Hemi guys, RBRE Hemi Rockers #2775224
05/16/20 08:00 PM
05/16/20 08:00 PM
Taxes & Virus's R-US, NY
Dragula Offline OP
Dragula  Offline OP
Anyone have back to back testing from standard rockers to the RBRE rockers?
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2775332
05/17/20 09:15 AM
05/17/20 09:15 AM
Dragula Offline OP
Dragula  Offline OP
Man, it sure is slow in here......If this had been a post about Hemi blocks there would be a hundred responses by now.
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2775349
05/17/20 10:16 AM
05/17/20 10:16 AM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
No back to back tests. Heck, no tests period (track is still closed). Thanks China!
[Linked Image]Untitled by Greg Ault, on Flickr
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2775395
05/17/20 12:23 PM
05/17/20 12:23 PM
S.E. Michigan
ZIPPY Offline
ZIPPY  Offline
S.E. Michigan
I have not used them but was fortunate to be given the guided tour of the product
by Chuck at Best Machine. Actually an older version and a new version that had some oiling
refinements. If you can get ahold of him, he knows all about them and probably has the info you're
looking for.
Rich H.
Esse Quam Videri
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2775475
05/17/20 04:29 PM
05/17/20 04:29 PM
Boynton Beach, Fl
Rapid588 Online content
Rapid588  Online Content
Boynton Beach, Fl
Don't think you would see a lot on a time slip, but the ratio's are tons better than original rockers. That being said, I love mine for many reasons, like the corrected ratio's, the better oiling, and ease of replacing individual rocker if needed... instead of removing rocker shafts and mounts to do one rocker!
93 Dodge Stealth - Supercharged 526ci Hemi
93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS
67 Hemi GTX (may the 4speed with you!)
Re: Hemi guys, RBRE Hemi Rockers [Re: ZIPPY] #2775479
05/17/20 04:35 PM
05/17/20 04:35 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
I run them, and I like them for several reasons. You can adjust geometry with them easily. You can pull one at a time to change springs, and they are more stable at high rpms than the normal stands. Jesel has the best hemi system there is for these type heads, but they require a fair amount of machine work to use,and they're more expensive.
Re: Hemi guys, RBRE Hemi Rockers [Re: Rapid588] #2775480
05/17/20 04:36 PM
05/17/20 04:36 PM
Boynton Beach, Fl
Boynton Beach, Fl
If you have a set of the earliest ones, make sure the ARP bolts holding down the pedestels are the correct length, I had a set of the first batch of rockers when they first came out, noticed a little oil seep out where the pedestal meets the head when I was setting the valves. Found the ARP bolts were slightly too long and were bottoming out when torquing them and were not fully seated.
I called RBRE and mentioned this to them, and then ground the bolts down to be able to race the next day. Overall... GREAT rocker system though!!!
Re: Hemi guys, RBRE Hemi Rockers [Re: gsmopar] #2775484
05/17/20 04:44 PM
05/17/20 04:44 PM
Dragula Offline OP
Dragula  Offline OP
What ratios are you guys using? I currently use the Indy rollers....work good, but I heard a rumor that the RBRE's are worth 25hp....
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2776162
05/19/20 03:32 PM
05/19/20 03:32 PM
Arizona, USA
gsmopar Offline
gsmopar  Offline
Arizona, USA
Click the pic and it will let you zoom in.
I = 1.6
E = 1.55
Re: Hemi guys, RBRE Hemi Rockers [Re: gsmopar] #2776169
05/19/20 03:48 PM
05/19/20 03:48 PM
N/E, Michigan
RATTRAP Offline
RATTRAP  Offline
N/E, Michigan
The advantage with the RB setup is that your able to correct bad valve geometry more easily.
Re: Hemi guys, RBRE Hemi Rockers [Re: RATTRAP] #2776214
05/19/20 05:50 PM
05/19/20 05:50 PM
Dragula Offline OP
Dragula  Offline OP
Looking for more HP....
Re: Hemi guys, RBRE Hemi Rockers [Re: dthemi] #2776218
05/19/20 05:59 PM
05/19/20 05:59 PM
NW Illinois
MoonshineMattK Offline
NW Illinois
What does a set of the Jesel rockers cost? And what makes them better? Did some googling and did not find any answers.
Thanks, Matt
Re: Hemi guys, RBRE Hemi Rockers [Re: MoonshineMattK] #2776248
05/19/20 07:24 PM
05/19/20 07:24 PM
DFW
mr_340 Offline
mr_340  Offline
DFW
[/quote]What does a set of the Jesel rockers cost? And what makes them better? Did some googling and did not find any answers.
Thanks, Matt [/quote]
I think they are around $5k, and there are a few versions. The Jesel site is hard to navigate and find the Hemi rocker arms.
Floyd Lippencott IV
Re: Hemi guys, RBRE Hemi Rockers [Re: mr_340] #2776264
05/19/20 08:28 PM
05/19/20 08:28 PM
Dragula Offline OP
Dragula  Offline OP
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2776422
05/20/20 11:52 AM
05/20/20 11:52 AM
NW Illinois
NW Illinois
Re: Hemi guys, RBRE Hemi Rockers [Re: mr_340] #2776431
05/20/20 12:10 PM
05/20/20 12:10 PM
back in Georgia
dthemi Offline
dthemi  Offline
back in Georgia
Thanks, Matt
I think they are around $5k, and there are a few versions. The Jesel site is hard to navigate and find the Hemi rocker arms. [/quote]
Yep, you'll have around 5 in them by the time you get them on the motor. Biggest difference is in the intake rocker design. As far as I know they are the most rpm stable you can just buy.
On my Barton TD stuff I run 1.7 on the intake and 1.6 exhaust
Re: Hemi guys, RBRE Hemi Rockers [Re: dthemi] #2776445
05/20/20 12:28 PM
05/20/20 12:28 PM
Temperance, MI
68 HEMI GTS Offline
68 HEMI GTS  Offline
Temperance, MI
I bought 1.6’s I&E for mine. I also decided to pushrod oil with some assistance from best machine.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780#
69 Roadrunner 511 six pack 10.92 drive to track street car
Re: Hemi guys, RBRE Hemi Rockers [Re: Dragula] #2776659
05/21/20 07:20 AM
05/21/20 07:20 AM
Northeast Indiana
73DAD Offline
73DAD  Offline
Northeast Indiana
If you're only looking for more power, I'm pretty sure Stage V makes/made a 1.7:1 ratio rocker.
Re: Hemi guys, RBRE Hemi Rockers [Re: 73DAD] #2776841
05/21/20 07:52 PM
05/21/20 07:52 PM
Melbourne , Australia
LA360 Offline
LA360  Offline
I do wonder how different the RBRE (T&D) system is to the Jesel System (that I believe Charlie Wescott worked with them on?)??
Alan Jones
