Re: trans ptk
[Re: calrobb2000]
#2779050
05/28/20 12:29 PM
05/28/20 12:29 PM
Posts: 4,712 Moved to N.E. Tennessee
GomangoCuda
I think you have it all out of wack trying to raise the shift points. You do that by changing the weights in the Governor not by messing with the pressures and throttle pressure linkage.
Put everything back exactly the way transgo said to do it, don't improvise. Do not mix parts or instructions between different kits or stages of kits. Don't presume that you or a Chevy buddy know how to do it better than transgo.
Does your trans have the proper servo for part throttle kickdown and is the transgo kit compatible with part throttle kickdown? I don't know about transgos kit but The kit that Mopar used to sell eliminated part throttle kickdown. Is the throttle pressure linkage properly adjusted or are you improperly trying to raise shift points with this adjustment?
Unfortunately if you continue down this road I predict total transmission failure in your near future.
Note: If I have made incorrect assumptions about what you are doing or you are offended in any way then I am sorry and you can feel free to disregard this post.
Re: trans ptk
[Re: calrobb2000]
#2779051
05/28/20 12:32 PM
05/28/20 12:32 PM
Posts: 25,750 Rio Linda, CA
John_Kunkel
Rio Linda, CA
Did you install the Transgo black spring in the PTK module? That spring lowers the road speed at which PTK is locked out.
Re: trans ptk
[Re: GomangoCuda]
#2779062
05/28/20 12:52 PM
05/28/20 12:52 PM
Posts: 3,069 Michigan
A727Tflite
Note: If I have made incorrect assumptions about what you are doing or you are offended in any way then I am sorry and you can feel free to disregard this post. Part throttle kickdown will function with either front servo.
Re: trans ptk
[Re: calrobb2000]
#2779131
05/28/20 03:33 PM
05/28/20 03:33 PM
John_Kunkel
Rio Linda, CA
You have to realize that some of the TF-2 mods can have unintended consequences for some users. For example, if you shortened the throttle valve, WOT kickdown might not kickdown if the linkage adjustment is iffy.
My oft-repeated advice, make sure that WOT in the engine compartment is WOT at the pedal; have somebody sit in the car and floor the throttle then, from under the hood, push back on the carb lever to make sure it's actually wide open and make sure the trans linkage is close to full back.
Re: trans ptk
[Re: calrobb2000]
#2779327
05/29/20 02:43 AM
05/29/20 02:43 AM
John_Kunkel
Rio Linda, CA
You're saying the Transgo TF-2 kit claims 7000 rpm upshifts? Must be something new.
