Driveshaft Loop ? #2777720
05/24/20 03:59 PM
05/24/20 03:59 PM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Does anyone use the driveshaft loop that Mancini used to sell for Mopars ? Its the one that bolts to the trans crossmember as I cant find one anywhere so far and was wondering if anyone uses it and how they like it ? And is it still sold ? Thanks , Ron
Re: Driveshaft Loop ? [Re: 383man] #2777731
05/24/20 04:20 PM
05/24/20 04:20 PM
Ambridge, Pa.
rickraw Offline
rickraw  Offline
Ambridge, Pa.
I heard and don't quote me that their not legal for drag racing. A friend told me this yrs ago.
Re: Driveshaft Loop ? [Re: rickraw] #2777741
05/24/20 05:02 PM
05/24/20 05:02 PM
New York
polyspheric Offline
polyspheric  Offline
New York
IIRC has to be behind the front U-joint?
Boffin Emeritus
Re: Driveshaft Loop ? [Re: polyspheric] #2777746
05/24/20 05:17 PM
05/24/20 05:17 PM
MR_P_BODY Offline
MR_P_BODY  Offline
It does.. those had a long arm on them to put it back there.. they allowed way to much wipp to them
if you did break a shaft or u-joint
wave
Re: Driveshaft Loop ? [Re: MR_P_BODY] #2777750
05/24/20 05:35 PM
05/24/20 05:35 PM
A collage of whims
topside Online content
topside  Online Content
A collage of whims
I have one I pulled off a car. With the extension needed to get the loop far enough back, it's pretty flexible.
The loop is just small enough that it rubbed the driveshaft, scoring it.
Kind of like a self-fulfilling prophecy but not in a good way.
Re: Driveshaft Loop ? [Re: topside] #2777870
05/24/20 10:57 PM
05/24/20 10:57 PM
CT
GTX MATT Offline
GTX MATT  Offline
CT
Ron, I think you're looking for the one made by U.S. car tool. http://store.uscartool.com/Bolt-In-Driveshaft-Loop-64-72-Mopar-B-Body-70-74-Mopar-E-Body_p_21.html
If they are really that flexible are there any loops that bolt in and fit well? The universal ones are really way too big to fit in a B body in the correct location relative to the U joint. I know pretty much every GM or Ford platform has cheap ones designed to bolt in...
Re: Driveshaft Loop ? [Re: rickraw] #2777919
05/25/20 07:25 AM
05/25/20 07:25 AM
Usa
A39Coronet Offline
A39Coronet  Offline
Usa
Your friend was mistaken.
Plus in all my racing experience, I don't think a tech ever got down on the ground to check for it.
Follow my G3 Hemi Barracuda build on Youtube
https://www.youtube.com/watch?v=XSDAWczXoZw&list=PLTus_wQu8POADHEeJNJp2nr4NMHEyB9EK
2015 Tri-State Stock Super Stock Champion
2017 Monster Mopar Pro Winner
2018 Monster Mopar No Box Winner
Re: Driveshaft Loop ? [Re: A39Coronet] #2777946
05/25/20 09:35 AM
05/25/20 09:35 AM
Byron, NY
W.I.N. Racing Offline
Byron, NY
iagree
If I were to use one of that type I would put a bolt and plate through the top of the loop to the floor at least. They will make you "Legal" tech wise but probably not actually work the best.
'01 P1500, Blown/Inj BAE,/Veney ,Bruno/CS2,Dana 60
'01 Dodge 3500 S Cummins Auto, Fresh air kit, 4" Exhaust,
'05 Dodge Magnum R/T - Too Much to list
'60 Willys CJ5
'01 International LPX - Project,DT466, Allison
'64 Plymouth Valiant, Inj 528 Hemi, 2spd
Re: Driveshaft Loop ? [Re: W.I.N. Racing] #2777949
05/25/20 09:39 AM
05/25/20 09:39 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
iagree
There is a hole for a carriage bolt to do that in the one I bought.
1969 Dart GTS 340
1969 Super Bee X9 N-96
1969 Coronet R/T X9 N-96
2015 Dodge Dart GT
2019 Ram 2500 Big Horn.
Looking for the original block for my Bee. The last 4 are 7449
Re: Driveshaft Loop ? [Re: OhioMopar] #2777965
05/25/20 10:05 AM
05/25/20 10:05 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks for the replies. I thought it looked kinda flimsy. I don't even know where to buy one even if I wanted one. Bolting a bracket to the loop to the floor is a great idea for it. Thanks , Ron
Re: Driveshaft Loop ? [Re: 383man] #2777993
05/25/20 11:09 AM
05/25/20 11:09 AM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I wouldn't say it's flimsy. It's a heavy sucker. I'd have to measure when I get back under it, but it's at least 1/8" steel. You would buy it through U.S. Cartool. That's who Mancini gets them from .
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Driveshaft Loop ? [Re: OhioMopar] #2778020
05/25/20 11:58 AM
05/25/20 11:58 AM
Richmond Twp. Mi.
Mr340 Offline
Mr340  Offline
Richmond Twp. Mi.
these require you drill thru the floor and only go back to '66
https://www.metcomotorsports.com/products.asp?cat=96
Re: Driveshaft Loop ? [Re: OhioMopar] #2778028
05/25/20 12:18 PM
05/25/20 12:18 PM
Bitopia
jcc Offline
jcc  Offline
Bitopia
I think maybe stating the "design" is flimsy might be more accurate.
Years back I addressed this cantilever shortcoming of the design directly with the manufacturer even with the single hole thru the floor, and after a few back and forths, he commented, "its not for racing", and then implied its more for the hobbyist that wants extra protection in a DS failure, and hard to argue with that sentiment.
I would not purchase one, FWIW.
Re: Driveshaft Loop ? [Re: jcc] #2778038
05/25/20 01:00 PM
05/25/20 01:00 PM
Mt.Gilead, Ohio
OhioMopar Offline
OhioMopar  Offline
Mt.Gilead, Ohio
I think I could agree with that.
I do find it odd that it's not for racing but carries NHRA and IHRA certification.
I think bolting it to the floor would help a great deal in its ability to withstand a driveshaft coming undone.
It would be interesting to see if anyone had a failure while using one and what the aftermath looked like.
1969 Dart GTS 340
2015 Dodge Dart GT
Re: Driveshaft Loop ? [Re: OhioMopar] #2778045
05/25/20 01:29 PM
05/25/20 01:29 PM
MR_P_BODY Offline
MR_P_BODY  Offline
1/8" doesnt meet NHRA standards.. has to be a 1/4" min and the long arm of it wouldnt slow
up much if the U-joint let go
wave
Re: Driveshaft Loop ? [Re: MR_P_BODY] #2778046
05/25/20 01:31 PM
05/25/20 01:31 PM
Byron, NY
Byron, NY
wave
iagree
'60 Willys CJ5
Re: Driveshaft Loop ? [Re: 383man] #2778147
05/25/20 07:27 PM
05/25/20 07:27 PM
Central Missouri Fort Leonard...
mopar65 Offline
mopar65  Offline
Ron what about one of these? I found it looking for one for my 96 Dakota.
3520 pound race ready 1973 Street/Strip Dodge Dart - Stock stroke 440/727 10.49 @ 125.0 on 93 pump gas & ET Street Radials. More to come... ( SGT Miller) Proudly served 12 years in the US ARMY RESERVES support our troops
Re: Driveshaft Loop ? [Re: A39Coronet] #2778150
05/25/20 07:36 PM
05/25/20 07:36 PM
Wichita
GY3 Offline
GY3  Offline
Wichita
I had a tech check mine last year.
'63 Dodge 330
11.19 @ 121 mph
Re: Driveshaft Loop ? [Re: 383man] #2778163
05/25/20 08:09 PM
05/25/20 08:09 PM
I have a older legal driveshaft loop from Mr. Gasket, I think, that fits in Mopar drive shaft tunnels fine.
It bolts to the floor so you can position it where you need it up
I'm thinking that you can weld tabs on one of those to use in your car work
The one I have bolts together so you can assemble it in the car with the drive shaft in or before installing it over the driveshaft disconnect at the rear end up
I will sell it if anyone wants it up
PM me if your interested.
Re: Driveshaft Loop ? [Re: Cab_Burge] #2778237
05/26/20 02:44 AM
05/26/20 02:44 AM
Balt. Md
3
383man Offline OP
383man  Offline OP
Balt. Md
Thanks guys. Yes I meant just a flimsy looking design. I have a loop on my car of course but its one I made and I don't think it would be legal. But as said I have never had a tech look under my car. In fact the last two years when I race in the NSS club as Cecil County in Md they tech the cars in right in the staging lanes and they never look at anything on my car. Thanks again , Ron
