Re: Hemi guys, RBRE Hemi Rockers
[Re: Dragula]
#2775395
05/17/20 12:23 PM
05/17/20 12:23 PM
Posts: 17,840 S.E. Michigan
ZIPPY
S.E. Michigan
I have not used them but was fortunate to be given the guided tour of the product by Chuck at Best Machine. Actually an older version and a new version that had some oiling refinements. If you can get ahold of him, he knows all about them and probably has the info you're looking for.
Rich H.
Esse Quam Videri
[Re: Dragula]
#2775475
05/17/20 04:29 PM
05/17/20 04:29 PM
Posts: 995 Boynton Beach, Fl
Rapid588
Boynton Beach, Fl
Don't think you would see a lot on a time slip, but the ratio's are tons better than original rockers. That being said, I love mine for many reasons, like the corrected ratio's, the better oiling, and ease of replacing individual rocker if needed... instead of removing rocker shafts and mounts to do one rocker!
93 Dodge Stealth - Supercharged 526ci Hemi 93 Dodge Daytona Top Sportsman injected 588 Hemi - plus a lil NOS 67 Hemi GTX (may the 4speed with you!)
[Re: Rapid588]
#2775480
05/17/20 04:36 PM
05/17/20 04:36 PM
Rapid588
Boynton Beach, Fl
If you have a set of the earliest ones, make sure the ARP bolts holding down the pedestels are the correct length, I had a set of the first batch of rockers when they first came out, noticed a little oil seep out where the pedestal meets the head when I was setting the valves. Found the ARP bolts were slightly too long and were bottoming out when torquing them and were not fully seated.
I called RBRE and mentioned this to them, and then ground the bolts down to be able to race the next day. Overall... GREAT rocker system though!!!
[Re: gsmopar]
#2775484
05/17/20 04:44 PM
05/17/20 04:44 PM
Posts: 12,383 Taxes & Virus's R-US, NY
Dragula
No back to back tests. Heck, no tests period (track is still closed). Thanks China! Untitled by Greg Ault, on Flickr What ratios are you guys using? I currently use the Indy rollers....work good, but I heard a rumor that the RBRE's are worth 25hp....
[Re: Dragula]
#2776162
05/19/20 03:32 PM
05/19/20 03:32 PM
Posts: 1,145 Arizona, USA
gsmopar
Arizona, USA
What ratios are you guys using? I currently use the Indy rollers....work good, but I heard a rumor that the RBRE's are worth 25hp.... Click the pic and it will let you zoom in. I = 1.6 E = 1.55
[Re: dthemi]
#2776218
05/19/20 05:59 PM
05/19/20 05:59 PM
Posts: 287 NW Illinois
MoonshineMattK
NW Illinois
I run them, and I like them for several reasons. You can adjust geometry with them easily. You can pull one at a time to change springs, and they are more stable at high rpms than the normal stands. Jesel has the best hemi system there is for these type heads, but they require a fair amount of machine work to use,and they're more expensive. What does a set of the Jesel rockers cost? And what makes them better? Did some googling and did not find any answers. Thanks, Matt
[Re: MoonshineMattK]
#2776248
05/19/20 07:24 PM
05/19/20 07:24 PM
Posts: 3,504 DFW
mr_340
DFW
[/quote]What does a set of the Jesel rockers cost? And what makes them better? Did some googling and did not find any answers.
Thanks, Matt [/quote]
I think they are around $5k, and there are a few versions. The Jesel site is hard to navigate and find the Hemi rocker arms.
Floyd Lippencott IV
[Re: mr_340]
#2776431
05/20/20 12:10 PM
05/20/20 12:10 PM
Posts: 3,097 back in Georgia
dthemi
back in Georgia
Thanks, Matt I think they are around $5k, and there are a few versions. The Jesel site is hard to navigate and find the Hemi rocker arms. [/quote] Yep, you'll have around 5 in them by the time you get them on the motor. Biggest difference is in the intake rocker design. As far as I know they are the most rpm stable you can just buy. On my Barton TD stuff I run 1.7 on the intake and 1.6 exhaust
[Re: dthemi]
#2776445
05/20/20 12:28 PM
05/20/20 12:28 PM
Posts: 511 Temperance, MI
68 HEMI GTS
Temperance, MI
I bought 1.6’s I&E for mine. I also decided to pushrod oil with some assistance from best machine.
68 Dart GTS "HEMI" 10.30 @ 131 pump gas street car 3780# 69 Roadrunner 511 six pack 10.92 drive to track street car
[Re: 73DAD]
#2776841
05/21/20 07:52 PM
05/21/20 07:52 PM
Posts: 6,135 Melbourne , Australia
LA360
I do wonder how different the RBRE (T&D) system is to the Jesel System (that I believe Charlie Wescott worked with them on?)??
Alan Jones
