SB deck to head dowel pin sizing?
#2781886
06/05/20 08:26 PM
06/05/20 08:26 PM
Posts: 1,754 Windsor, ON, Canada
Diplomat360
Windsor, ON, Canada
'74 360 block here...checked the hole diameter and it looks to be around .300-.310, however several on-line sources reference a 0.275" diameter pin ( Mancini Racing), and yet there is the following Mr. Gasket part which is 0.310". Heck, this Pioneer Automotive set is a steal at $11 for 25 pcs! So what the heck is the right/correct dimension? I've never seen a wobbly dowel pin ever, so that 0.275" diameter seems not right.
Re: SB deck to head dowel pin sizing?
[Re: Diplomat360]
#2782043
06/06/20 10:40 AM
06/06/20 10:40 AM
RapidRobert
May I ask, how did you measure the hole?
[Re: RapidRobert]
#2782050
06/06/20 10:55 AM
06/06/20 10:55 AM
Diplomat360
Windsor, ON, Canada
May I ask, how did you measure the hole? Vernier caliper...I got between .300-.310 only because the dowel pin hole in the head is the .310" while the block is .300". Since I figure it's hard to expect the block to expand by 0.010" to make the larger diameter dowel pin fit, I better look at something around that .300" size, but the only thing I find in the right length is the .275" stuff.
[Re: Diplomat360]
#2782055
06/06/20 11:04 AM
06/06/20 11:04 AM
Posts: 10,704 North Dakota
6PakBee
North Dakota
I've always had trouble measuring small holes with a caliper. I've resorted to using drill bits as an el-cheapo plug gauge.
[Re: Diplomat360]
#2782350
06/07/20 11:20 AM
06/07/20 11:20 AM
Posts: 3,509 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
'74 360 block here...checked the hole diameter and it looks to be around .300-.310, however several on-line sources reference a 0.275" diameter pin ( Mancini Racing), and yet there is the following Mr. Gasket part which is 0.310". Heck, this Pioneer Automotive set is a steal at $11 for 25 pcs! So what the heck is the right/correct dimension? I've never seen a wobbly dowel pin ever, so that 0.275" diameter seems not right. I have a couple of the kits Mopar sells to finish out a new bare block. Freeze plugs, distributor bushing etc. The have two sets of dowel pins in them one set around .310 and some others closer to .275. Not sure where the small ones go.
[Re: 340Cuda]
#2782416
06/07/20 02:56 PM
06/07/20 02:56 PM
Posts: 20,169 Park Forest, IL
slantzilla
Park Forest, IL
Locating pins for the timing chain cover?
[Re: slantzilla]
#2782712
06/08/20 11:57 AM
06/08/20 11:57 AM
340Cuda
Tulsa, Oklahoma
Locating pins for the timing chain cover? That is kind of what I was thinking. That is kind of what I thought but isn't that a big block deal? My R3 block has no provision for them.
[Re: 340Cuda]
#2782762
06/08/20 01:11 PM
06/08/20 01:11 PM
slantzilla
Park Forest, IL
I don't remember if a small block has them or not. Slants do.
[Re: Diplomat360]
#2783930
06/10/20 10:40 PM
06/10/20 10:40 PM
Diplomat360
Windsor, ON, Canada
Thanks for the responses you guys.
I ordered a couple of different part numbers, just a QTY of 1 or 2, so not a big spend.
Once I get them here, will measure and try them out, and post the results, FYI if anything.
