 12:02 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have my vacuum gauge connected to a fitting on the valley cover and that seems to work well.
Re: vaccum pump reading? [Re: birdtracker] #2782733
06/08/20 12:29 PM
06/08/20 12:29 PM
AndyF Offline
AndyF  Offline
I make fuel pump covers with a 1/8 NPT threaded port so you can install a fitting or a sensor for a vacuum gauge.
http://arengineering.com/products/fuel-pump-blockoff-billet-big-block-mopar/
Re: vaccum pump reading? [Re: AndyF] #2782738
06/08/20 12:33 PM
06/08/20 12:33 PM
AndyF Offline
AndyF  Offline
On my EFI race engine I just screwed the vacuum sensor right into the fuel pump blockoff for dyno testing. For a race car I'd probably suggest using a hose so the sensor isn't exposed to so much engine vibration. It is nice to have a sensor hooked up to a datalogger rather than watching a vacuum gauge but a hose to a vacuum gauge will work if you don't have a data logger.
Re: vaccum pump reading? [Re: birdtracker] #2782757
06/08/20 01:06 PM
06/08/20 01:06 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Where do you have the pump inlet hose hooked up to? If it is in a valve cover don't hook the gauge port up to the same cover, it will not give you an accurate reading but will tell you how much vacuum that valve cover has smile Also if this is a racepak or other data logger DO NOT put the sensor directly on the engine. They do not like the vibration at all. AS for me we generally put it in the opposite valve cover from the pump inlet.
Re: vaccum pump reading? [Re: Al_Alguire] #2782803
06/08/20 02:00 PM
06/08/20 02:00 PM
Thanks everyone for the reply. My block does not have a provision for a manual fuel pump and the valley tray is thin aluminum. So opposite valve cover it will be. Thanks for the positive direction. Birdtracker
Re: vaccum pump reading? [Re: birdtracker] #2782815
06/08/20 02:22 PM
06/08/20 02:22 PM
Addison,IL
OUTLAWSSAA Offline
OUTLAWSSAA  Offline
Addison,IL
Passenger side valve cover.
Re: vaccum pump reading? [Re: OUTLAWSSAA] #2782916
06/08/20 04:58 PM
06/08/20 04:58 PM
that is very sanitary. First time vac pump user. Plan on using all AN fittings. Birdtracker
Re: vaccum pump reading? [Re: birdtracker] #2783013
06/08/20 08:26 PM
06/08/20 08:26 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
We just use pushlock air line fittings. It weighs less and easy to connect and disconnect for maintenance
Here is a pic of mine. Drivers side valve cover in the oil fill cap.
Re: vaccum pump reading? [Re: Cab_Burge] #2783031
06/08/20 09:36 PM
06/08/20 09:36 PM
New York, USA
New York, USA
Cab, what i meant was that, as far as i can figure, ia baffle is not really needed since the crankcase is under vacuum and being pulled into the pump. So oil won’t be pushed up the fitting, like if the crankcase was under pressure and vents to any openings. This is what i surmised, but correct me if i’m wrong on my thinking, please.
Re: vaccum pump reading? [Re: Chargerfan68] #2783069
06/09/20 01:53 AM
06/09/20 01:53 AM
I found out the hard way that not using a baffle under the vacuum fitting on my new motor caused a lot more oil being sucked into the tank on every run, it would fill the tank up in less than 6 runs pukescope
I swap the old valve covers onto the new motor and cure that problem up
Using the baffle under the fitting resulted in almost pure moisture with in the tank and very little oil up
I think the oil droplets being slung off of the rocker arms are being forced into the fitting and up the hose under suction and not being given a chance to drop back into the heads, the baffle stops that twocents
Re: vaccum pump reading? [Re: Cab_Burge] #2783134
06/09/20 10:49 AM
06/09/20 10:49 AM
PA
moparacer Offline
moparacer  Offline
PA
I just tig welded an 1/8 inch pipe fitting on the top rear corner on my indy valve covers and run a plastic oil pressure line to my guage. Doesnt have to be anything extravagant. Just has to work.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: vaccum pump reading? [Re: moparacer] #2783145
06/09/20 11:10 AM
06/09/20 11:10 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
Drilled and tapped 1/8"pipe the back of the valley cover. Then used1/4"push lock. Out of sight.
Doug
Re: vaccum pump reading? [Re: Cab_Burge] #2783261
06/09/20 02:58 PM
06/09/20 02:58 PM
New York, USA
New York, USA
[quote=Cab_Burge]I found out the hard way that not using a baffle under the vacuum fitting on my new motor caused a lot more oil being sucked into the tank on every run, it would fill the tank up in less than 6 runs pukescope
I think the oil droplets being slung off of the rocker arms are being forced into the fitting and up the hose under suction and not being given a chance to drop back into the heads, the baffle stops that twocents [/
I should have clarified, but i am talking about the fitting that leads only to the vacuum gauge to monitor crankcase vacuum. Not the fitting and baffle to leads to the pump itself. They are in 2 diff locations. The pump hose fitting has a bafgle and is mounted in front of valve cover.
Btw, is there a better position for the baffle opening in that valve cover that you found is best? Right now, i have my opening pointing towards the header side. With the angle of the valve covers mounted on the heads, it is slanted downward away from the fitting opening. But, not sure if facing forward or center of engine is better? Thx
Re: vaccum pump reading? [Re: Chargerfan68] #2783445
06/09/20 10:27 PM
06/09/20 10:27 PM
I drilled a hole in the top rear of the drivers side V.C. for the gauge to read from up
