small block timing chain ? #2781772
06/05/20 02:39 PM
06/05/20 02:39 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
does any one make a timing chain set with .250" with SOLID roller bushings for small block ?
look for a lost art quality !
thank you !
Re: small block timing chain ? [Re: calrobb2000] #2781796
06/05/20 04:16 PM
06/05/20 04:16 PM
Kirkland, Washington
Pacnorthcuda Offline
Not sure what you mean. Roller bushings, in order to ‘roll’ have to be hollow in order to fit around the pin. If they were solid, they would be pins.
Unless I’m missing something here....which is very possible!
Re: small block timing chain ? [Re: Pacnorthcuda] #2781955
06/05/20 11:04 PM
06/05/20 11:04 PM
Eagle, Idaho
Neil Online content
The Doctor is in.
Neil  Online Content
The Doctor is in.
Eagle, Idaho
Maybe a Pro Gear set is what you want?
http://progearweb.com/
