Page 4 of 5 1 2 3 4 5
Re: Anything wrong with a Fram PH8a for racecar? [Re: ZIPPY] #2777968
05/25/20 10:08 AM
05/25/20 10:08 AM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
Originally Posted by ZIPPY
Buddy of mine lost oil pressure completely with a K&N.
The tests I have seen have not rated the K&N highly.
Re: Anything wrong with a Fram PH8a for racecar? [Re: Cab_Burge] #2778095
05/25/20 03:26 PM
05/25/20 03:26 PM
In The Hills
jughed Offline
jughed  Offline
In The Hills
Originally Posted by Cab_Burge
I've cut a bunch of Fram oil filters apart starting back in early 1970s, I stop using them when they went cheap down
Wix only now up, not the high bypass race filters either twocents
I use both types of Wix. I think I'll stock up on more of them....you never know when a company will go the cheap Chinese route (like Fram did).
End those annoying Infolink ads with AdBlockPlus
https://adblockplus.org/
Re: Anything wrong with a Fram PH8a for racecar? [Re: jughed] #2778317
05/26/20 12:12 PM
05/26/20 12:12 PM
moparx Offline
moparx  Offline
at one time, there was a group buy for WIX filters.
is that still in effect ? [i haven't researched this]
beer
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparx] #2778323
05/26/20 12:17 PM
05/26/20 12:17 PM
PA.
pittsburghracer Offline
"Little"John
"Little"John
PA.
beer
I get mine locally at napa. The girl that works there calls me twice a year when they have their 40-50 percent off sale. I just bought 125.00 worth for my motorhome, truck, car, and race cars.
https://board.moparts.org/ubbthread...-filters-for-moparts-members.html#UNREAD
1970 Duster
Edelbrock headed 408
5.984@112.52
422 Indy headed small block
5.982@112.56 mph
9.42@138.27
Re: Anything wrong with a Fram PH8a for racecar? [Re: pittsburghracer] #2778330
05/26/20 12:32 PM
05/26/20 12:32 PM
moparx Offline
moparx  Offline
yeah john, i just missed that sale this year !
any chance for a heads up when the second one will be ?
my napa is only two miles away.
beer
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparx] #2778358
05/26/20 02:07 PM
05/26/20 02:07 PM
PA.
"Little"John
"Little"John
PA.
beer
I posted about it on abodyonly when it started. I will try to remember to remind you buddy.
1970 Duster
5.984@112.52
5.982@112.56 mph
9.42@138.27
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparx] #2778367
05/26/20 02:34 PM
05/26/20 02:34 PM
Tulsa, Oklahoma
340Cuda Offline
340Cuda  Offline
Tulsa, Oklahoma
beer
Yes there is:
Re: Anything wrong with a Fram PH8a for racecar? [Re: 340Cuda] #2778410
05/26/20 04:33 PM
05/26/20 04:33 PM
NW Chicago suburban area
Mopar Mitch Offline
Mopar Mitch  Offline
I was planning to use the Fram PH8A as an initial startup filter with hi-Zinc break-in motor oil... figure ~2-hours max (flat tappet, hyd)... then change the springs, etc... and then throw away that Fram PH8a for a better filter... racing PH1 or other as I've always used throughout the season..
Any opinions on just using the PH8a as a quick break-in then throw away filter?
Re: Anything wrong with a Fram PH8a for racecar? [Re: Mopar Mitch] #2778413
05/26/20 04:41 PM
05/26/20 04:41 PM
AndyF Offline
AndyF  Offline
Odds are that it will work just fine.
Re: Anything wrong with a Fram PH8a for racecar? [Re: Mopar Mitch] #2778441
05/26/20 06:01 PM
05/26/20 06:01 PM
Are you feeling lucky? devil
Why take a chance work,
Buy and use a good filter on your new motor up twocents
BTW, I run my new motors with flat tappet cams for 20 to 30 minutes at or above 1500 RPM to break in the cam and lifters and then change the oil and filter and cut the filter open for inspection before running the motor again with the new oil and filter up scope
The reason for me doing this is I have had two brand new hydraulic flat tappet camshafts that had no taper ground on the lobes and they both started eating the lobes in those 20 to 30 minutes which was trapped in the Wix oil filters up
Murphy loves messing with us hot rodders and racers whiney
Re: Anything wrong with a Fram PH8a for racecar? [Re: Mopar Mitch] #2778447
05/26/20 06:10 PM
05/26/20 06:10 PM
Guitar Jones Online laugh2
Why do you hate your engine? laugh2 Why would you spend thousands of dollars on a new engine then cheap out and not spend $6 or $7 for a good filter?
Re: Anything wrong with a Fram PH8a for racecar? [Re: Cab_Burge] #2778448
05/26/20 06:10 PM
05/26/20 06:10 PM
PA
moparacer Offline
moparacer  Offline
PA
Orange canister of death lol. Never heard that one.
I have used the Fram HP racing filters on my engines before in a pinch and broke them in with whatever is cheap I can get my hands on at the time. Never had one collapse. Mostly I use a system 1 filter.
Honestly I think the Fram filter collapsing thing is the exception not the norm.
67 Barracuda street/bracket car 11.27-119
68 Dart 502 BB 8.70s-152
414 cid SB Dragster 7.65-174
Re: Anything wrong with a Fram PH8a for racecar? [Re: moparacer] #2778462
05/26/20 06:46 PM
05/26/20 06:46 PM
Florida STAYcation
BeEtLeJuIcE ! Offline
The village idiot's idiot
Florida STAYcation
Someone from the LEFTY COAST needs a really good filter TO FILTER OUT those excessive smilies ! tsk grin
AND ... if a good filter is required AT ALL it’s during the break in period ... whistling
Re: Anything wrong with a Fram PH8a for racecar? [Re: BeEtLeJuIcE !] #2778481
05/26/20 07:29 PM
05/26/20 07:29 PM
Florida STAYcation
Florida STAYcation
I wonder if that musik guy ever used a TP canister type ... rumor has it that Charmin has the bestest filtering quality’s. !!
Re: Anything wrong with a Fram PH8a for racecar? [Re: BeEtLeJuIcE !] #2778485
05/26/20 07:36 PM
05/26/20 07:36 PM
tboomer Offline
tboomer  Offline
Stay on topic Doc... work
Re: Anything wrong with a Fram PH8a for racecar? [Re: tboomer] #2778532
05/26/20 09:42 PM
05/26/20 09:42 PM
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters?
I wish I could remember the name of that company, I never used them either tsk
Man I must be getting old, HUH DOC grin
Re: Anything wrong with a Fram PH8a for racecar? [Re: Cab_Burge] #2778565
05/27/20 12:21 AM
05/27/20 12:21 AM
Auburn WA
Dave_J Offline
Dave_J  Offline
Auburn WA
Frantz was one.
Retired, US ARMY 1973-1994
ASE mechanic, Electrical 1994-1997
Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter
65 Formula S Cuda
78 Little Red Express Truck
98 Buick Regal (wifes car)
Re: Anything wrong with a Fram PH8a for racecar? [Re: Dave_J] #2778582
05/27/20 03:12 AM
05/27/20 03:12 AM
Frantz was one.
That sounds correct, THANKS up
Re: Anything wrong with a Fram PH8a for racecar? [Re: Cab_Burge] #2778707
05/27/20 12:21 PM
05/27/20 12:21 PM
Pattison Texas
CSK Online shake_head
CSK  Online Shake_Head
Pattison Texas
Frantz was one.
Amsoil Sold the same thing , not sure if they still do.
Re: Anything wrong with a Fram PH8a for racecar? [Re: CSK] #2778751
05/27/20 02:30 PM
05/27/20 02:30 PM
S.E. South Dakota !
bigdad Offline
Still Posting A Lot
bigdad  Offline
Still Posting A Lot
S.E. South Dakota !
Friend used a K & N on a furd , it blew the canister apart and he almost crashed .. I'll pass on those also
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
