First test pass after mishap with motor
#2780109
05/31/20 05:06 PM
05/31/20 05:06 PM
Posts: 739 WA
JD Dart
WA
First test pass this year after last year when Exhaust valve broke causing extensive damage pulls super strong too bad I lifted too soon shift light came on 7500 and blinded me forgot to turn it up after dyno pulls. https://www.youtube.com/watch?v=yvKRdk-bLco&t=20s It's a 540 B1 MC Indy Max block
best so far 8.53 @ 158.59 MPH 60'1.240
Re: First test pass after mishap with motor
[Re: JD Dart]
#2780130
05/31/20 06:30 PM
05/31/20 06:30 PM
Posts: 43,180 Bend,OR USA
Cab_Burge
Sounded like the throttle stop was on over 3 seconds, what will it run all out?
[Re: Cab_Burge]
#2780328
06/01/20 12:57 PM
06/01/20 12:57 PM
Posts: 19,363 Las Vegas
Al_Alguire
Las Vegas
Glad to hear you got her going again Jess.
[Re: Al_Alguire]
#2780355
06/01/20 02:25 PM
06/01/20 02:25 PM
Posts: 739 WA
JD Dart
WA
Thanks nice to have the power back gives me more options at the finish line. Working on the hood scoop this week A/F gets weird going down track front cylinders are going lean rear is ok. Just thought it was normal. Until I did some chassis dyno pulls because of Covid-19 no track open at the time, A/F follow each other sitting still. So I'm thinking there is some serious air flow issues going on. You will have to let me know how to post racepak logs.
