3/8" or 1/2" fuel line for a 505
#2778632
05/27/20 10:07 AM
05/27/20 10:07 AM
Posts: 1,317 Ohio
jlatessa
Ohio
Starting on our 71 RR, engine is a 10.7 Cr 440 stroker in front of a built 727 and 3.54s, Beefed up 11" convertor
Dynoed at 620 HP, 640 TQ, RPMs limit at 6000. Solid roller.
This is primarily a street car, 4000# may be one or two outings to sort out suspension etc.
Electric pump only, single 950, dual plane MW Indy, Max wedge Victors.
I'm thinking 3/8" should suffice, but before I spring for the lines, I thought I'd see what the masters think.
Thanks, Joe
Re: 3/8" or 1/2" fuel line for a 505
[Re: MR_P_BODY]
#2778664
05/27/20 11:15 AM
05/27/20 11:15 AM
Posts: 4,669 Wichita
GY3
Wichita
3/8" will be more than enough.
[Re: sasquatch]
#2778733
05/27/20 01:28 PM
05/27/20 01:28 PM
Posts: 1,495 Shelby mi.
JAKE68
Shelby mi.
Just a short story. Ron mancini had a b-1 powered car that made around 950 hp. It had two carter fuel pumps and 3/8 line. So someone told him he would pick up big time going to 1/2 and a better fuel system. He went complete system with 1/2 with magna fuel system. Never picked up at all. So to answer your question 3/8 will be fine.
JAKES AUTOMOTIVE
[Re: jlatessa]
#2778745
05/27/20 02:09 PM
05/27/20 02:09 PM
Posts: 43,118 Bend,OR USA
Cab_Burge
Are you talking about the outside diameter or inside diameter of the new line? if inside diameter 3/8 inch is fine, if outside diameter go with the 1/2 inch What brand and size electric pump are you going too use? Not all of them work good
[Re: jlatessa]
#2778782
05/27/20 04:08 PM
05/27/20 04:08 PM
Posts: 4,311 Prospect, PA
BSB67
Prospect, PA
Mine is similar to yours in a lot of ways. 508 street car, small roller, shift around 6400, Indy dual plane, 950 carb with 0.110" N&S, stock converter. 4150 lbs and runs in the high 11s at 120 mph with a 1.9 sec 60 ft.
I have 3/8" line and a Mallory 140 pump regulated to 6 psi. It runs about 4 psi down the track and through the traps. If you're lifting the tires off the ground, consider 1/2".
[Re: BSB67]
#2778799
05/27/20 04:43 PM
05/27/20 04:43 PM
GY3
Wichita
I've posted it here before and people tend not to believe so....
I've ran 11.19 @ 121 mph in a 3,600 lbs. car with the slant 6 OE 5/16 fuel line from tank to Carter street/strip pump. 3/8 from pump to carb. Stock (replacement) tank and pickup.
