Gluing slicks instead of screws, results
#2782324
06/07/20 08:22 AM
06/07/20 08:22 AM
Posts: 1,213 Minn
SportF
Minn
How good does weatherstrip glue work in holding a tire to the rim?
I know somebody has tried that. How did that go? Thanks
7 passes, and zero movement. Looks like I am good without screws! Thanks for replies gang!
Re: Gluing slicks instead of screws
[Re: SportF]
#2782338
06/07/20 10:05 AM
06/07/20 10:05 AM
Posts: 2,526 PA
moparacer
PA
Been using permatex high tack for years on Dart with 60 fts in the 1.20s Lots of other cars too. Used to mark the tire and watch it. Now I dont even bother because they dont move.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: moparacer]
#2782448
06/07/20 04:42 PM
06/07/20 04:42 PM
Posts: 43,292 Bend,OR USA
Cab_Burge
Bias or radial tires? Same thing on the OP The tire pressure will make a huge differences on when they move or don't I use to mark my rims and tires at the tire valve and swap sides on both types of tires tubeless with no screws, The bias tires would move some at first and then move back when swapped to the other side. I don't remember the radials moving very much at all either side or either way I never tried adhesives on any of my tires , I have a old all mechanical tire machine that I mount all my slicks on, I inflate them to between 20 to 30 lbs. and let them sit overnight or longer before putting them on the car to seat the tires as well as stretch the carcasses as much as possible before measuring the circumferences and adjusting the pressures to get the same circumferences within 1/4 inch of each other
[Re: SportF]
#2782535
06/07/20 08:46 PM
06/07/20 08:46 PM
Posts: 4,700 Wichita
GY3
Wichita
I do a silver paint pen and line it up with the valvestem. Right rear stopped after moving about 2". Left rear about 1". Never put anything on them.
[Re: GY3]
#2782596
06/08/20 12:27 AM
06/08/20 12:27 AM
Posts: 4,319 Puyallup, WA
StealthWedge67
Puyallup, WA
Ive used Hi-Tack for a few sets now with good results. Remember when you apply to put a thin coat on the tire, and on the rim. Let it set up for at least a few minutes. Most report a little initial movement to set the tire, then solid after that.
[Re: SportF]
#2782691
06/08/20 11:20 AM
06/08/20 11:20 AM
Posts: 2,675 Mt. Eden Ky.
Hemi Allstate
Mt. Eden Ky.
I have run Goodyear bias slicks down to 7.5 psi with no screws or adhesive. I marked them for reference, and they have not moved. My 60 ft. times are low 1.30 s.
Mark
1996 Ram 1500 Sport 1968 road runner 1952 Sears Allstate licensed, pump gas, Hemi 5.98 @ 115.73 1.33 60 ft. The best is yet to come. Painless Performance / Street RODDER magazine Top 100 for 2019
[Re: Hemi Allstate]
#2783206
06/09/20 12:56 PM
06/09/20 12:56 PM
Posts: 10,045 MN
JERICOGTX
MN
Rockfalls this weekend Tom? Mike, Steve, and I will be there Friday.
69 GTX
68 Road Runner
[Re: JERICOGTX]
#2783308
06/09/20 04:28 PM
06/09/20 04:28 PM
Posts: 1,213 Minn
SportF
Minn
[Re: dvw]
#2783393
06/09/20 08:11 PM
06/09/20 08:11 PM
Posts: 10,045 MN
JERICOGTX
MN
Doug, you will like it. The new owner has made a ton of improvements, and next year it will be a new facility. Track has tons of bite now.
69 GTX
68 Road Runner
