Page 1 of 3 1 2 3
Out with the old. #2776910
05/22/20 03:58 AM
05/22/20 03:58 AM
Queensland,Australia
T-bar Offline OP
T-bar  Offline OP
This is my little update change over. 496 rb quickest run was 10.94 but want to go a bit quicker. So with a deal from an awesome person in a man called Tom aka camastomcat we struck a deal for one of his predator motors to go into my 70 Cuda street car. Its been a bit of a challenge here and there but its getting close to driveable.
Re: Out with the old. [Re: T-bar] #2776911
05/22/20 04:01 AM
05/22/20 04:01 AM
T-bar Offline OP
T-bar  Offline OP
The new one.
Re: Out with the old. [Re: T-bar] #2776920
05/22/20 07:28 AM
05/22/20 07:28 AM
Tulsa OK
Bad340fish Offline
Bad340fish  Offline
Tulsa OK
That should pick it up a little bit! Nice setup!
68 Barracuda Formula S 340
Re: Out with the old. [Re: Bad340fish] #2777064
05/22/20 02:52 PM
05/22/20 02:52 PM
T-bar Offline OP
T-bar  Offline OP
It should do, gone up to 598" hope it may crack an 8 eventually.
Re: Out with the old. [Re: T-bar] #2777090
05/22/20 03:28 PM
05/22/20 03:28 PM
Las Vegas
Al_Alguire Offline
Al_Alguire  Offline
Las Vegas
I remember Tom telling me he had sold one to a guy in Australlia. IM sure it will be a big step up from what you had for sure smile
Re: Out with the old. [Re: Al_Alguire] #2777150
05/22/20 06:54 PM
05/22/20 06:54 PM
T-bar Offline OP
T-bar  Offline OP
Yes it's going to be a big learning curve that's for sure. A big shout out to Tom as well for a man i never met he bent over backwards for me on this deal just from phone calls and emails. When we meet up one day i will be buying the beers.
Re: Out with the old. [Re: T-bar] #2777228
05/22/20 09:56 PM
05/22/20 09:56 PM
Taxes & Virus's R-US, NY
Dragula Offline
Dragula  Offline
That is awesome.....I love those engines. And look at all the room around it in there....What kind of power are you expecting out of it, and what compression?
Re: Out with the old. [Re: Al_Alguire] #2777247
05/22/20 10:51 PM
05/22/20 10:51 PM
Al, Is this Utah Toms Predator motor?
Re: Out with the old. [Re: Cab_Burge] #2777259
05/23/20 01:33 AM
05/23/20 01:33 AM
T-bar Offline OP
T-bar  Offline OP
Dragula, i moved the engine to the center to free up some room on the passenger side for the headers but they are very tall. I have a 4" reverse cowl and the top of the carb sit's level with the top of it. Compression is 14.3 to 1 will be using E85. Cab it was Tom's alloy block engine.
Re: Out with the old. [Re: T-bar] #2777281
05/23/20 08:27 AM
05/23/20 08:27 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
Still on stock front ? I'd be interested to see where the headers go, been wondering about these heads myself.
Re: Out with the old. [Re: T-bar] #2777305
05/23/20 09:14 AM
05/23/20 09:14 AM
Dragula Offline
Dragula  Offline
What I did with my engine plate was to better center my engine like you did.....I think I moved it over an inch to the drivers side......Then, because I had a Magnum force setup in the car, I lowered it as far as I possibly could. Literally, the oil filter spin on plate, I ground the bottom lip off it, and it basically touches the k-member....That allowed as much room as possible around the engine and heads, and hood clearance for the carb.....
Re: Out with the old. [Re: Dragula] #2777392
05/23/20 04:13 PM
05/23/20 04:13 PM
T-bar Offline OP
T-bar  Offline OP
Tig, stock front suspension K member just had to cut the driver side engine mount down to allow for the oil pump. Moving the motor to the center freed up a lot of room on the passenger side. We will try 2 1/8 primarys into 2 1/4 into 4" collector and see how it goes. An after market front end would be nice but the cost held that back for now.
Re: Out with the old. [Re: T-bar] #2777411
05/23/20 05:25 PM
05/23/20 05:25 PM
AndyF Offline
AndyF  Offline
One look at that intake and nobody is going to want to race you anymore! That engine looks serious. I see you used one of my engine plates so thanks for the business.
Re: Out with the old. [Re: AndyF] #2777578
05/24/20 03:20 AM
05/24/20 03:20 AM
T-bar Offline OP
T-bar  Offline OP
Yes Andy one of your plates but i did modify it a little to move it over. Getting the exhuast done in a couple of weeks then to the auto electrician and then hub dyno. Hopefully making some noise by the end of next month.
Re: Out with the old. [Re: T-bar] #2777580
05/24/20 04:39 AM
05/24/20 04:39 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Looking good .
Running Willowbank ?
Tex
New best ET 10.259@129.65 .
New best MPH 130.32
Finally fitted a solid cam,
stepped it up a bit more
3690lbs through the mufflers
Power by Tex's Automotive
Re: Out with the old. [Re: tex013] #2777581
05/24/20 05:14 AM
05/24/20 05:14 AM
T-bar Offline OP
T-bar  Offline OP
Willowbank and Warwick Tex.
Re: Out with the old. [Re: T-bar] #2777591
05/24/20 06:54 AM
05/24/20 06:54 AM
Sydney,Australia
tex013 Offline
tex013  Offline
Sydney,Australia
Neat
Tex
New best MPH 130.32
Re: Out with the old. [Re: T-bar] #2777616
05/24/20 08:51 AM
05/24/20 08:51 AM
A shed in England
Tig Offline
Tig  Offline
A shed in England
We managed to get 2 1/4 in to work with stock suspension and stock engine position in our ebody. Though we did have to cut away the D/S engine mount on the K frame to clear the dual line oiling system. Works with 385cc 572-13 heads and 600 -13 X heads. We recently fitted a QA1 crossmember after a big wheelstand cracked the stock one, it didn't put the suspension back in the same place and the headers fouled on stuff they never used to, BUT the geometery is WAY better. Just something to be aware of when you start hammering on some $2K custom stainless headers, DAMHIK laugh
BTW we have to run stock style suspension in one of the classes we run in over here, otherwise we'd do away with the torsion bars.
Re: Out with the old. [Re: T-bar] #2777618
05/24/20 08:55 AM
05/24/20 08:55 AM
Mo.
racerx Offline
racerx  Offline
Mo.
It should make some serious #'s on the hub dyno. smoke
Re: Out with the old. [Re: racerx] #2777907
05/25/20 03:43 AM
05/25/20 03:43 AM
T-bar Offline OP
T-bar  Offline OP
Racerx it should make some good numbers it was on the dyno when built and ran some nice number without being pushed real hard. It has been detuned a bit from how Tom had it in his dragster so i can run some street duties. Tig the class i'll be looking at running doesn't require stock stuff but it would be easier the for the header builder if the steering box and torsion bars weren't there but he will have to make them fit
Page 1 of 3 1 2 3
