SB deck to head dowel pin sizing? #2781886
06/05/20 08:26 PM
06/05/20 08:26 PM
Windsor, ON, Canada
Diplomat360 Offline OP
Windsor, ON, Canada
'74 360 block here...checked the hole diameter and it looks to be around .300-.310, however several on-line sources reference a 0.275" diameter pin (Mancini Racing), and yet there is the following Mr. Gasket part which is 0.310".
Heck, this Pioneer Automotive set is a steal at $11 for 25 pcs!
So what the heck is the right/correct dimension?
I've never seen a wobbly dowel pin ever, so that 0.275" diameter seems not right.
Re: SB deck to head dowel pin sizing? [Re: Diplomat360] #2782043
06/06/20 10:40 AM
06/06/20 10:40 AM
May I ask, how did you measure the hole?
Re: SB deck to head dowel pin sizing? [Re: RapidRobert] #2782050
06/06/20 10:55 AM
06/06/20 10:55 AM
Windsor, ON, Canada
Windsor, ON, Canada
Vernier caliper...I got between .300-.310 only because the dowel pin hole in the head is the .310" while the block is .300".
Since I figure it's hard to expect the block to expand by 0.010" to make the larger diameter dowel pin fit, I better look at something around that .300" size, but the only thing I find in the right length is the .275" stuff.
Re: SB deck to head dowel pin sizing? [Re: Diplomat360] #2782055
06/06/20 11:04 AM
06/06/20 11:04 AM
North Dakota
6PakBee Offline
6PakBee  Offline
North Dakota
I've always had trouble measuring small holes with a caliper. I've resorted to using drill bits as an el-cheapo plug gauge.
Re: SB deck to head dowel pin sizing? [Re: 6PakBee] #2782080
06/06/20 12:17 PM
06/06/20 12:17 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
iagree Pretty obvious that the nominal dimension is .3125" (5/16").
Re: SB deck to head dowel pin sizing? [Re: Diplomat360] #2782350
06/07/20 11:20 AM
06/07/20 11:20 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I have a couple of the kits Mopar sells to finish out a new bare block. Freeze plugs, distributor bushing etc. The have two sets of dowel pins in them one set around .310 and some others closer to .275. Not sure where the small ones go.
Re: SB deck to head dowel pin sizing? [Re: 340Cuda] #2782416
06/07/20 02:56 PM
06/07/20 02:56 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
Locating pins for the timing chain cover?
Re: SB deck to head dowel pin sizing? [Re: slantzilla] #2782712
06/08/20 11:57 AM
06/08/20 11:57 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
That is kind of what I was thinking.
That is kind of what I thought but isn't that a big block deal?
My R3 block has no provision for them.
Re: SB deck to head dowel pin sizing? [Re: 340Cuda] #2782762
06/08/20 01:11 PM
06/08/20 01:11 PM
Park Forest, IL
slantzilla Offline
slantzilla  Offline
Park Forest, IL
I don't remember if a small block has them or not. Slants do.
Re: SB deck to head dowel pin sizing? [Re: slantzilla] #2783166
06/09/20 11:41 AM
06/09/20 11:41 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
I am currently preping a never used R3 block. I had a lot of trouble getting the dowel pins in the driver's side deck. Even using a brass hammer I mushroomed the top of one.
On the passenger side i placed the dowels in the -1 freezer for a couple days and they went in much better.
Re: SB deck to head dowel pin sizing? [Re: Diplomat360] #2783930
06/10/20 10:40 PM
06/10/20 10:40 PM
Windsor, ON, Canada
Windsor, ON, Canada
Thanks for the responses you guys.
I ordered a couple of different part numbers, just a QTY of 1 or 2, so not a big spend.
Once I get them here, will measure and try them out, and post the results, FYI if anything.
