833 Questions
#2779476
05/29/20 01:59 PM
05/29/20 01:59 PM
Posts: 3,547 stratford,ontario,canada
JD340
Will a Hurst Competition Plus shifter and rods from a normal B body 833 work on an 833 OD truck trans? Would I need to reuse the OD 3-4 rod or will the Comp one work as is? Any help appreciated.
Nothing to see here. Carry on.
Re: 833 Questions
[Re: JD340]
#2779480
05/29/20 02:13 PM
05/29/20 02:13 PM
Posts: 6,008 Salem
Grizzly
Moparts Proctologist
Salem
The shifter will work as long as it has the same hair pin setup as factory.
Putting an OD in is a little more involved with modifying the rods and transmission levers.
If you know how to weld it's easy, it's a bit of a pain though.
Are you putting an OD in a B body or putting the shifter in a truck with OD?
Mo' Farts
Moderated by "tbagger".
Re: 833 Questions
[Re: Grizzly]
#2779481
05/29/20 02:20 PM
05/29/20 02:20 PM
JD340
Are you putting an OD in a B body or putting the shifter in a truck with OD? Hoping to use the shifter in my truck. My factory shifter is worn and sloppy, I figured an upgrade to the comp plus would tighten things up considerably. PLUS, it comes with the pistol grip shifter I've been wanting to add as well!
Re: 833 Questions
[Re: JD340]
#2779500
05/29/20 03:11 PM
05/29/20 03:11 PM
Posts: 10,555 Rittman Ohio
fourgearsavoy
Rittman Ohio
Are you putting an OD in a B body or putting the shifter in a truck with OD? Hoping to use the shifter in my truck. My factory shifter is worn and sloppy, I figured an upgrade to the comp plus would tighten things up considerably. PLUS, it comes with the pistol grip shifter I've been wanting to add as well! It will work but you may need to make the 3-4 rod longer Gus
64 Plymouth Savoy 493 Indy EZ's by Nick at Compu-Flow 5-Speed Richmond faceplate Liberty box Dana 60
Re: 833 Questions
[Re: fourgearsavoy]
#2779501
05/29/20 03:16 PM
05/29/20 03:16 PM
JD340
Are you putting an OD in a B body or putting the shifter in a truck with OD? Hoping to use the shifter in my truck. My factory shifter is worn and sloppy, I figured an upgrade to the comp plus would tighten things up considerably. PLUS, it comes with the pistol grip shifter I've been wanting to add as well! It will work but you may need to make the 3-4 rod longer Gus Are you talking adjustment wise, or actually making the rod longer? Could I use the original 3-4 rod instead?
Re: 833 Questions
[Re: JD340]
#2779630
05/29/20 09:41 PM
05/29/20 09:41 PM
fourgearsavoy
Rittman Ohio
If you use the B body shifter mounting pad you wont have to do any thing at all. But if you used the raised bracket for the truck trans you may need to lengthen one or more rods if you run out of threads. Gus
Re: 833 Questions
[Re: fourgearsavoy]
#2779657
05/30/20 12:56 AM
05/30/20 12:56 AM
Posts: 6,008 Salem
Grizzly
Salem
I looked up a picture of the shifter and if I got the right image, it sure looks alot like a stock shifter? This is just me, but I would just re-build and re-grease the truck shifter (it is a Hurst shifter), cut the end off, weld on the pistol grip, and modify for shorter throws. That's what I did to shorten the shifts on my current 833od in an E-Body and it's awesome. The throws are about 4 to 5 inches long, maybe less.........haven't driven it since last year.
Mo' Farts
