First test pass after mishap with motor #2780109
05/31/20 05:06 PM
05/31/20 05:06 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
First test pass this year after last year when Exhaust valve broke causing extensive damage pulls super strong too bad I lifted too soon shift light came on 7500 and blinded me forgot to turn it up after dyno pulls. https://www.youtube.com/watch?v=yvKRdk-bLco&t=20s It's a 540 B1 MC Indy Max block
Attached PDF document
new time lip.pdf (65 downloads)
best so far 8.53 @ 158.59 MPH 60'1.240
Re: First test pass after mishap with motor [Re: JD Dart] #2780116
05/31/20 05:25 PM
05/31/20 05:25 PM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
nice
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: First test pass after mishap with motor [Re: JD Dart] #2780130
05/31/20 06:30 PM
05/31/20 06:30 PM
Sounded like the throttle stop was on over 3 seconds, what will it run all out?
Re: First test pass after mishap with motor [Re: Cab_Burge] #2780132
05/31/20 06:33 PM
05/31/20 06:33 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
8.50's
Re: First test pass after mishap with motor [Re: JD Dart] #2780134
05/31/20 06:36 PM
05/31/20 06:36 PM
Originally Posted by JD Dart
8.50's
Thanks up
Re: First test pass after mishap with motor [Re: Cab_Burge] #2780328
06/01/20 12:57 PM
06/01/20 12:57 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Glad to hear you got her going again Jess.
Re: First test pass after mishap with motor [Re: Al_Alguire] #2780355
06/01/20 02:25 PM
06/01/20 02:25 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Thanks nice to have the power back gives me more options at the finish line. Working on the hood scoop this week A/F gets weird going down track front cylinders are going lean rear is ok. Just thought it was normal. Until I did some chassis dyno pulls because of Covid-19 no track open at the time, A/F follow each other sitting still.
So I'm thinking there is some serious air flow issues going on. You will have to let me know how to post racepak logs.
Re: First test pass after mishap with motor [Re: JD Dart] #2780797
06/02/20 04:18 PM
06/02/20 04:18 PM
Great Neck,LI,new york
hemi-itis Offline
hemi-itis  Offline
Take screenshots and then post them.
HEMI-ITIS has no cure.
My condition is fully BLOWN!!
Re: First test pass after mishap with motor [Re: hemi-itis] #2780832
06/02/20 05:54 PM
06/02/20 05:54 PM
WA
JD Dart Offline OP
JD Dart  Offline OP
WA
Ok I'll try Thanks
