Page 3 of 5 1 2 3 4 5
Re: Suggestions on what to do with my motor? - update [Re: 440Jim] #2779527
05/29/20 04:39 PM
05/29/20 04:39 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Ready for the dyno! grin grin grin
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2779531
05/29/20 04:53 PM
05/29/20 04:53 PM
tboomer Online work
tboomer  Online Work
Good luck!
Re: Suggestions on what to do with my motor? - update [Re: tboomer] #2779536
05/29/20 05:09 PM
05/29/20 05:09 PM
NC
440Jim Offline
440Jim  Offline
NC
I am looking forward to the dyno results. Not too many 1000+ hp engines posted here.
Can you summarize the final build numbers?
15.x CR, cam specs, head flow numbers, carb, header size
Re: Suggestions on what to do with my motor? - update [Re: 440Jim] #2779543
05/29/20 05:25 PM
05/29/20 05:25 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
I will when after the dyno run.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2779568
05/29/20 06:39 PM
05/29/20 06:39 PM
Guitar Jones Offline
Hmm, that's not your run of the mill 500 horse 440. laugh2 I also noticed you don't have a PH8A Fram oil filter on it. laugh2
Good luck with it, hope it's everything you wanted from it.
'74 W200 Crew Cab 360, NV4500, D44, D60 and NP205 divorced transfer case. Rear disc and hydroboost coming soon!
Re: Suggestions on what to do with my motor? - update [Re: Guitar Jones] #2779570
05/29/20 06:40 PM
05/29/20 06:40 PM
Oh wait, are you going to put a Street Demon on it? laugh2
Re: Suggestions on what to do with my motor? - update [Re: Guitar Jones] #2779581
05/29/20 07:18 PM
05/29/20 07:18 PM
gregsdart Offline
gregsdart  Offline
Did i miss when the dyno session is? Looking forward to this! It is what i should have done many years ago!!
Re: Suggestions on what to do with my motor? - update [Re: gregsdart] #2779695
05/30/20 10:12 AM
05/30/20 10:12 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Dyno session not scheduled yet.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2780812
06/02/20 05:15 PM
06/02/20 05:15 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
June 17 is dyno day..............
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2781367
06/04/20 12:42 PM
06/04/20 12:42 PM
gregsdart Offline
gregsdart  Offline
Any chassis or driveline upgrades to match the new power level?
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2781379
06/04/20 12:58 PM
06/04/20 12:58 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
Cant wait to hear the results. The little B1 deal was just dynode on this past Monday
Re: Suggestions on what to do with my motor? - update [Re: Al_Alguire] #2781393
06/04/20 01:45 PM
06/04/20 01:45 PM
why aren't you sharing those results Al whistling stirthepot grin
Re: Suggestions on what to do with my motor? - update [Re: gregsdart] #2781428
06/04/20 04:20 PM
06/04/20 04:20 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Not much. Biggest worry is the 727 output shaft. Working with Rick Allison on a solution but that is still open.
John Holt redid my fuel tank and added the parachute. They also redid my windshield as it was caving in at 140 mph. The window was in original rubber and the Lexan was cut a tad too small. Now its screwed in.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2786295
06/17/20 10:47 AM
06/17/20 10:47 AM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
Well its dyno day! Anyone wanna play a guessing game on HP? I know I did not give the required info.......... I say it best make 1050 and hope at least 1080 hp.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2786299
06/17/20 11:00 AM
06/17/20 11:00 AM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
My old MC engine made 1088 and was only 525, so lets start there. Good luck and I am sure you will be happy with what Tony and BES give you.
Re: Suggestions on what to do with my motor? - update [Re: Al_Alguire] #2786356
06/17/20 12:41 PM
06/17/20 12:41 PM
Shelby Twp. Mi
HardcoreB Offline
HardcoreB  Offline
Shelby Twp. Mi
NICE program and updates!!! 1050 non-oxygenated fuel is my guess
Re: Suggestions on what to do with my motor? - update [Re: HardcoreB] #2786371
06/17/20 01:00 PM
06/17/20 01:00 PM
On the parachute mount
N
n20mstr Offline
n20mstr  Offline
N
MY 530" made 915, with C23 and has a nitrous friendly 1050 carb and nitrous no NA friendly cam LOL , so I don't see how 1000+ is out of the question. Should go over 1000. I will guess 1100
....BAD A$$ STREET CAR.....
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2786433
06/17/20 02:45 PM
06/17/20 02:45 PM
NC
440Jim Offline
440Jim  Offline
NC
I don't know much about those B1 MC motors, and without the cam duration guessing peak horsepower is tough.
My guess 1065 hp at 6800 rpm More cam, more rpm, more peak horsepower. Good Luck.
Re: Suggestions on what to do with my motor? - update [Re: 440Jim] #2786445
06/17/20 03:04 PM
06/17/20 03:04 PM
Morrow, OH
markz528 Offline OP
markz528  Offline OP
Morrow, OH
We are running c14 fuel. My headers did not fit so these are a bit bigger than mine.
We will see where it ends up so far 1040 hp at 7100 rpm 830 torque. It likes timing.
Re: Suggestions on what to do with my motor? - update [Re: markz528] #2786604
06/17/20 09:35 PM
06/17/20 09:35 PM
NC
440Jim Offline
440Jim  Offline
NC
If so far peak hp was 7100 rpm, you likely have more cam duration than I was thinking from your older posts....
Look forward to the final tune.
