2011 Ram electrical problems
#2778553
05/26/20 11:06 PM
05/26/20 11:06 PM
Posts: 12,419 Kalispell Mt.
HotRodDave
Kalispell Mt.
My 2011 ram 1500 front windows sometimes don't work and sometimes they do. It seems like if they work on one key cycle they work great the rest of that key cycle until the next key cycle when they again may or may not work for the entire key cycle. I tried a switch off one of my other trucks that has no issues and this one still has the same issue and the other one works fine with this old switch, also tried the door module and same story.
Another thing it has done is all the gauges will randomly stop working for about 2 seconds and then come right back on like as if you just started the truck. This only happens about 1 out of 5 times I drive it. The engine does not shut off or nothing, it just keeps driving on down the road fine.
Re: 2011 Ram electrical problems
[Re: HotRodDave]
#2824207
09/23/20 04:48 PM
09/23/20 04:48 PM
HotRodDave
Kalispell Mt.
Just thought I would update everyone incase someone is looking in the future for a cure, I put in a new door module and problem solved
