3/8" or 1/2" fuel line for a 505 #2778632
05/27/20 10:07 AM
05/27/20 10:07 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Starting on our 71 RR, engine is a 10.7 Cr 440 stroker in front of a built 727 and 3.54s, Beefed up 11" convertor
Dynoed at 620 HP, 640 TQ, RPMs limit at 6000. Solid roller.
This is primarily a street car, 4000# may be one or two outings to sort out suspension etc.
Electric pump only, single 950, dual plane MW Indy, Max wedge Victors.
I'm thinking 3/8" should suffice, but before I spring for the lines, I thought I'd see what the masters think.
Thanks, Joe
Re: 3/8" or 1/2" fuel line for a 505 [Re: jlatessa] #2778634
05/27/20 10:11 AM
05/27/20 10:11 AM
AZ
squirrel Offline
squirrel  Offline
AZ
3/8" will probably suffice, so get 1/2" so it's not questionable.
Re: 3/8" or 1/2" fuel line for a 505 [Re: squirrel] #2778636
05/27/20 10:13 AM
05/27/20 10:13 AM
Martinsville, IN
cdwmotorsports Online content
cdwmotorsports  Online Content
Martinsville, IN
I have 1/2" on my 451. I don't like having to buy things twice
eBay-cdwmotorsports
Re: 3/8" or 1/2" fuel line for a 505 [Re: cdwmotorsports] #2778642
05/27/20 10:20 AM
05/27/20 10:20 AM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Haven't looked yet, but does Fine Lines supply a !/2"?
Also, what do I do for a sending unit, redo a 3/8"?
Std tank.
Thanks, Joe
Re: 3/8" or 1/2" fuel line for a 505 [Re: jlatessa] #2778646
05/27/20 10:24 AM
05/27/20 10:24 AM
AZ
squirrel Offline
squirrel  Offline
AZ
Put a new 1/2" pickup at the bottom rear of the tank? yes, it takes work.
Re: 3/8" or 1/2" fuel line for a 505 [Re: cdwmotorsports] #2778647
05/27/20 10:24 AM
05/27/20 10:24 AM
A collage of whims
topside Offline
topside  Offline
A collage of whims
I've done both, but have fed a stout 512 with 3/8" and a good mech pump & regulator without issues.
For a street car I wouldn't worry about the 1/2".
For dual quads, high RPM, or drag racing, I'd go 1/2".
Re: 3/8" or 1/2" fuel line for a 505 [Re: topside] #2778663
05/27/20 11:09 AM
05/27/20 11:09 AM
MR_P_BODY Offline
MR_P_BODY  Offline
Nicely made(no kinks) 3/8 is fine.. one kink and your done.. a few places make 3/8 pick ups..
I use to make my own
wave
Re: 3/8" or 1/2" fuel line for a 505 [Re: MR_P_BODY] #2778664
05/27/20 11:15 AM
05/27/20 11:15 AM
Wichita
GY3 Offline
GY3  Offline
Wichita
3/8" will be more than enough.
'63 Dodge 330
11.19 @ 121 mph
Re: 3/8" or 1/2" fuel line for a 505 [Re: GY3] #2778673
05/27/20 11:36 AM
05/27/20 11:36 AM
East Coast
A/MP Offline
A/MP  Offline
East Coast
For a street car 3/8. If you expect hard launches, then 1/2. When you launch, you need to overcome the force that pushes you back in the seat. It does the same thing to the fuel in the line. Bowls are full at the launch and run out of fuel pretty fast. The more volume in the line, the easier it is to recoop that inertia of the launch. Its only an 1/8 larger so no big difference in cost. One less issue to think about when you are sorting things out.
Re: 3/8" or 1/2" fuel line for a 505 [Re: jlatessa] #2778684
05/27/20 11:52 AM
05/27/20 11:52 AM
Rittman Ohio
fourgearsavoy Offline
Rittman Ohio
Hey Joe I don't know where you are in Ohio but you can pick up your lines at Fine Lines direct in Wadsworth and avoid the lines bent in half when they ship them. I had 3/8" on my Savoy when I had a 440 in it and when I changed to a high volume pump and 493 I switched to 1/2". I never had issues with the smaller line I just was changing every thing else in the fuel system so I just upgraded to a cleaner system with smoother bends twocents
Gus beer
64 Plymouth Savoy
Dana 60
Re: 3/8" or 1/2" fuel line for a 505 [Re: fourgearsavoy] #2778699
05/27/20 12:02 PM
05/27/20 12:02 PM
North Carolina
sasquatch Offline
sasquatch  Offline
North Carolina
Pretty sure Vans Auto has the 1/2 inch pickups in stock.
Re: 3/8" or 1/2" fuel line for a 505 [Re: sasquatch] #2778733
05/27/20 01:28 PM
05/27/20 01:28 PM
Shelby mi.
JAKE68 Offline
JAKE68  Offline
Shelby mi.
Just a short story. Ron mancini had a b-1 powered car that made around 950 hp. It had two carter fuel pumps and 3/8 line. So someone told him he would pick up big time going to 1/2 and a better fuel system. He went complete system with 1/2 with magna fuel system. Never picked up at all. So to answer your question 3/8 will be fine.
JAKES AUTOMOTIVE
Re: 3/8" or 1/2" fuel line for a 505 [Re: jlatessa] #2778745
05/27/20 02:09 PM
05/27/20 02:09 PM
Are you talking about the outside diameter or inside diameter of the new line?
if inside diameter 3/8 inch is fine, if outside diameter go with the 1/2 inch up
What brand and size electric pump are you going too use?
Not all of them work good whiney
Re: 3/8" or 1/2" fuel line for a 505 [Re: Cab_Burge] #2778769
05/27/20 03:22 PM
05/27/20 03:22 PM
MR_P_BODY Offline
MR_P_BODY  Offline
Cab.. tubing is measured on the OD.. 3/8 will work fine for a street car
wave
Re: 3/8" or 1/2" fuel line for a 505 [Re: jlatessa] #2778782
05/27/20 04:08 PM
05/27/20 04:08 PM
Prospect, PA
BSB67 Offline
BSB67  Offline
Prospect, PA
Mine is similar to yours in a lot of ways. 508 street car, small roller, shift around 6400, Indy dual plane, 950 carb with 0.110" N&S, stock converter. 4150 lbs and runs in the high 11s at 120 mph with a 1.9 sec 60 ft.
I have 3/8" line and a Mallory 140 pump regulated to 6 psi. It runs about 4 psi down the track and through the traps. If you're lifting the tires off the ground, consider 1/2".
Re: 3/8" or 1/2" fuel line for a 505 [Re: BSB67] #2778799
05/27/20 04:43 PM
05/27/20 04:43 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I've posted it here before and people tend not to believe so....
I've ran 11.19 @ 121 mph in a 3,600 lbs. car with the slant 6 OE 5/16 fuel line from tank to Carter street/strip pump. 3/8 from pump to carb. Stock (replacement) tank and pickup.
'63 Dodge 330
11.19 @ 121 mph
Re: 3/8" or 1/2" fuel line for a 505 [Re: GY3] #2778868
05/27/20 07:51 PM
05/27/20 07:51 PM
Ohio
jlatessa Offline OP
jlatessa  Offline OP
Ohio
Thanks guys, I've decided 3/8.
Thanks fourgear, I am picking up from fineLines, an hour drive for me,
did the same for our 440 Charger.
Thank you all for your input.
Joe
