Electrical Issue #2779710
05/30/20 11:51 AM
05/30/20 11:51 AM
Sebring, Florida
Mopar Grandpa Offline OP
Sebring, Florida
Okay, I have a 2016 Chrysler 300C and it has developed an electrical issue in the instrument panel. When I start the car the instrument panel doesn’t light up like it is supposed to, but not all of the time. I can back it out of the garage, shift to D and the instrument panel lights up. I have the headlight switch in the Auto mode (we never change it) and if I change it to On the panel will light up. However, this problem is intermittent. Need some help on this one as I haven’t taken it to a dealership yet and would prefer to fix it myself since the 3 year bumper to bumper warranty has expired. Only 20,000 miles and always kept in the garage.
Thanks in advance.
Re: Electrical Issue [Re: Mopar Grandpa] #2779750
05/30/20 01:20 PM
05/30/20 01:20 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
If you use it manually it works?
Re: Electrical Issue [Re: Mopar Grandpa] #2779751
05/30/20 01:21 PM
05/30/20 01:21 PM
NEW JERSEY
AARCONV Offline
AARCONV  Offline
NEW JERSEY
Is the headlight switch on the turn signal stick also?
Re: Electrical Issue [Re: AARCONV] #2779761
05/30/20 01:34 PM
05/30/20 01:34 PM
Sebring, Florida
Sebring, Florida
Yes, but it will eventually work in the Auto mode.
Re: Electrical Issue [Re: AARCONV] #2779762
05/30/20 01:35 PM
05/30/20 01:35 PM
Sebring, Florida
Sebring, Florida
No, the switch is on the lower left side of the dash.
Re: Electrical Issue [Re: Mopar Grandpa] #2779775
05/30/20 02:19 PM
05/30/20 02:19 PM
It sounds to me like it is(the connection or circuit) either worn or corroded causing the intermittent issues your having twocents
Do you live in a high humidity area, winter and summer? If so look for corrosion, if not look for wear twocents
Re: Electrical Issue [Re: Cab_Burge] #2779782
05/30/20 03:12 PM
05/30/20 03:12 PM
Grand Prairie,Texas
stumpy Online content
stumpy  Online Content
Grand Prairie,Texas
Try running the dash light dimmer switch both ways a few times.
Re: Electrical Issue [Re: Cab_Burge] #2779786
05/30/20 03:33 PM
05/30/20 03:33 PM
Sebring, Florida
Sebring, Florida
Yes, I live in central Florida and the humidity is high most of the time. Thanks for your input. I’ll do some checking.
Re: Electrical Issue [Re: stumpy] #2779809
05/30/20 04:49 PM
05/30/20 04:49 PM
Sebring, Florida
Sebring, Florida
I’ll give that a try. Thanks.
