build sheet #2776618
05/20/20 10:07 PM
05/20/20 10:07 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
Im helping out a friend sort out a 67 rt dana car stick. the build sheet calls the engine an (83) which is 440 4 bl hp. the block was a 66 with an C on the pad not an hp. I know this car from 67 I don't believe this block was ever change. its original to the car. does the C stand for commando engine? would Chrysler put a 66 block in a 67 car out of the factory. The other confusing engine code on the build sheet calls it a 449. could that be an over bored 440?? the door tag calls for an L engine as well. any one familiar with the decoding.
Re: build sheet [Re: dart9ss] #2776628
05/20/20 11:01 PM
05/20/20 11:01 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
c is for 67, d 68 ect
Re: build sheet [Re: CSK] #2776630
05/20/20 11:06 PM
05/20/20 11:06 PM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
thanks csk why no H P on the pad? Its got the right heads?
Re: build sheet [Re: dart9ss] #2776632
05/20/20 11:13 PM
05/20/20 11:13 PM
Pattison Texas
CSK Offline
CSK  Offline
Pattison Texas
I have no answer for that, Im sure someone will chime in.
Re: build sheet [Re: dart9ss] #2776634
05/20/20 11:32 PM
05/20/20 11:32 PM
Cab_Burge Online work
Cab_Burge  Online Work
Are the 915 heads hand stamp HP?
You need to keep in mind that Mopar had been using the low po 350, 355, non HP 440 motors in C bodies cars in 1966, not in the Dodge or Plymouth B body cars until mid year 1967 shruggy
I've seen several original 1967 Dodge RT/T 440 motors, I don't remember if any of those had HP stamp on the upper pad or not back then.
Maybe the HP stamping started in 1968 along with the motor numbers hand stamping #s matching the body VIN #s confused
Re: build sheet [Re: Cab_Burge] #2776652
05/21/20 05:40 AM
05/21/20 05:40 AM
nj pine beach
dart9ss Offline OP
dart9ss  Offline OP
nj pine beach
thanks Cab. we are looking under the valve covers today for the head #s.
Re: build sheet [Re: dart9ss] #2778467
05/26/20 06:58 PM
05/26/20 06:58 PM
Big Sky Country
MO_PA Offline
MO_PA  Offline
Big Sky Country
My 66 Sport Fury convertible came from the factory with the 365hp 440, and of course no HP on the block. Had 516 heads same as the 426S engines.
Re: build sheet [Re: MO_PA] #2778931
05/27/20 10:45 PM
05/27/20 10:45 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
YES, they started making 1967 cars in summer of 1966. So yes many many have 1966 dated C 440 HP blocks. They all have HPstamped blocks from the factory. Engine code L in the vin means HP on the block. C body and B body.
Dart9ss you need to stick around and learn what the numbers on a build sheet mean. The 449 is the last 3 digits of the part number, not cubic inches.
C is 1967, it will say that in the top left corner your broadcast sheet. And the sequence number starts with C for 1967
And the part number is not always the casting number.
Can you post the broadcast sheet or fender tag so we can see dates and things? I could decode the whole car for you. No fee, no waiting, like GTs. LOL
Re: build sheet [Re: NANKET] #2779274
05/28/20 10:00 PM
05/28/20 10:00 PM
northwest USA
N
NANKET Offline
NANKET  Offline
N
northwest USA
1967 hemi is #447 that’s not cubic inches.
