trans ptk #2778933
05/27/20 11:00 PM
05/27/20 11:00 PM
s. e. pa.
calrobb2000 Offline OP
s. e. pa.
hi
got a 73 360 727 trans that ptk not working ?
has a tf-2 kit
trans currently set to shift wot at 5400 this works good prob will raise to 56 - 5800
stock spring for psi relief adjusted high as it can get
can too high psi cause this ? throttle or line ?
also no wot kick down above 20 mph ?
1/2 shift control valve blocked
ideas ?
thank you !
Re: trans ptk [Re: calrobb2000] #2779024
05/28/20 10:58 AM
05/28/20 10:58 AM
Aurora, Colorado
451Mopar Offline
451Mopar  Offline
Aurora, Colorado
That does not sound like a TF-2 kit?
Does the valve body have the extra part throttle kickdown assembly?
I din't recall theTF-2 using a shift valve blocker rod, and uses a different pressure regulator spring with a washer with an edge missing. This is how the newer TF-2 kits come.
I know the old TF-2 kits were a bit different?
Re: trans ptk [Re: calrobb2000] #2779050
05/28/20 12:29 PM
05/28/20 12:29 PM
Moved to N.E. Tennessee
GomangoCuda Offline
GomangoCuda  Offline
I think you have it all out of wack trying to raise the shift points. You do that by changing the weights in the Governor not by messing with the pressures and throttle pressure linkage.
Put everything back exactly the way transgo said to do it, don't improvise. Do not mix parts or instructions between different kits or stages of kits. Don't presume that you or a Chevy buddy know how to do it better than transgo.
Does your trans have the proper servo for part throttle kickdown and is the transgo kit compatible with part throttle kickdown? I don't know about transgos kit but The kit that Mopar used to sell eliminated part throttle kickdown.
Is the throttle pressure linkage properly adjusted or are you improperly trying to raise shift points with this adjustment?
Unfortunately if you continue down this road I predict total transmission failure in your near future.
Note: If I have made incorrect assumptions about what you are doing or you are offended in any way then I am sorry and you can feel free to disregard this post.
Re: trans ptk [Re: calrobb2000] #2779051
05/28/20 12:32 PM
05/28/20 12:32 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
Did you install the Transgo black spring in the PTK module? That spring lowers the road speed at which PTK is locked out.
Re: trans ptk [Re: GomangoCuda] #2779062
05/28/20 12:52 PM
05/28/20 12:52 PM
A727Tflite Offline
A727Tflite  Offline
Part throttle kickdown will function with either front servo.
Re: trans ptk [Re: John_Kunkel] #2779107
05/28/20 02:31 PM
05/28/20 02:31 PM
s. e. pa.
s. e. pa.
hi john
thats the thing , had the stock spring and wot kickdown worked at app 35 mph .
installed a weeker spring and now it is down to 20 mph before it will downshift at wot and still no ptk ?
2nd identical valve body and same result ?
Re: trans ptk [Re: calrobb2000] #2779131
05/28/20 03:33 PM
05/28/20 03:33 PM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You have to realize that some of the TF-2 mods can have unintended consequences for some users. For example, if you shortened the throttle valve, WOT kickdown might not kickdown if the linkage adjustment is iffy.
My oft-repeated advice, make sure that WOT in the engine compartment is WOT at the pedal; have somebody sit in the car and floor the throttle then, from under the hood, push back on the carb lever to make sure it's actually wide open and make sure the trans linkage is close to full back.
Re: trans ptk [Re: John_Kunkel] #2779317
05/29/20 12:08 AM
05/29/20 12:08 AM
s. e. pa.
s. e. pa.
hi
with this kit shift rpm is determined by how far the throttle rod moves the valve .
sooo havent adjusted it full back as i was trying to get ptk working , it was full back before kit install, and still no ptk , and shift points were 4600
with it full back now kit claim is 7000 rpm shifts ! i can adjust it some more but dont need more than 5800- 6000 rpm . 5200 now
Re: trans ptk [Re: calrobb2000] #2779327
05/29/20 02:43 AM
05/29/20 02:43 AM
Rio Linda, CA
John_Kunkel Offline
John_Kunkel  Offline
Rio Linda, CA
You're saying the Transgo TF-2 kit claims 7000 rpm upshifts? Must be something new.
