Intake Compatibility with "Batwings" #2780703
06/02/20 01:11 PM
06/02/20 01:11 PM
CT
GTX MATT Offline OP
GTX MATT  Offline OP
CT
Do the lower single plane intakes like a Holley SD or Eddy Torker/TM7 work with the valley plate/bat wings on a non raised port head?
Re: Intake Compatibility with "Batwings" [Re: GTX MATT] #2780710
06/02/20 01:27 PM
06/02/20 01:27 PM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We used to run a Torker II with std "Motor home" heads and std, tin intake gaskets on a 440 RB, No issues as I recall. HTH's up
Re: Intake Compatibility with "Batwings" [Re: GTX MATT] #2780769
06/02/20 03:08 PM
06/02/20 03:08 PM
So. Burlington, Vt.
fast68plymouth Offline
So. Burlington, Vt.
They should work in any application where the stock valley pan would work.
Re: Intake Compatibility with "Batwings" [Re: fast68plymouth] #2780780
06/02/20 03:29 PM
06/02/20 03:29 PM
junction city oregon
V
viperblue72 Offline
viperblue72  Offline
V
I think the op is asking what intakes will clear the thick aluminum valley cover.
Re: Intake Compatibility with "Batwings" [Re: viperblue72] #2780800
06/02/20 04:25 PM
06/02/20 04:25 PM
usa
lewtot184 Offline
lewtot184  Offline
usa
the heat crossover is usually the problem with valley covers. crossovers aren't a uniform size. all manifolds are different.
Re: Intake Compatibility with "Batwings" [Re: lewtot184] #2780820
06/02/20 05:35 PM
06/02/20 05:35 PM
AndyF Offline
AndyF  Offline
You can tell if the intake will clear a billet valley plate by just looking at the intake.
