Re: Out with the old.
[Re: T-bar]
#2776920
05/22/20 07:28 AM
05/22/20 07:28 AM
Posts: 8,018 Tulsa OK
Bad340fish
Tulsa OK
That should pick it up a little bit! Nice setup!
68 Barracuda Formula S 340
[Re: Al_Alguire]
#2777247
05/22/20 10:51 PM
05/22/20 10:51 PM
Posts: 43,097 Bend,OR USA
Cab_Burge
I remember Tom telling me he had sold one to a guy in Australlia. IM sure it will be a big step up from what you had for sure Al, Is this Utah Toms Predator motor?
[Re: Cab_Burge]
#2777259
05/23/20 01:33 AM
05/23/20 01:33 AM
Posts: 146 Queensland,Australia
T-bar
Dragula, i moved the engine to the center to free up some room on the passenger side for the headers but they are very tall. I have a 4" reverse cowl and the top of the carb sit's level with the top of it. Compression is 14.3 to 1 will be using E85. Cab it was Tom's alloy block engine.
[Re: T-bar]
#2777281
05/23/20 08:27 AM
05/23/20 08:27 AM
Posts: 2,915 A shed in England
Tig
A shed in England
Dragula, i moved the engine to the center to free up some room on the passenger side for the headers but they are very tall. I have a 4" reverse cowl and the top of the carb sit's level with the top of it. Compression is 14.3 to 1 will be using E85. Cab it was Tom's alloy block engine. Still on stock front ? I'd be interested to see where the headers go, been wondering about these heads myself.
'74 Challenger..9.46 @ 145.9 1/4, 6.001 @ 118 1/8 so far. 4023lb !!! # N/A, Marsh performance 655ci, Indy Maxx, T/R, Indy 600-13 X's, Street legal, pump gas, full interior, Cal-Tracs, mufflers, 3:73's and real 10.5 radials. 9.51 @ 142.4 1/4, 6.003 @ 114 1/8 with our old mule KB, 572-13, 580 wedge. RHD '68 Barracuda Fastback 323ci street/strip. Best ET 13.88 @ 99.03
[Re: T-bar]
#2777305
05/23/20 09:14 AM
05/23/20 09:14 AM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
What I did with my engine plate was to better center my engine like you did.....I think I moved it over an inch to the drivers side......Then, because I had a Magnum force setup in the car, I lowered it as far as I possibly could. Literally, the oil filter spin on plate, I ground the bottom lip off it, and it basically touches the k-member....That allowed as much room as possible around the engine and heads, and hood clearance for the carb.....
[Re: T-bar]
#2777411
05/23/20 05:25 PM
05/23/20 05:25 PM
Posts: 30,989 Oregon
AndyF
One look at that intake and nobody is going to want to race you anymore! That engine looks serious. I see you used one of my engine plates so thanks for the business.
[Re: T-bar]
#2777580
05/24/20 04:39 AM
05/24/20 04:39 AM
Posts: 2,457 Sydney,Australia
tex013
Sydney,Australia
Looking good . Running Willowbank ?
Tex
New best ET 10.259@129.65 . New best MPH 130.32 Finally fitted a solid cam, stepped it up a bit more 3690lbs through the mufflers New World block 3780lbs 10.278@130.80 . Wowser 10.253@130.24 footbraking from 1500rpm Power by Tex's Automotive
[Re: T-bar]
#2777616
05/24/20 08:51 AM
05/24/20 08:51 AM
Tig
A shed in England
Tig, stock front suspension K member just had to cut the driver side engine mount down to allow for the oil pump. Moving the motor to the center freed up a lot of room on the passenger side. We will try 2 1/8 primarys into 2 1/4 into 4" collector and see how it goes. An after market front end would be nice but the cost held that back for now. We managed to get 2 1/4 in to work with stock suspension and stock engine position in our ebody. Though we did have to cut away the D/S engine mount on the K frame to clear the dual line oiling system. Works with 385cc 572-13 heads and 600 -13 X heads. We recently fitted a QA1 crossmember after a big wheelstand cracked the stock one, it didn't put the suspension back in the same place and the headers fouled on stuff they never used to, BUT the geometery is WAY better. Just something to be aware of when you start hammering on some $2K custom stainless headers, DAMHIK BTW we have to run stock style suspension in one of the classes we run in over here, otherwise we'd do away with the torsion bars.
[Re: racerx]
#2777907
05/25/20 03:43 AM
05/25/20 03:43 AM
T-bar
Racerx it should make some good numbers it was on the dyno when built and ran some nice number without being pushed real hard. It has been detuned a bit from how Tom had it in his dragster so i can run some street duties. Tig the class i'll be looking at running doesn't require stock stuff but it would be easier the for the header builder if the steering box and torsion bars weren't there but he will have to make them fit
