Re: Anything wrong with a Fram PH8a for racecar?
[Re: ZIPPY]
#2777968
05/25/20 10:08 AM
05/25/20 10:08 AM
Posts: 3,514 Tulsa, Oklahoma
340Cuda
Tulsa, Oklahoma
Buddy of mine lost oil pressure completely with a K&N.
The tests I have seen have not rated the K&N highly.
[Re: Cab_Burge]
#2778095
05/25/20 03:26 PM
05/25/20 03:26 PM
Posts: 1,229 In The Hills
jughed
In The Hills
I've cut a bunch of Fram oil filters apart starting back in early 1970s, I stop using them when they went cheap Wix only now , not the high bypass race filters either I use both types of Wix. I think I'll stock up on more of them....you never know when a company will go the cheap Chinese route (like Fram did).
[Re: moparx]
#2778323
05/26/20 12:17 PM
05/26/20 12:17 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
at one time, there was a group buy for WIX filters. is that still in effect ? [i haven't researched this] I get mine locally at napa. The girl that works there calls me twice a year when they have their 40-50 percent off sale. I just bought 125.00 worth for my motorhome, truck, car, and race cars. https://board.moparts.org/ubbthread...-filters-for-moparts-members.html#UNREAD
[Re: pittsburghracer]
#2778330
05/26/20 12:32 PM
05/26/20 12:32 PM
Posts: 19,406 north of coder
moparx
yeah john, i just missed that sale this year ! any chance for a heads up when the second one will be ? my napa is only two miles away.
[Re: moparx]
#2778358
05/26/20 02:07 PM
05/26/20 02:07 PM
Posts: 20,174 PA.
pittsburghracer
"Little"John
"Little"John
PA.
yeah john, i just missed that sale this year ! any chance for a heads up when the second one will be ? my napa is only two miles away. I posted about it on abodyonly when it started. I will try to remember to remind you buddy.
[Re: 340Cuda]
#2778410
05/26/20 04:33 PM
05/26/20 04:33 PM
Posts: 1,442 NW Chicago suburban area
Mopar Mitch
I was planning to use the Fram PH8A as an initial startup filter with hi-Zinc break-in motor oil... figure ~2-hours max (flat tappet, hyd)... then change the springs, etc... and then throw away that Fram PH8a for a better filter... racing PH1 or other as I've always used throughout the season..
Any opinions on just using the PH8a as a quick break-in then throw away filter?
Mopar Mitch
"Road racers and autocrossers go in deeper and come out harder!"... and rain never stops us from having fun with our cars... in fact, it makes us better drivers!
Check out MOPAR ACTION MAGAZINE, August 2006 issue for feature article and specs on my autocross T/A!
[Re: Mopar Mitch]
#2778441
05/26/20 06:01 PM
05/26/20 06:01 PM
Posts: 43,181 Bend,OR USA
Cab_Burge
Any opinions on just using the PH8a as a quick break-in then throw away filter? Are you feeling lucky? Why take a chance , Buy and use a good filter on your new motor BTW, I run my new motors with flat tappet cams for 20 to 30 minutes at or above 1500 RPM to break in the cam and lifters and then change the oil and filter and cut the filter open for inspection before running the motor again with the new oil and filter The reason for me doing this is I have had two brand new hydraulic flat tappet camshafts that had no taper ground on the lobes and they both started eating the lobes in those 20 to 30 minutes which was trapped in the Wix oil filters Murphy loves messing with us hot rodders and racers
[Re: Mopar Mitch]
#2778447
05/26/20 06:10 PM
05/26/20 06:10 PM
Guitar Jones
Any opinions on just using the PH8a as a quick break-in then throw away filter? Why do you hate your engine? Why would you spend thousands of dollars on a new engine then cheap out and not spend $6 or $7 for a good filter?
[Re: Cab_Burge]
#2778448
05/26/20 06:10 PM
05/26/20 06:10 PM
Posts: 2,505 PA
moparacer
PA
Orange canister of death lol. Never heard that one.
I have used the Fram HP racing filters on my engines before in a pinch and broke them in with whatever is cheap I can get my hands on at the time. Never had one collapse. Mostly I use a system 1 filter.
Honestly I think the Fram filter collapsing thing is the exception not the norm.
67 Barracuda street/bracket car 11.27-119 68 Dart 502 BB 8.70s-152 414 cid SB Dragster 7.65-174
[Re: tboomer]
#2778532
05/26/20 09:42 PM
05/26/20 09:42 PM
Cab_Burge
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters? I wish I could remember the name of that company, I never used them either Man I must be getting old, HUH DOC
[Re: Cab_Burge]
#2778565
05/27/20 12:21 AM
05/27/20 12:21 AM
Posts: 3,122 Auburn WA
Dave_J
Auburn WA
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters? I wish I could remember the name of that company, I never used them either Man I must be getting old, HUH DOC Frantz was one.
Retired, US ARMY 1973-1994 ASE mechanic, Electrical 1994-1997 Retired GTE/VERIZON/FRONTIER 1997-2015
03 Suzuki Burgman 650(Burger King) Scooter 65 Formula S Cuda 78 Little Red Express Truck 98 Buick Regal (wifes car)
[Re: Dave_J]
#2778582
05/27/20 03:12 AM
05/27/20 03:12 AM
Cab_Burge
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters? I wish I could remember the name of that company, I never used them either Man I must be getting old, HUH DOC Frantz was one. That sounds correct, THANKS
[Re: Cab_Burge]
#2778707
05/27/20 12:21 PM
05/27/20 12:21 PM
Posts: 2,861 Pattison Texas
CSK
Pattison Texas
You don't remember all the hype on T.V. in the late 1950 and early 1960 selling those add on oil filters that used T.P rolls instead of using standard oil filters? I wish I could remember the name of that company, I never used them either Man I must be getting old, HUH DOC Frantz was one. That sounds correct, THANKS Amsoil Sold the same thing , not sure if they still do.
[Re: CSK]
#2778751
05/27/20 02:30 PM
05/27/20 02:30 PM
Posts: 34,904 S.E. South Dakota !
bigdad
Still Posting A Lot
Still Posting A Lot
S.E. South Dakota !
Friend used a K & N on a furd , it blew the canister apart and he almost crashed .. I'll pass on those also
The lips of fools bring them strife, and their mouths invite a beating.Proverbs 18:6
