Gluing slicks instead of screws, results #2782324
06/07/20 08:22 AM
06/07/20 08:22 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
How good does weatherstrip glue work in holding a tire to the rim?
I know somebody has tried that. How did that go? Thanks
7 passes, and zero movement. Looks like I am good without screws! Thanks for replies gang!
Re: Gluing slicks instead of screws [Re: SportF] #2782338
06/07/20 10:05 AM
06/07/20 10:05 AM
PA
moparacer Offline
moparacer  Offline
PA
Been using permatex high tack for years on Dart with 60 fts in the 1.20s Lots of other cars too. Used to mark the tire and watch it. Now I dont even bother because they dont move.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Gluing slicks instead of screws [Re: moparacer] #2782344
06/07/20 10:45 AM
06/07/20 10:45 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Glad to hear that!!!!
I would guess though, I probably am not going to break the bead when the time comes, eh?
Re: Gluing slicks instead of screws [Re: SportF] #2782356
06/07/20 11:45 AM
06/07/20 11:45 AM
moparx Offline
moparx  Offline
you might have to walk around the rim a time or two, depending on the machine you are using.
don't over-apply the hi-tack. like the old commercial : "a little dab will do ya".
beer
Re: Gluing slicks instead of screws [Re: moparacer] #2782448
06/07/20 04:42 PM
06/07/20 04:42 PM
Bias or radial tires?
Same thing on the OP work
The tire pressure will make a huge differences on when they move or don't twocents shruggy
I use to mark my rims and tires at the tire valve and swap sides on both types of tires tubeless with no screws, The bias tires would move some at first and then move back when swapped to the other side. I don't remember the radials moving very much at all either side or either way confused
I never tried adhesives on any of my tires , I have a old all mechanical tire machine that I mount all my slicks on, I inflate them to between 20 to 30 lbs. and let them sit overnight or longer before putting them on the car to seat the tires as well as stretch the carcasses as much as possible before measuring the circumferences and adjusting the pressures to get the same circumferences within 1/4 inch of each other scope wrench
Re: Gluing slicks instead of screws [Re: Cab_Burge] #2782462
06/07/20 05:22 PM
06/07/20 05:22 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Cab, I had radial slicks on there and they never moved with 18 pounds of air. But I'm going back to bias and I'm tying the glue method. I guess the tires will be about 12-14 pounds. I'm guessing, hopefully on the high side of that guess.
I'm only in the low to mid 1.40's 60 foot, hopefully be ok.
Re: Gluing slicks instead of screws [Re: SportF] #2782520
06/07/20 08:06 PM
06/07/20 08:06 PM
I used a small dab of white shoe polish on the edge of the rims and tires, it will show if they move or not scope
Re: Gluing slicks instead of screws [Re: Cab_Burge] #2782523
06/07/20 08:14 PM
06/07/20 08:14 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
I can do that!
Re: Gluing slicks instead of screws [Re: SportF] #2782535
06/07/20 08:46 PM
06/07/20 08:46 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I do a silver paint pen and line it up with the valvestem. Right rear stopped after moving about 2". Left rear about 1". Never put anything on them.
'63 Dodge 330
11.19 @ 121 mph
Re: Gluing slicks instead of screws [Re: GY3] #2782596
06/08/20 12:27 AM
06/08/20 12:27 AM
Puyallup, WA
StealthWedge67 Offline
Puyallup, WA
Ive used Hi-Tack for a few sets now with good results. Remember when you apply to put a thin coat on the tire, and on the rim. Let it set up for at least a few minutes. Most report a little initial movement to set the tire, then solid after that.
Re: Gluing slicks instead of screws [Re: StealthWedge67] #2782611
06/08/20 05:26 AM
06/08/20 05:26 AM
MI, usa
dvw Offline
dvw  Offline
MI, usa
I used Permetex . Even ran tubes for a while. Eventually one moved and tore the tube. The other side never moved more than an 1"
Doug
Re: Gluing slicks instead of screws [Re: StealthWedge67] #2782633
06/08/20 08:03 AM
06/08/20 08:03 AM
Minn
SportF Offline OP
SportF  Offline OP
Minn
All good news as I don't want to change the looks of my wheels. Thanks gang, thanks to all.
Re: Gluing slicks instead of screws [Re: SportF] #2782691
06/08/20 11:20 AM
06/08/20 11:20 AM
Mt. Eden Ky.
Hemi Allstate Offline
Mt. Eden Ky.
I have run Goodyear bias slicks down to 7.5 psi with no screws or adhesive. I marked them for reference, and they have not moved. My 60 ft. times are low 1.30 s.
Mark
http://marsh-racing.com/Mark%20Mahorney-Allstate.htm
1996 Ram 1500 Sport
1968 road runner
1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
Re: Gluing slicks instead of screws [Re: Hemi Allstate] #2783206
06/09/20 12:56 PM
06/09/20 12:56 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Rockfalls this weekend Tom? Mike, Steve, and I will be there Friday.
69 GTX 68 Road Runner
Re: Gluing slicks instead of screws [Re: JERICOGTX] #2783308
06/09/20 04:28 PM
06/09/20 04:28 PM
Minn
SportF Offline OP
SportF  Offline OP
Minn
Sunday for sure
Re: Gluing slicks instead of screws [Re: SportF] #2783388
06/09/20 08:01 PM
06/09/20 08:01 PM
MI, usa
dvw Offline
dvw  Offline
MI, usa
We'll be making the long trip from Michigan to Rock Falls the 19th-21st for the Badger state Summer Classic.
Doug
Re: Gluing slicks instead of screws [Re: dvw] #2783393
06/09/20 08:11 PM
06/09/20 08:11 PM
MN
JERICOGTX Offline
JERICOGTX  Offline
MN
Doug, you will like it. The new owner has made a ton of improvements, and next year it will be a new facility. Track has tons of bite now.
